Projects 1938,39,40 Sloper Custom
Discussion in 'The Hokey Ass Message Board' started by X38, Nov 4, 2020.
  1. Jacksmith
    Jacksmith
    from Aridzona
  2. 1-SHOT
    1-SHOT
    from Denton
    What did you use for a shifter detent on the column? Frank
  3. X38
    X38
    I made that some time ago, I have pics somewhere.
    chryslerfan55 and brEad like this.
  4. Outback
    Outback
    from NE Vic
    That's gold! Good progress btw! Looking good!
  5. X38
    X38
    Making the shifter work.
    First up, I wanted the gate at the top of the column and figured I could mount it behind the column drop I had made. Next, how? Because of the way the lever operated it moved the gate tang in the opposite way to a regular Ford auto column (stock the tang moves down to disengage.) When you pull back on the lever on the 40 column, the shaft moves up. I made tang and mounted it as high as possible while still allowing full movement. I made this as a screw-on part. Then the gate itself...
    Because the movement of the tang when in engaged/disengaged was now different from a stock situation, I found I had to make a new gate in a mirror image of a factory one. These shown are RHD factory ones. I made the new one at the rear from stainless. I should also note that I was trying to keep all the sweep radiuses, shift arm lengths etc. the same as factory to minimise issues. The arm in this pic is one of the manual ones shortened to replicate the operating radius of the factory auto version.
    I finished up the gate and also made it a screw-on piece, this time to the column drop. So far so good.
    Arm at the modified lower end.
    I mounted the column and then determined the necessary modifications to the shift linkage rod. This connects to the modified factory RHD monkey motion connection to the transmission as shown many posts back.
    In place and hooked up. Much to my relief, it works! Phew! It does clear the factory dipstick tube when it's bolted in place on the back of the head. There is obviously plenty of finessing to do, but at this point I'm pretty happy.
  6. That is slick! Nicely done.
    Stogy, Hnstray and X38 like this.
  7. Bandit Billy
    Bandit Billy
    Left hand drive is tougher than I imagined with dip sticks and the starter over there. I will never complain about tight spaces for my steering again.
  8. X38
    X38
    Yes, it creates extra issues. Which is why I went for hanging pedals this time around with the column shift involved.
    Stogy, Hnstray, Outback and 3 others like this.
  9. That detent is super cool.
    X38 and TrailerTrashToo like this.
  10. tub1
    tub1
    from tasmania
    Cool having original lever to shift , I had original shifter in my 47 Merc years ago ,with Windsor and C4 ,I didn't have a detent , just selected whatever needed , mind you no engineer need for rego then
    Outback and chryslerfan55 like this.
  11. X38
    X38
    Been doing mostly mechanical work lately but I did manage to get some primer on the roof and cowl.
    Crusty Chevy, Spoggie, Tman and 15 others like this.
  12. Gotta love 41 Studebaker taillights. They're a natural for these cars.
    Stogy, Hnstray and OG lil E like this.
  13. Dean Lowe
    Dean Lowe
    Looking good Tony!
    Spoggie, Stogy, Hnstray and 1 other person like this.
  14. The 39 guy
    The 39 guy
    That whole shifter system is just brilliant old boy!
  15. X38
    X38
  16. alchemy
    alchemy
    Good Job! Every line and shape is perfect!
    Spoggie, Stogy, X38 and 2 others like this.
  17. Bandit Billy
    Bandit Billy
    Love the welded/moulded fenders, gravel pan and rear deck. I know the front is going to be uber cool but it will be hard to beat that ***!
    chryslerfan55, Stogy, X38 and 2 others like this.
  18. Not enough "o's" in smoooooth!
    Spoggie, Stogy, X38 and 1 other person like this.
  19. aussie57wag
    aussie57wag
    from australia
    Very cool. Looking great. A car that cool deserves something a bit a more interesting and cool than a regular sbf and 3 spd auto.
  20. X38
    X38
    If you're buying, I'm all ears.;)
    Spoggie, Outback, Stogy and 3 others like this.
  21. The 39 guy
    The 39 guy
    Great picture of a very beautiful car! You sure have a lot of light in that picture! makes me dream of bright summer days....
    Stogy and X38 like this.
  22. X38
    X38
    Before I put the trunk lid back on for safe keeping a few more mundane things had to be taken care of. Such as the brace for the trunk prop. This had the bottom cut off at some point so was just swinging in the breeze...and this brace is important because, well, the trunk lid is heavy and can distort the trunk surround. So I took off what was there and lengthened it.
    Cleaned up:
    In place:
    Spoggie, brEad, hotrodjack33 and 8 others like this.
  23. Bandit Billy
    Bandit Billy
    Nice work X
    Stogy likes this.
  24. The 39 guy
    The 39 guy
    That's interesting....My 39 CS does not have a support there. I have not noticed any flex of trunk surround but I will have to check for it that next time I put the trunk lid on. Thanks for sharing this info.
    Stogy and chryslerfan55 like this.
  25. X38
    X38
    Next bit was the bracing under the parcel shelf. Originally these cars didn't have any because the seat back could fold forward etc. to give a 6ft floor from the trunk to the front seats. I won't have that feature, but do want bracing.
    I folded up these hat sections.
    Fitted them like this and gave everything a coat of red oxide epoxy.
  26. The 39 guy
    The 39 guy
    Nice job! Looks Factory!
    Outback, Stogy and chryslerfan55 like this.
  27. X38
    X38
    Yes, they are for a shelf. The spare didn’t stand vertically because of the fold down seat, but sat flat under the shelf - which was removable.
    You’ll also notice the hump in the floor for the frame C-notch.
    Spoggie likes this.
  28. tub1
    tub1
    from tasmania
    It's Amazing what you can fit in a ford sloper with the the original seat folded down ,have filled mine up with swap meet parts a few times
    Outback and X38 like this.
  29. jimmy six
    jimmy six
  30. X38
    X38
    That looks like DD.
    jimmy six likes this.
