Technical The Allure of the Quick-Change Rear End.
Discussion in 'Traditional Hot Rods' started by Jive-Bomber, Dec 6, 2016.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Stock Car Products made their own QCs. I have one in my shop truck. They are similar to the Frankland, Winters and several others. The center section is 3 3/4" wide and they use a deep rear cover.
    SCP also made differentials in the Tru-Track style. I've never seen a broken one.
    rod1, gimpyshotrods, loudbang and 2 others like this.
  2. Hamtown Al
    Hamtown Al
    ^^^ Thanks for the information. Where are they made... if still in business?
    The HAMB is great!!
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Originally in Richmond, VA. The company has changed and now manufactures dry sump pumps. Located in Ca.
  4. Hamtown Al
    Hamtown Al
    ^^Thanks for the quick followup... guess I have a "collectible" quick change rearend!!;):D:D
    Are there any existing threads about SCP that you know of?
    We all love good stories but at least we know the ending when we start... bummer but still glad to know!
    Thanks again.
  5. ghalperin
    ghalperin
    Thanks, I’ve seen the cable and handle that Speedway sells, but I’ve been unable to see a photo of a Halibrand 101 with any linkage or cable connected to it.
  6. sdluck
    sdluck
    The Sprint car I used to drive had a lever that attach to the torque tube and that a detent and you just clicked it back and forth.
  7. Bert Kollar
    Bert Kollar
    I went to a lot of trouble designing this spring ahead suspension so I could show off the quick change 100_1417.JPG ]
    Outback, neverdun, Hamtown Al and 3 others like this.
  8. ratrodrodder
    ratrodrodder
    from Boston
    Just curious, as I'm still learning.... how many of you with QCs actually change the gears before/after a roadtrip?
  9. seb fontana
    seb fontana
    from ct
    :confused:o_O:rolleyes:
    Outback likes this.
  10. steve hackel
    steve hackel
    In the very first posting it lists a new Winters Q.C. is available - from who, and are there different widths, bolt patterns, and early Ford / Lincoln brakes?
  11. gimpyshotrods
    gimpyshotrods
    Winters has traditional appearing axle tubes/bells that have the variety of big Ford ends.
    There are adapters to use vintage axle tubes/bells, that can take early Ford, and possibly Lincoln brakes.
    The bolt pattern is axle shaft dependent with single-float axles.
    I believe that @GearheadsQCE might be able to shine some light on that. He's my connection for Winters stuff.
  12. gimpyshotrods
    gimpyshotrods
    Some useful info about hubs, if you scored a Grand National setup:
    There are full-float GN hubs that have the 5-on-4-3/4" pattern, rather than 5-on-5". A few models have 5/8" screw in studs. There are 5/8" to 1/2" stepped screw-in studs. That combination gets you into more common wheels and studs.
    It is what I run on my quick change rear.
    Hamtown Al likes this.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @gimpyshotrods ,
    Thanx for the shout out!
    @steve hackel ,
    Yes, Winters has several brand new Quickchanges that fit our style cars and I am a dealer for them.
    I'll send you a 'Conversation'.
  14. LowBlackFast
    LowBlackFast
    Can anyone identify this thing? Looks like a Frankland center, but I don't have a clue what the bells are.. FB_IMG_1699129689049.jpg
    tractorguy likes this.
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I've not seen that one before. A couple of other QC makers had bolt on tubes but they were different than that one.
    Don't be surprised if they turn out to be Frankland. There were a lot of variants made.
    Are there any part numbers etc. on the bells or tube adapters?
    stillrunners and rod1 like this.
  16. I've seen a lot of big QC rear ends (have 3 different brands myself), but not that one! It is sort of "Big n Ugly" . . . sort of like my ole' girlfriend . . . God I miss her! LOL
    stillrunners likes this.
  17. LowBlackFast
    LowBlackFast
    @GearheadsQCE - I believe the center is A frankland. But the side bells and tube bases have me confused. No ID anywhere on the outside.
    @Bored&Stroked - lol @ "Big n Ugly"
  18. Dan from Oakland
    Dan from Oakland
    When they are too blown up to run, ya just need to find a new use for them!!
  19. gimpyshotrods
    gimpyshotrods
    Only time will tell.
    Outback, HemiDeuce, Happydaze and 2 others like this.
  20. Time moves faster in a Quickie . . .
    HemiDeuce and stillrunners like this.
  21. dirt car
    dirt car
    from nebraska
    Day light saving time-quick change!
  22. Frames
    Frames
    I don't know where to start with pictures. I like the looks of this rear end I built in about the late 70's. I used 2 left side Frankland bells with a spacer in the right side. 2 Mustang left axles. I sold it to a street rodder for $1,900.00. I couldn't believe they would spend that much money on a rear end. I am looking for a pair of these side plates Hot rod Frankland.jpg or either side if you have one.
    Outback, stillrunners and tractorguy like this.
  23. Frames
    Frames
    The old days. 301 Halibrand with truck left bells. W 8 QC center sections. JM QC 001.JPG Trans sprint 039.jpg CIRCLE TRACK STUFF 002.JPG ent to Austailia. Only had to ship it to Long Beach.
    Outback, stillrunners and Just Gary like this.
  24. Frames
    Frames
    Custom built 201 steel Q C's. Highland, Bart, Frankland and some others used a 7/8" thick steel spacer plate [ Heavy and a lot of welding ] a spacer ring and a 1/4" plate to hold the spacer ring in. I eliminated all of that with my cast aluminum extension. K I S. Used Halibrand or Speedway Motors cover. Retired foundry owner cast up the extensions. I believe $7.00 per pound. One of my tenants bored and faced off the castings. Trans sprint 032.jpg Trans sprint 033.jpg No charge. I did the drilling and tapping. I made a fixture off a Halibrand 201 to install the front bearing retainer. No mill needed just a hole saw. Built 5. Three are in my cars. Sold 2. Can you spell CLEAN?
  25. Frames
    Frames
    Now I have nine 301's. Two for the street. The rest are wide fives. 2023-10-29 12.06.42-1.jpg
  26. Frames
    Frames
    img091.jpg I used a Frankland 201 in the roadster I call " Potential contender A M B R " 50's type hot rod with a track nose. p1010062_0021_0095.jpg
  28. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I've been thinking about doing something along that line, because I want the strength of a 9" for a high torq engine.....and I don't want the noise. I've been thinking about getting an old closed drive and seeing if it could be cut off in front and a plate welded to the front to accept a 9" pumpkin. Might have to space the bells out some,and then the alum housing slipped over like yours. Just thinkin............but I have some quickchange parts on a shelf.:)
    THE FRENCHTOWN FLYER likes this.
  29. scoob_daddy
    scoob_daddy
    from Georgia
    Here’s my contribution, early-early Frankland fabricated quick change. Old southeastern dirt track stuff.
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    True
    In addition to the obvious strength, ratio choices, and aftermarket support of the nine inch axle, I think it probably does not take any more time to change ratios in a 9-incher than to change ratios in a quick-change.
    I'd be willing to bet changing ratios on my 9s is not much longer than changing ratios on a QC.
    For a 9er, drop driveshaft, pull axles, drain oil, pull center section, install new and refill with oil, re***emble axles and brakes.
    For a QC drain oil, remove cover, remove old gears, install new gears, reinstall cover, refill with oil.
    ekimneirbo and stillrunners like this.
