Customs 1959 Bel Air 2 door hardtop build.
Discussion in 'The Hokey Ass Message Board' started by 110mike, Jun 17, 2020.
  1. 110mike
    110mike
    Just got out of paint.
    Will be cutting and buffing.
  2. 110mike
    110mike
    20211218_120408.jpg 20211209_220213.jpg 20211209_215538.jpg 20211209_215523.jpg 20211209_215149.jpg IMG_20211209_210034_01.jpg
    This is pre paint mock up.
    Everything fit very well.
    Gl*** went it right after these pics. I wanted to be sure rear gl*** still fit as i did alot of work back there.
  3. 110mike
    110mike
  4. 110mike
    110mike
    Seats. 1964 Tbird...... dont hate me....
    Bench was just SO boaring i couldnt do it.
    Made my own seat pans that mate the deat to the stock floor. That means the bench can go back in if desired.
    Lets face it, GMs design budget in 1959 ran out after the body/dash we done. Stock interior is SO boaring. I wanted,,, no, NEEDED, buckets and a console.
    Lloyd's paint & glass and Baumi like this.
  5. Squablow
    Squablow
    If you're gonna put buckets and console into a 50's car, the '64 Thunderbird setup is one of the best possible choices. Still period correct, and lots of custom Mercs got the same thing, along with the wraparound back seat. Not sure if you could make that work in a '59 Chevy or not but would look cool if you could, although the front seats and console look nice on their own.
  6. 110mike
    110mike
    Question:
    59-60 2 door HTs;
    Left and right, rear window area, UPPER stailess trim with the "fuzzies" that are spotwelded to the "bannana looking" stainless trim. Where the rear window slides into when the window is all the way up;
    How do you replace the fuzzy in this trim ??
    Mine fuzzies are nonexistent and require replacement.
    I ***ume i have to drill out the spotwelds that hold in the fuzzy channel to the stainless trim???
    Is the replacement just fuzzy-channel-by-the-foot??
    I cannot find difinitive info on this.
    Please help if you have any info.
  7. vtwhead
    vtwhead
    Mike, try these guys as they have bailed me out at times. Worth a shot.
    Restoration Specialties, 148 Minnow Creek Road, PO Box 328, Windbar, PA. 15963
    814-467-9842 Jeff or Bill
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    This ? According to a 2014 thread on here , PUI has them
  9. Mcspar
    Mcspar
    Hi Mike, Thanks for the do***entation on this build. I am also working on a 59 Bel Air hardtop and would like to ask a few questions.
    1. Where is the cowl tag on your car? I'm pretty sure mine is not in the correct spot and I want to make it as "right" as I can when I get to that point
    2. Where is the VIN tag on your car? Mine is inside the drivers door and this one seems to be in the correct location.
    3. Do both tags have aluminum finish or were they painted?
    4. Was your VIN stamped into the frame on your car? If so, where were the stamps?
    any ***istance is appreciated. Pictures would be super helpful. I will try to figure out for to attach pictures of mine as well. Thanks in advance. Mike Spar
  10. Slick111
    Slick111
    I have family in Calgary my uncle had a 59 Bel Air 2 door HT green white no pictures survived cant remember just how the white went on top and onto the deck lid how it was divided off
