Hot Rods Southeast Gasser, Father and Son H/Gas build
Discussion in 'The Hokey Ass Message Board' started by 37dodge, Dec 18, 2020.
  1. 37dodge
    37dodge
    from Oxford, NC
    The engine ***embly went Ok, just slow as usual. Not a whole lot to show for that part, but here is a few of the process. 20211018_191143.jpg 20211120_130130.jpg 20211120_130142.jpg
  2. 37dodge
    37dodge
    from Oxford, NC
  3. 37dodge
    37dodge
    from Oxford, NC
    One thing that made me scratch my head was, how far off the timing was from the cam card. The cam is a Tatom's spec grind by Schneider and the timing gear is an Elgin. Turned out the intake centerline was falling on 123* and should be 110*. Had to pin the camshaft and use an offset bushing to get me back to 110 ICL. 20211015_193328.jpg 20211015_193344.jpg
  4. AHotRod
    AHotRod
    I can't wait to hear that old flatty run.
    What RPM do you think you will be turning it?
    chryslerfan55, catdad49 and loudbang like this.
  5. 37dodge
    37dodge
    from Oxford, NC
    I am thinking it will RPM to 5500 safely.
    bchctybob, chryslerfan55 and loudbang like this.
  6. 37dodge
    37dodge
    from Oxford, NC
    We needed to make a block saver plate out of 1/8" 6061-T6 aluminum. Made the pattern from the bellhousing, drilled come holes and used the plasma cutter to cut it out. Came out pretty good.
  7. 37dodge
    37dodge
    from Oxford, NC
    Another thing that bothered us on the car was the front axle. It is a narrowed 56 F100 axle with unknown spindle/ brake conversion and it had crazy amounts of positive camber, kind of tractor like as evidenced it the pictures. So, while the engine was out it is a good time to start over on the front end.
  8. 37dodge
    37dodge
    from Oxford, NC
    The I beam axle is about a 2.5" drop, but the spring perches had 2" riser blocks plus caster shims. The brakes were 11 inch vented rotors with GM calipers. A lot of weight if you add it all up.
    I ordered a HD straight tube axle from speedway and basically the front-end & brake ***embly that uses their forged and machined Chevy spindles. We re-used the existing leaf springs and a few pieces of hardware. The HD Speedway axle is robust and actually heavier than I thought it would be. But it ain't going to bend on us. After mocking it in place I welded the spring perches on the tube to give us 8* caster.
  9. Lloyd's paint & glass
    Looking great, hope to see it in person someday!
    seb fontana and loudbang like this.
  10. 37dodge
    37dodge
    from Oxford, NC
    The front axle is all together and it came out great. Only minor tweaking needed to get it all to fit. So now it was time to drop in the motor and trans. 20220205_153604.jpg 20220205_153621.jpg 20220205_160122.jpg
  11. catdad49
    catdad49
    Looking Good!
  12. 37dodge
    37dodge
    from Oxford, NC
    More progress updates. Engine is in place and just about ready for start-up. We are running a cooling system so had to come up with a radiator. Used the small race radiator that came with the car but had another inlet and 2 outlets welded in for the flathead configuration. There is not much real estate in the front, so options were limited. Made a fuel log for the 3 carbs with pressure gauge and hooked up the lines. Fabbed up a crankcase vent in place of the mech fuel pump ***bly. Not running a charging system so made a belt tensioner so we can still drive the water pumps. Got the headers and the exhaust dumps all made up. engine.jpg engine.jpg headers.jpg
  13. sidevalve8ba
    sidevalve8ba
  14. Philip Gilmore
    Philip Gilmore
    The blue looks gorgeous!
    catdad49 likes this.
  15. loveoftiki
    loveoftiki
    from Livonia,Mi
    Not bad….a little secret..you can have a sign shop make a template for ya and all ya do is brush the paint on and peel the template off..not real expensive and leads to great results
    great color..are those rims real Magnesium?
    bchctybob likes this.
  16. 37dodge
    37dodge
    from Oxford, NC
    I can't believe it has been over a year since I posted on this build. A couple recent comments about it helped me revive it. We got it running and started tuning it up. This happened at the tail end of 2022. Here is a short video of some garage testing to make sure it moved under its own power.
    bchctybob, catdad49, Randall and 5 others like this.
  17. 37dodge
    37dodge
    from Oxford, NC
    Here is another vid of it idling in the garage. This one is open headers. The previous one I had some mufflers attached to not piss of the neighbors too much.
  18. 37dodge
    37dodge
    from Oxford, NC
    Once we felt things were Ok with it, we took it out for some actual test N Tune. As expected, there were some bugs to iron out. Really had to work on jetting and proper timing. But it went down the track Ok until one time on a shift to 2nd, it death wobbled like crazy. Also, out little radiator wasn't going to cut it. Just sitting in staging and making a run and getting back to the pits, it was getting too warm for comfort. Resized_IMG_5651.jpeg Minor1.jpeg
    oldiron 440, KiWinUS, slayer and 4 others like this.
  19. 37dodge
    37dodge
    from Oxford, NC
    Needing a bigger radiator required reconfiguring the front frame crossmember and lowering it down 6 inches. There is so little real estate under the hood, it really was a c Radiator support 155746.jpg hallenge.
  20. Lloyd's paint & glass
    Love it man. Cool little car. As far as your lettering, it looks awesome. We're always our own worse critics on this stuff, anything with the human element isn't gonna be perfect, I'd rather see character than to see a laser cut vinyl sticker ;)
  21. mad mikey
    mad mikey
    WOW! :):):):):) That is a great little car. Congrats on a job very well done.
  22. 37dodge
    37dodge
    from Oxford, NC
    So, we finally made it out to a Southeast G***ers event in May of this year at Wilksboro Dragway in NC and had a great time. The car ran well and was well received by everyone. There are some things we need to work on and a lot of it is me. Here is one last one for now. Enjoy.
  23. 37dodge
    37dodge
    from Oxford, NC
    OK, one more.....
  24. catdad49
    catdad49
    Lookin’ Good going down the track, you should be Proud!!
    mad mikey, Randall and 427 sleeper like this.
  25. oldiron 440
    oldiron 440
    I wish I could hit that little like ****on a few hundred times more! I really liked the 3-4 shift…lol
    37dodge likes this.
  26. catdad49
    catdad49
    Sad to see that you are selling this little beast, but I know you both had a great Father Son experience with it! All the Best, Carp,
    mad mikey likes this.
  27. sidevalve8ba
    sidevalve8ba
  28. Quain Stott
    Quain Stott
    I loved that car and and hate to hear you're selling it. It was a big hit at the SEGA race you came to, hope it stays in SEGA where it can be appreciated for what it is.
  29. ***Area-51***
    ***Area-51***
    from Ohio
    That thing is Cool as sh!t :cool::cool:!!!!!
  30. 37dodge
    37dodge
    from Oxford, NC
    I have decided to put it up for sale and see what happens. The engine is out to get sleeved and for crack repair which took me out late last season, so selling the car as a roller. Hope it can stay in the SEGA family to do what it was built for. See the add in the cl***ifieds if you're interested. I guess if it doesn't sell, we'll keep working on it as time and money allows us, both of which are in short supply nowadays.
