Projects "Hidden Agenda" Turbo Model A coupe rebuild
Discussion in 'The Hokey Ass Message Board' started by 100mph WHEELSPINNER, Mar 21, 2009.
  1. guthriesmith
    guthriesmith
    How did I miss this??? What a great build! Sounds like your priorities are right too.
  2. cfmvw
    cfmvw
    Wow, this thing is insane - great buildup!
  3. Blue One
    Blue One
    from Alberta
    Great that you have your priorities right. You have a beautiful family.
  4. Dan Timberlake
    Dan Timberlake
    gimpyshotrods likes this.
  5. daddio211
    daddio211
    I was trying to find this thread a few months ago, glad to see its still alive!
  6. Me either! :(
  7. brandon
    brandon
    From the way back machine
    kidcampbell71, Baumi and Just Gary like this.
  8. telecaster_6
    telecaster_6
    Just add some snow tires and you've got your self the best winter hot rod ...cause your heater will always be on broil...
    100mph WHEELSPINNER and Baumi like this.
  9. Baumi
    Baumi
    Any news on this build? I´m a little curious after all these years
  10. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Got the wife's 51 on the road. (its far from done) Gonna finally put this thing together again! More post to follow!
    AHotRod likes this.
  11. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    BBC is out. Turbo small block is going back in. Hoping to finally build the Hidden agenda as originally intended.
  12. pwschuh
    pwschuh
    Welcome back!
    100mph WHEELSPINNER likes this.
  13. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Thanks, Cant wait to be back on the road!
  14. Malcolm
    Malcolm
    from Nebraska
    Glad to see you're still at it!
  15. flamedabone
    flamedabone
    You have until August to get that thing to the HAMB Drags. Keep at it.
    -Abone.
  16. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    After God-only-knows how many months of dreaming/wishing/planning, we finally have a brand new T56 for the Coupe! Lord willing, the "Hidden Agenda" will be gracing a race track near you in the not-so-distant future! Thanks Mark Bowler at Bowler Performance Transmissions !
  17. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Looking for a nice stock model a full hood in the southern Indiana/Illinois area.
  18. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    What times you running defending that Yay-Hoo cup?
  19. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Scored a nice hood. Gotta extend it because of the 32 frame. While everyone is staring at perfection at the roadster show I sit in my shop sipping whiskey and laying down some Sem trim black for another go at it!
    loudbang and rod1 like this.
  20. flamedabone
    flamedabone
    It depends on who shows up. Sometimes the winner is a 13 second car, or Racer X might drive his insane 6 second Dodge coupe. The real goal is to actually drive your car to the Drags, flog the hell out of it and still make it home. It's fun as Hell, you'll dig it I promise.
    -Abone.
  21. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Am I allowed to change tires once i get there?
  22. Malcolm
    Malcolm
    from Nebraska
    Absolutely.
    100mph WHEELSPINNER and loudbang like this.
  23. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Made some progress on the hood tonight.
  24. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Had to take a break and get the gokart going for the ice! cheers!
    loudbang and Baumi like this.
  25. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Help fellow hotrodders: I am looking to buy a full set of hydraulic roller lifters for a first gen small block chevy. I am looking for any set other than comp cams part# 15853. As you see in the picture I have 3 pair with roller pin problems. Seat height 2.66, Body dia 0.842 in. Any help locating a set is greatly appreciated.
  26. Tim_with_a_T
    Tim_with_a_T
    Off the wall response, but have you considered going with a solid roller lifter instead? If you watch Engine Masters, they put solid roller lifters on a hydraulic roller cam with some good results... their only concern was durability/life cylcles long term because no one has really tested this.
    loudbang and 100mph WHEELSPINNER like this.
  27. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Yes I have thought of going solid roller. That is what comp cams recommended. (No one has solid lifters either). I have talked with Jegs, Summit, and Com Cams. They are out of stock of all roller lifters for 1-3months. I talked with a couple other manufactures today that had nothing available and asked them what was up. They said no one can get the steel to make them. Its a crazy world. I never would have thought I couldn't find a roller lifter for a sbc. I know this may be crazy but whats your thoughts on tig welding the shafts on the set that I have? Just to be clear I was trying to find lifters with the same seat height so that I don't have to change push rods also.
    loudbang and Tim_with_a_T like this.
  28. Roothawg
    Roothawg
    Why not use the LS7 lifters? They are interchangeable. Cheap too.
  29. Tim_with_a_T
    Tim_with_a_T
    The solid lifters are shorter than hydraulic, so you would have to change pushrods in that situation. I can't advise on welding the shafts to the set you have, I have no experience with that and am not the best welder, or engine builder for that matter LOL. I recently bought lifters and I had the same problem you have, I got the last set of solid rollers Summit had that were reasonably priced.
    LS7 lifters will only work in a late model roller block with the lifter spider and factory lifter links, because they don't have the tie bar like the retrofit ones, unless I am totally missing something here.
  30. Roothawg
    Roothawg
    You are correct. I wasn’t thinking about the early block provisions. I have been on Darts website all day looking at later styled blocks. My bad.
    Tim_with_a_T likes this.
