HA/GR in Minnesota
Discussion in 'HA/GR' started by bobw, Jan 14, 2009.
  1. bobw
    bobw
    Here's a pic of the upper manifold with two Motorcraft two barrels mounted to it. They are 1.14" venturi units. Not sure if this will get tried.
  2. bobw
    bobw
    Went 11.12 with the 3 Two barrel Motorcraft carbs. Will be running this 2 -4 barrel Holley set up this year. Hoping to dip into the 10's.
    300racr, Chucky and Crosley like this.
  3. Rand Man
    Rand Man
    You’re haulin *** now.
  4. bobw
    bobw
    In the process of removing around 100 pounds of excess weight. Changing to an Anglia front axle and narrow aluminum front wheels. Also made a header to replace the individual pipes.
  5. RacerRoy3
    RacerRoy3
    Great to see you back! The 10's can't be far off.
  6. bobw
    bobw
    We only ran at two meets. A total of 6 runs. Five of them in the 10's. Best was our final run of the year. A 10.69 @ 118mph. This was with two 750 cfm Holley carbs. Will be changing to two 600 cfm Holleys for next season as it was a bit over carbed. IMG_3363.JPG Managed to remove 120 lbs. from it last winter.
    300racr, Crosley and Rand Man like this.
  7. spanners
    spanners
    Fantastic. Do you think the new pipe work made a big difference? 120 lbs was a lot of t*******.
    I ran at the Nostalgia Nationals over here at the weekend but I'll do a race report later.
    Crosley likes this.
