Technical ***February 2022 Banger Meet Thread - Heart Has 4 Chambers***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 1, 2022.
  1. Jiminy
    Jiminy
    Link to previous month: January 2022
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there maybe more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    edfueler and chryslerfan55 like this.
  2. 62pan
    62pan
    Checking in and waiting for spring.
  3. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Checking in, loving winter and not sweating...
    luckylou, Old Dawg, guitarguy and 2 others like this.
  4. denis4x4
    denis4x4
    from Colorado
    Ready to snow here again.
  5. V4F
    V4F
    from middle ca.
    way to much COLD north wind here
  6. noboD
    noboD
    Snow ****s.
  7. Dustyp489
    Dustyp489
    Checking in, got to check on my Banger pickup and plan to get the leaks stopped in the carbs. Still snow on the ground and cold.
  8. burl
    burl
    from Minnesota
    Checking in for the month getting stuff done every week.
    Cut down the pistons so there flush with the deck.
    Made a custom gauge panel.
    Started working on my doors. Glad i have doors but these are going to need some work.
    Have to make something for my fire wall with the engine set back so far.
    Parts are getting to to get think i have the last set of 60 over rings in the country. Debating to machine for larger valves on this temporary engine. banger 1.jpg gauge panel.jpg door.jpg firewall.jpg
    mctim64, blgitn, barrnone50 and 8 others like this.
  9. Deeluxe
    Deeluxe
    from island
    Hey Ya'll. Thought you might dig my 1924 Buick 4 cyl. I have been building this car for the last couple years. Fired it up for the first time at Christmas.
    Thanks for all the inspiration along the way! 20211102_140855crop2.jpg 20220118_115336crop.jpg
    mctim64, Carter, 282doorUK and 16 others like this.
  10. this buick is a nice looking engine
    winduptoy likes this.
  11. Crazydaddyo
    Crazydaddyo
    Starting my first Burtz block build.
    20220131_213428.jpg 20220131_213443.jpg 20220131_213457.jpg 20220131_213507.jpg 20220131_222654.jpg
    282doorUK, mctim64, Jeff34 and 15 others like this.
  12. Russ B
    Russ B
    I got my Burtz block last week, starting to order parts, and figuring out who can do what I don’t have sufficient tools or equipment to do. A lot of studying for me to do.
  13. Tribalmonkey
    Tribalmonkey
    Checking in from Maryland. Digging into Ratty, the rusty roadster. Jim Brierley ‘C’ grind cam on the way along with a few more upgrades- Snyder 6:1 head, lightened flywheel, Mallory Dual Point, 39 trans… FF4069DB-4F9D-4461-A124-202F29DFDBD9.jpeg FC0ABF30-0BCB-4B7D-992F-942513FAE90D.jpeg
    Jet96, Old Dawg, Dustyp489 and 6 others like this.
  14. winduptoy
    winduptoy
    Dropped into Reds Headers the other day. Victor was out sick so missed him
    mctim64, Old Dawg, Jet96 and 4 others like this.
  15. burl
    burl
    from Minnesota
    All this talk about burtz blocks here's a 5 main engine direct from the factory. I should probably do something with this some day. Should put a Dodge in one of my Dodge cars haha fast four.jpg
    Deeluxe, mctim64, Jet96 and 7 others like this.
  16. Kevin Pharis
    Kevin Pharis
    from Califunny
    My new Winfield S-B went on the flow bench today... 153 cfm!!!:D
    BCCHOPIT, Carter, blgitn and 18 others like this.
  17. burl
    burl
    from Minnesota
    winduptoy and Dustyp489 like this.
  18. steve hackel
    steve hackel
    How soon before the New Winfields hit the open market Its been around 50 years since I've owned one (pair) but even back then, they were well used and abused and missing only a "FEW" parts.
    The silent majority is patiently waiting.
  19. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Got a question... To those who have done a FSI conversion and the guys who have done a B dist conversion... Worth it from the stock A dizzy?
  20. moving over to a cent advance dist is a must, at least as I see it.
    I just did one for myself, used a mallory dist from a marine application, machined to fit and did a simple curve change.
    personally, I like the points but whatever blows your skirt up
    John
    winduptoy, ottoman, Old Dawg and 2 others like this.
  21. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Good to know... I am a points guy also... Thanks for the input.
  22. brjnelson
    brjnelson
    Yes its worth it, I would never go back to stock A, after running a Mallory.
    I also am happy with points, I have pertronics in all my other old cars, but on my A with a weak generator, the electronic hall effect thingy did not like low voltage.
    burl, Jet96 and stubbsrodandcustom like this.
  23. Kevin Pharis
    Kevin Pharis
    from Califunny
    Did some head scratching this morning to figure the estimated flow rates of all the S and SR model Winfield carbs. ***uming that the venturi efficiency is constant across the full range of sizes... here is what I came up with;
    I was planning on flowing the D as this may be my next target, so may be able to verify this number eventually.
    I know I’ve seen an article that breaks down the flow rates of all the V8 carbs by model, and as I recall an 81 flows bout 110 cfm, and a 97 bout 150 cfm... can’t find it now, anybody have this article handy for comparison?
    winduptoy, brjnelson, Jet96 and 3 others like this.
  24. Crazydaddyo
    Crazydaddyo
    This is what I have found:
    Small base Rochester 278cfm
    stromberg 48 175cfm
    stromberg 81 135cfm
    stromberg 97 150cfm
    stromberg LZ 160cfm
    holley 92 142cfm
    holley 94/59 155cfm
    holley 94/8ba 162cfm
    holley egc 185cfm
    winduptoy, Jet96, BeaverMatt and 2 others like this.
  26. I have to ask at what level of vacuum are these numbers taken?
    I do know that when Holley started making the 4BBL carbys, the vacuum level was changed to accommodate the old flow benches to determine the flow.
    John
    Old Dawg likes this.
  27. Kevin Pharis
    Kevin Pharis
    from Califunny
    As I understand the story... the old standard of measuring carbs was cfm at 3” of vacuum. Apparently flow benches are only capable of drawing about 900 cfm at 3”, so when larger 4 barrel carbs came out 1.5” of vacuum was used to essentially double the capacity of the flow bench
    winduptoy, Dustyp489 and Old Dawg like this.
  28. I think you are right here
    I was testing head and port flow some years ago and found a 600cfm 4bbl flowed nearly double the 500cfm 2bbl.
    Both were Holley carbs, it is still deceiving.
    After moving to injection systems, carbys seem antiquated. Don't get me wrong, I still run them.
    Keep us informed on your progress, it looks great!!
    John
  29. Kevin Pharis
    Kevin Pharis
    from Califunny
    I had a good chat with the fella doin the flow bench work the other day. I am not pretending to fully understand all of what he was saying, but was intrigued by this particular detail. It seems really odd to me that the industry standard would be to have 2 different measurement scales that don’t seem to correlate to one another...?!
    A 4 barrel carb is essentially 2 separate 2 barrel carbs joined at the hip... one would think that if the carb outsized the flow bench, it would simply be measured in halves and the volumes added...
  30. drtrcrV-8
    drtrcrV-8
    Kevin : You know better than to mix "logic" & "old cars"..... LOL!
