Customs Lincoln Y block Parts Help
Discussion in 'The Hokey Ass Message Board' started by Kato Kings, Jul 28, 2020.
  1. Kato Kings
    Kato Kings
    from Minnesota
    I am looking for a parts source for my 1957 lincoln 368. I need valve seals, valve cover gaskets, and valve cover grommets. I am pretty sure most of the parts are different than the ford y block. I am not sure. Any help would be appreciated.
  2. J_J2
    J_J2
    jimmy six likes this.
  3. J_J2
    J_J2
  4. Kato Kings
    Kato Kings
    from Minnesota
    That's it. Valve guide same as valve seal? Thanks.
  5. J_J2
    J_J2
    The seal is an additional part
  6. Kato Kings
    Kato Kings
    from Minnesota
    I have bad blowby but have good compression all the way around. definitely broken valve seals when i pulled the valve covers. will it help to just do valve seals?
  7. J_J2
    J_J2
    It might, I would have the heads gone through just to be on the safe side.
  8. J_J2
    J_J2
    Blowby is usually bad piston rings, are you sure you’re having blowby?
    Truck64 likes this.
  9. drtrcrV-8
    drtrcrV-8
    Suggest looking into Ford truck/commercial/industrial parts as these were out of Heavy F-7/F-8 trucks from '52-'64 & used the same gasket sets & shared most internal parts. If it's worn enough to need the head work you've described, I'd STRONGLY suggest replacing the timing chain set, cam bearings, piston rings & oil pump, & at least inspect the rod/main bearings for wear. Yes, I know it sounds like a rebuild, but once you do, it'll be "good" for at least another 150K to 200K!
    Bill Whitehurst likes this.
  10. jaracer
    jaracer
  11. martyk98
    martyk98
    from washington
    I like Egge for my 368 build. They are pros. Sometimes Hagen's stuff can be old. That's something you don't want in gaskets or seals. If you don't have the heads re-done with bronze guides and hardened seats you'll never know if the trouble isn't in the valve area. Makes running regular gas not an issue. Any other parts you need? I have a few. This is what I'm working on. IMG_1951 copy.JPG
  12. Where does one find Lincoln Y-block Valve Cover Gaskets? Thanks
  13. drtrcrV-8
    drtrcrV-8
    I almost always try ROCK AUTO PARTS first, either under '52-'57 Lincoln or under '52-'64 Ford F-8 truck parts, then my local NAPA parts house, SEE ENTRY ABOVE, POST #9. Also check MUMMERTS.
  14. krylon32
    krylon32
    from Nebraska
    Didn't The Rolling Bones use a Lincoln Y block in their Bonneville race car?
    bigcaddypoppa likes this.
  15. egads
    egads
    Mummert doesn't carry parts for the Lincoln Y
  16. jimmy six
    jimmy six
    Best Gaskets lists individual and a complete engine gasket set for 368’s and earlier V8 Lincoln’s. I have found them top notch for gasket on my Y-Blocks and GMC 6’s.
    egads likes this.
  17. brjnelson
    brjnelson
    I have 1 NOS truck ramhorn exh manifold I do not need, it fits the Linc Y not the Ford Y block.
  18. cobrabreeze
    cobrabreeze
    from Renton, WA
  19. X38
    X38
  20. Nailhead Jason
    Nailhead Jason
    This past year Keith was running a Killer Lincoln MEL motor, it was running good till it came apart on him during a run. We were pitted with them last year, my club brother Dustin, owns and drives the old bones racer, XFGR #532 roadster.
