Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    Test fit of fuel pump and filter…
    brEad and loudbang like this.
  2. pennafxu
    pennafxu
    from Kentucky
    Solution for tight oil pressure fitting space F43574CB-5A8A-4856-9727-050F79A099E7.jpeg
  3. pennafxu
    pennafxu
    from Kentucky
    Fuel vent set up 3C243544-0D57-486A-BCCD-6BC76C705CBA.jpeg AD2C85E5-533F-4E32-BA4B-D3E1CC80B0CC.jpeg
  4. pennafxu
    pennafxu
    from Kentucky
    Finished up cowl frunk. AB538EBF-3ABB-4E5A-9E95-09AF3D11B546.jpeg 1D11BBE7-8606-4DCA-A88F-B1A8D093F9D1.jpeg D33C0656-7C12-4835-B709-B069A44ABAC0.jpeg 4F231F18-791B-4BF8-80D4-BF47AACC288E.jpeg 848B4298-80B9-4564-8628-E429554B6CB9.jpeg
    patmanta and loudbang like this.
  5. pennafxu
    pennafxu
    from Kentucky
    Cowl badge… C6252CB2-7D1B-403A-A6F2-FCF7F45BFFCB.jpeg 19782F4C-59D6-430C-B387-DACA7A6C5DA1.jpeg
    AHotRod and loudbang like this.
  6. pennafxu
    pennafxu
    from Kentucky
    Started work on gas tank mounting… 2B3C54A2-6C6A-4044-89BC-7FCF153DE5D7.jpeg 41953F60-3B91-4D8E-A639-31CF070B934D.jpeg 452BBE9C-995D-46BC-9107-8E7707472E26.jpeg C44F5E35-A78B-4C29-82FF-FEAB6464A09D.jpeg
    brEad, AHotRod and loudbang like this.
  7. pennafxu
    pennafxu
    from Kentucky
    0872542C-BD93-43CA-B419-16E9C3115989.jpeg 5EE4E8E3-3F32-4B48-AA86-DD62443676EB.jpeg Will put a 4” 90 deg brake to mount the electric fuel pump and filter… It has to be mounted 45deg… so my bends will be inventive to say the least
  8. pennafxu
    pennafxu
    from Kentucky
    Marked out holes for mounting... I have a lot of nit-picky things that need done here... everything is a nightmare. Wrong bolts, wrong tools, **** lying everywhere. Just frustrated all around. The end product will be great, but getting there will require patience, calm, time, layout, marking, measuring, cutting and executing. Right now it seems like everything is just going wrong. :mad: tempImage8L0qgS.png
  9. pennafxu
    pennafxu
    from Kentucky
    One side flange completed. A whole lot more to go with mounting points for a bunch of different sub-units... I've been using my Beverley shears! This will be a very stout structure when completed...
  10. pennafxu
    pennafxu
    from Kentucky
    Cut out these pieces to use to strengthen the sides…
  11. pennafxu
    pennafxu
    from Kentucky
    Now it’s official…
  12. pennafxu
    pennafxu
    from Kentucky
    I love stainless nut zerts… they are very stout. 79C835AB-A5D1-4AAB-A49B-8332A63E937C.jpeg 7554F4C9-ED07-4F1A-A182-FC369A026146.jpeg
  13. pennafxu
    pennafxu
    from Kentucky
    Will mount here most likely… DCFA407E-D23F-4B1E-ABF0-3A6145836C92.jpeg EE4D47DF-D7F2-47C9-9AFE-7351B5ED0926.jpeg C19F317E-0A02-4B67-BC1C-D2430BC154EE.jpeg
  14. pennafxu
    pennafxu
    from Kentucky
  15. pennafxu
    pennafxu
    from Kentucky
    Traced and cut one of the removed pieces
  16. pennafxu
    pennafxu
    from Kentucky
    Will TIG this up… But first some go fast holes… BF84DE14-2484-4F34-9FC7-C0F30F6221ED.jpeg 35D86267-4B32-4B92-AE6C-B817E730B8B0.jpeg
  17. pennafxu
    pennafxu
    from Kentucky
    I used the first one as a template. The shears cut through 1/8” plate like cheese. 032EAB46-37DF-4A4C-9A0D-28ACB615EA76.jpeg 0193ACDB-060B-475F-A422-1820487316DD.jpeg 1EA200C0-E50E-47FD-96D8-FD04F7DDC2C0.jpeg 50B161C1-B8D4-4B57-B764-9F12BF1D6139.jpeg EF9967B6-00F8-40EA-A180-2B61305B4170.jpeg
  18. pennafxu
    pennafxu
    from Kentucky
    C7357380-BEDB-47E2-BD2C-C7DE1798339E.jpeg Final product. Just rinse and repeat now!
