Technical Who or where do I get a custom windshield
Discussion in 'Traditional Customs' started by STREETREBEL, Jan 7, 2022.
  1. 38Chevy454
    38Chevy454
    ***uming your bottom of the windshield is the original shape, you are probably best to start with a stock windshield and cut that down. Hopefully the sides and top shape will work with the windshield. You have pretty serious chop, so it may need some metal work to fit a cut down windshield.
    You can try making a fibergl*** mold off your current lexan, and then compare that to stock windshield. Or worse case you can go to junkyard and take your template to find a windshield that has the right shape. It may need to be cut on all four sides. But given the more serious curve at the sides on stock windshield, doubt you will find any newer car to work. But that template trick can work out for rear window gl***. Stock rear gl*** is tempered and can't be cut down. That's the reason many chops just lay down the rear, or use a smaller rear out of different car.
  2. Curt R
    Curt R
    this may be cost prohibitive but they make new windshields
    Fox Fire Gl***, LLC
    • 3071 W Thompson Rd
    • Fenton, MI 48430
    Automotive: Fox Fire Gl*** LLC collaborates with automotive, marine, and transportation designers, engineers, prototype shops, and restoration facilities to fabricate gl*** components to their project’s specifications. Unlike production resources, we have the ability to produce low volume runs and the flexibility to adjust as the project progresses. This eliminates the overwhelming expense of production tooling and allows for the unexpected modifications that often occur during prototype processing.
    Curt R
  3. 5window
    5window
    It has to be gl*** in Pennsylvania.
    gimpyshotrods likes this.
  4. Lloyd's paint & glass
    Just start calling gl*** shops man! Or come to Owingsville. It's just gl***, old school ways still work.
    54delray likes this.
  5. 6sally6
    6sally6
    Check with jakesbackyard (a regular on here) He just finished a 50 Ford Ranchero and he chopped the top! He may be some help
    6sally6
  6. 38mag
    38mag
    In PA it's 7" for street rods, 11' for all others.
  7. In other words, the OP may be ****ed
    squirrel likes this.
  8. squirrel
    yeah...never buy a chopped car unless it has all the gl***, and the gl*** fits and works.
  9. Hellfish
    Hellfish
    A couple of years ago I called around about how much it would cost to have custom gl*** made on a fic***ious window. Everyone said it was expensive, but no one actually knew. I was curious.
    Curved Gl*** Creations in Florida said that they would need more info of course, but based on the details I provided, they estimated the price would range between $600 to $3000 (US) with 3-6 weeks for production. CurvedGl***Creations.
    Standard Bent Gl*** said they do not do car gl***, but suggested I contact Fox Fire Gl***, which someone mentioned above.
    There's also this place http://www.calgl***bending.com/.
    54delray and David Gersic like this.
  10. 5window
    5window
    OP, do you have the original gl***? How's it match up> I'm thinking you need a road tip to see Lloyd.
  11. wvenfield
    wvenfield
    I watched a guy cut out a windshield on one of them there television shows. One would think it complicated and granted he knew what he was doing but it did not seem all that hard.
  12. Lloyd's paint & glass
    Just like everything else, it takes practice, but accidents do happen. Ice will melt, paint will run, gl*** will break. You don't learn to cut gl*** on curved gl***. The gl*** company i work at for 6 years had the contract with UPS for most of the time I was there. We'd roll in at night and average about 5 pieces. Phil taught me on s**** pieces, then I'd cut a backhoe gl*** or something, then one day we got a call to Danny's body shop in Pedro Ohio for a C-10 that he had chopped. That's where it started. Broke the first one, which was the old gl***, 2nd gl*** was a charm. It's a craft, takes time to learn.
  13. Slopok
    Slopok
    EVERTHING on TV looks easy!!! o_O
    rockable and gimpyshotrods like this.
  14. wvenfield
    wvenfield
    I am sure it takes practice but the guy had no problem cutting the windshield out. You continue to note to go to a gl*** shop and get one cut out. Thread over.
  15. Lloyd's paint & glass
    Thread over? What the **** did I do? Yeah thread over for me. Get a cabinet maker to give advice on cutting gl***. I couldn't care any less :D I know how to do it myself.
  16. wvenfield
    wvenfield
    LOL. Your answer was the correct one. Go to a gl*** shop and have them cut you one.
  17. 5window
    5window
    Yeah, it's like the videos I watch to learn a surgery. Done by an expert and if they screw up, they just start over with another take. Not much help if you are trying to learn, especially if it's something that doesn't always do would it should. Like gl***. Or knee joints.
    With something in short supply-like that windshield-get an expert. You want to learn-get some s**** windshields.
    Loyd is correct and at some point, you can't get more correct.
  18. Truck64
    Truck64
    from Ioway
    There's all kinds of stuff that looks easy, but ... it ain't.
    5window likes this.
  19. Check the gl*** shops advertised in Hemmings. Also consider Lexan, I made a window for a 56 Ford pickup from Lexan, heating and bending it with a acetylene torch held about a foot away.
  20. 5window
    5window
    From everything I can find online, Missouri, where the OP resides, requires windshields to be made of safety gl***. i guess if it's a show only car you might use Lexan, but otherwise, better see a gl*** shop.
  21. rockable
    rockable
    I met a guy who bought this Rich Zocchi 57 Buick. When he got it, the windshield was cracked. He said they broke 2 more before they got one good. Expensive.
  22. F-ONE
    F-ONE
    from Alabama
    Modify the car to take divided flat gl***.
    5window likes this.
  23. hotrodlane
    hotrodlane
    You heard right! when doing those chops it is always best to make the body fit a cut down windshield. Having a custom curved windshield made from scratch can be very pricey if you can even find anyone who will do it anymore.
    64coolbrez and 54delray like this.
  24. BJR
    BJR
    That is why when I chopped my 49 Buick I cut the cowl instead of the windshield posts. If I pick up a rock and bust the windshield I can replace it with stock gl***.
