Hot Rods Rusty has a new project- father son build , 26 T roadster!
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Jul 26, 2021.
  1. 101Scout
    101Scout
    Awesome build, really nice work!
    Stogy, loudbang and Greenblade like this.
  2. rusty rocket
    rusty rocket
    Have our box location figured out, it’s a tight fit. 64BB5B5C-737A-4F1A-B082-10AED0A58A49.jpeg 7E1E60E2-017B-429C-8342-C09BA60EA8E7.jpeg BA2782D4-FA79-470C-B20B-E55C4FB98050.jpeg
    chryslerfan55, Tim, brEad and 6 others like this.
  3. Blues4U
    Blues4U
    from So Cal
    Looks like you'll just have room for the center exhaust outlet.
  4. rusty rocket
    rusty rocket
    Center will not be a problem but he rear Will be dang close. We will build a kick**** set of headers so I’ll make them fit.
  5. tombstone
    tombstone
    from sk.canada
    To gain more room have you considered mounting the box on top of the rail ?
    Stogy likes this.
  6. rusty rocket
    rusty rocket
    Runs right into the side of the block.
    loudbang, Greenblade and Stogy like this.
  7. Stogy
    Stogy
    Looking good Rusty...you are a ball of energy...22 is delivering good times...;)
    loudbang, 101Scout and Greenblade like this.
  8. rusty rocket
    rusty rocket
    Have our front shock/headlight mounts done on the front. F66C0D8B-5AB6-4668-9D4B-B4569AF9BF05.jpeg E840EFFC-EBF0-45BF-BAD2-B11957BC2651.jpeg DF72A656-F8F3-4501-9F3C-E39690DF32F2.jpeg Started working on the rear mounts. I had a chunk of heavy wall square tube that I cut for the top mount. D4C19B09-E868-45B4-9C5C-4DBCE5F7A8BA.jpeg The bottom mount will be the castoff part of the rear 35/6 bone. 99B0681D-907E-409A-A60F-F8B1D289AFC2.jpeg 6EFE61BD-D296-4891-A32B-9E2F48AB4993.jpeg
  9. rusty1
    rusty1
    ...you guys do nice work, always fun following along, carry n...
  10. atch
    atch
    Did this start out as an F-1 shock mount and part of a headlight bar?
  11. rusty rocket
    rusty rocket
    It
    It sure is, shortened the f100 mount reclocked it to fit the frame and then used the ends of a model A headlight bar
  12. atch
    atch
    Well done my friend...
  13. Kume
    Kume
    Am loving this build.
    Where did all the Model T roadster trunk lids go?
    scotts52, Tman, loudbang and 2 others like this.
  14. rusty rocket
    rusty rocket
    I wish I knew. I’ve heard story’s here in the states during the Great Depression trucks got more gas ration stamps so if you had a car you pulled the trunk lid off and slid in a pickup box. My pops model A roadster had that done to it and I’m guessing this T had it done also.
  15. phat rat
    phat rat
    That's the story I've always heard. It makes sense as it wasn't just T's and A's that this happened to
    loudbang, Stogy and Greenblade like this.
  16. MMM1693
    MMM1693
    Very nice work!
  17. Kume
    Kume
    That makes sense.
    Howells have done well as a result.
  18. scotts52
    scotts52
    I've heard that a lot were pulled off and used as sleds. What's weird is seems disproportionately Ts. I don't see as many other makes/ models missing their kids. Except 33/34 Dodge and Plymouth coupes, they seem to all be missing too.
  19. Greenblade
    Greenblade
    Took these pics of the piston heads awhile back. 20210903_153314.jpg 20210903_152410.jpg 20210903_153332.jpg 20210903_153314.jpg
  20. rusty rocket
    rusty rocket
    Got our third link mocked up. Not much progress lately. 253FB208-D13A-419F-AD4F-8519C950AA61.jpeg 435059E6-12C4-45BD-9434-91D2F86D8221.jpeg
    chryslerfan55, Tim, brEad and 3 others like this.
  21. rusty rocket
    rusty rocket
    I found a 35/6 inner drive shaft here on the hamb to build a set of lakes headers. Been brutally cold here but I did find a bit of time to warm up the shop and get the drivers side built and tacked together. E3D72ABC-9393-4E15-ACC6-40D476484098.jpeg E88D4969-67DE-4D2B-B6D6-F729D372D6AA.jpeg 79F04BFC-6FCB-4161-9BF7-8580E4BF61B3.jpeg
  22. tombstone
    tombstone
    from sk.canada
    Damn those are looking great ‼️
  23. 6inarow
    6inarow
    Looks great!!. Wow. Nice job!! Inliner exhaust would be easier around the steering box. Just sayin
    Stogy and loudbang like this.
  24. Greenblade
    Greenblade
    Some pictures of the T at the 2022 counts car show; 20220217_143129.jpg 20220217_143152.jpg 20220217_143147.jpg 20220217_143139.jpg 20220220_161910.jpg
  25. loudbang
    Headers look great for a freezing my**** off job. :)
    chryslerfan55, Stogy and Greenblade like this.
  26. vtwhead
    vtwhead
    Nice job on the header Rusty. It's a****** working in the cold weather but you made great progress.
    Stogy, Greenblade and loudbang like this.
  27. rusty rocket
    rusty rocket
    Minus temperatures definitely***** but I have a decent furnace in the shop so if the doors stay shut it’s a very workable environment although the concrete is a bit cool.
    chryslerfan55, Stogy, Tim and 2 others like this.
  28. 51504bat
    51504bat
  29. Tim
    Tim
    from KCMO
    Headers are looking sharp
  30. rusty rocket
    rusty rocket
    Have both headers built and tacked together. I still need to add the dumps to route exhaust under the car. 0FFB9BBE-B901-40EF-84CE-39F7F5C4EB30.jpeg I’ve also got the steering box mounted to the frame. I had to bend the steering arm on the spindle down to get the draglink on a better plain. I also bent up an old 41 Ford drag link to work around the radius rod it will be replaced with a new one when we get a little further down the road. 99295ED9-B960-4BC6-B233-76D9B732288D.jpeg
