Hot Rods VIN Decoding
Discussion in 'The Hokey Ass Message Board' started by SherryJeffreys1982, Jan 21, 2022.
Tags:
  1. Can someone help me with this serial number? C13Y2994
    We think it is a 1934 Ford
  2. Budget36
    Budget36
    As will be told to you soon, it’s a serial number , not a VIN. What make of vehicle?
    gimpyshotrods likes this.
  3. gary macdonald
    gary macdonald
    Nothing to decode . Ser num or body ***embly number,not a vehicle Identification number
    X38 and gimpyshotrods like this.
  4. Budget36
    Budget36
    But 7 8 9…
    Gotta be the reason 10 hit the road.
    silent rick likes this.
  5. Slopok
    Slopok
    What is an overp*** ?? Is this an S or a 5 ?? :confused:
    XXL__, gimpyshotrods and hidez57 like this.
  6. oldolds
    oldolds
    Coffee for Rob Ot
    gimpyshotrods and Slopok like this.
  7. junkman8888
    junkman8888
    Apparently some of us forgot to take our meds today!
    lurker mick likes this.
  8. AngleDrive
    AngleDrive
    from Florida
    1934 Ford Serial numbers were 18-457478 to 18-1234356, with a star before the number and a star after the number.
    Edit....US built cars
  9. Slopok
    Slopok
    Post a picture here and you will have an answer as to exactly what you have within minutes! :)
  10. alchemy
    alchemy
    Some (all?) Canadian early Fords had a C at the beginning of their serial number. My little brother has a 1934 frame like that. But I can almost guarantee that they didn't have a Y in the middle of the number.
    But, maybe some state or weird county re***igned that number to your car. They would have made it up in their own special code. It might still be a 34 Ford, but the number is all brand-ish new.
  11. AngleDrive
    AngleDrive
    from Florida
  12. gimpyshotrods
    gimpyshotrods
    Only pictures will tell the tale.
    Whatever it is, it is about a half-century before the VIN became a universal standard.
    In that era it was just the production numbers, and they were sequential, based on the order that engines came out of the engine plant.
    Also, where is this number located that you are reading?
    5window and X38 like this.
  13.
  14. AngleDrive
    AngleDrive
    from Florida
    Canadian ch***is which I know nothing about their serial number procedure.
  15. gimpyshotrods
    gimpyshotrods
    That is an original style number. I say style, because the stamps are reproduced. You would need to pull the body to see the other two.
    That said, this appears to be a Canadian-production vehicle. Ford had a plant in Windsor, Ontario then.
    As for further identification, this cannot be done from the serial number. This is not a VIN. Decodable VINs did not exist until decades later.
    The only thing that will help you from here on out would be photographs of the vehicle from all sides. Depending on what it is exactly, and given slight changes, folks here can get you year, model, and even the approximate position in the production run.
  16. gimpyshotrods
    gimpyshotrods
    Some additional info about serial number locations can be found here:
    http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
    As a some-time vehicle verifier for the State of California, I would say that the number is an original, as the surrounding metal is uniform, and appears undisturbed.
    I am ***uming that you have no paperwork on this, or you would not be asking these questions.
    For some additional clarity, the p***enger cars and light trucks used the same frame. Each of the p***enger car body styles all used the same frame. In short, it is not possible to tell what it was if it does not have a body on the frame, or you have no matching paperwork,
    Only the big trucks have a different frame, and you will know when you see one. They are hefty.
    XXL__ likes this.
  17. alchemy
    alchemy
    I’d say the 13 is really an 18. Ford’s 3 had a point in the top corner. That would be in line with Ford’s usual model number for V8’s of that era. The Y really throws me though. They used a hyphen, or sometimes a short double headed arrow after the 18. But I’ve never heard of a Y. Can you lightly sand it to confirm what that character is?
  18. rusty valley
    rusty valley
    I had a Canadian 34 frame, the C and the numbers are quite a bit bigger than American stampings
  19. alchemy
    alchemy
    Hey Rusty Valley, did you sell your frame to an Iowan, and deliver it to his hotel during Back To The Fifties?
  20. gimpyshotrods
    gimpyshotrods
    This is not a 3. This is an 8. The heavy bias in depth toward the right indicates that the stamp was tilted when it was struck. The upper right is curved, and not swept back, like a Ford 3 is.
    On the left side, there is too much wrap around for it to be a 3.
    Contrast this to Ford 3's:
    5window, mike in tucson and XXL__ like this.
  21. Beanscoot
    Beanscoot
    Try drying the area and getting a better picture. The wet surface acts as a mirror.
    From the poor image it looks like the Y could be an X.
  22. gimpyshotrods
    gimpyshotrods
    Still not finding a Y.
  23. gimpyshotrods
    gimpyshotrods
    It is an inexplicable Y.
    5window likes this.
  24. Jalopy Joker
    Jalopy Joker
    ^^^ great detective work
    gimpyshotrods and lothiandon1940 like this.
  25. lothiandon1940
    lothiandon1940
    Once it's dry, toss a bit of tal*** powder on it lightly, then wipe off the excess. It will highlight the number/ letters.
  26. alchemy
    alchemy
    Regardless of the serial number, if you showed us a picture of the frame, especially the front crossmember, we could tell you the year.
    gimpyshotrods, X38 and 5window like this.
  27. rusty valley
    rusty valley
    Alchemy, no I did not sell my Canadian frame to Iowa
  28. chopped
    chopped
    Hmmm, first time poster. Odd request, not heard from again. Anyone else seeing a pattern here? Or has cabin fever got me?
  29. gimpyshotrods
    gimpyshotrods
    Maybe, maybe not. There were two posts, and they were spread apart.
    Not everybody lives on this board 24-7.