  19. pennafxu
    pennafxu
    from Kentucky
    This is actually for my magnetic drill, but I will try it out.
  20. pennafxu
    pennafxu
    from Kentucky
    Onto the battery box. Fun little project CF70CE59-AED2-4CCC-B811-A2752E0F1F27.jpeg 3C205518-8607-4AC9-AC27-EB9A686539E5.jpeg 86474EE7-6A01-46C6-AA44-4E6D06E9FA12.jpeg 2794B95E-3406-48D5-BFDC-8161BD306EAA.jpeg 770329D2-F6DC-47D3-9FF3-C95279CC9202.jpeg ACE1A1B2-89BD-4CD2-B73A-77AE9CD31612.jpeg
  21. pennafxu
    pennafxu
    from Kentucky
    07F79C7C-46AB-4EEB-8E92-07506C2E403F.jpeg Will cut these 3 plates in one sitting
  22. Tim_with_a_T
    Tim_with_a_T
    Do you have any experience with these batteries? First time I'm seeing one. Interested to know. I had an Odyssey PC680 that others have used, and it wouldn't turn over my 10:1 SBC...... not sure if it was defective or low on charge or whatever, but I was unimpressed and hesitant to buy something like that again.... Although seeing those NOCO sizes and weights is causing me to reconsider....
    loudbang and pennafxu like this.
  23. pennafxu
    pennafxu
    from Kentucky
    Never had an issue… just make sure you get high cold cranking amps. I’m running a 6 volt starter so even easier to crank!
    loudbang and Tim_with_a_T like this.
  24. pennafxu
    pennafxu
    from Kentucky
    Here’s some more information @Tim_with_a_T
    They range from 400-700 CCA
    E4368DA9-F152-4113-8AB8-522BD3AD1789.jpeg 1555FA3B-7979-4CE9-BE88-9CBF8A8E39FF.jpeg D8112D76-CA44-4758-9E57-92A9A4EAE045.jpeg 5DFCD1FD-C3BE-41DF-BC2B-AEC9209DE979.jpeg 47FF5EB3-D6CB-4B41-9DCD-304DE5633593.jpeg B074915E-D713-4DC6-86AB-0626D749F0C3.jpeg F68C0DB3-5BB8-41A2-905E-24149DC8172C.jpeg D11C0868-839F-46B4-86E0-F74F40E97568.jpeg
    brEad, loudbang and Tim_with_a_T like this.
  25. pennafxu
    pennafxu
    from Kentucky
    I decided to get the other side in order… here it is on the brake. I had around 1/16” space to dial it in. 01A2EC98-BC1E-42D0-9BCE-B47324AAB66E.jpeg AED063BB-2A02-4AEC-BD2C-776E06E4F0E0.jpeg
  26. pennafxu
    pennafxu
    from Kentucky
    The angle was a little tricky. But I used my angled pieces for correct fitment BF783698-6EF9-470D-9E58-32B28D4D3C52.jpeg A85E0D74-F500-456F-ACEA-DEDDB9EF5EAD.jpeg
  27. pennafxu
    pennafxu
    from Kentucky
    I measured off and drew my lines. The first bend was a crisp 90 deg at 1”
    B579D1D2-DE8D-45ED-A0DD-BC62A88585F4.jpeg 05217F01-919B-4BD3-9772-6F100F896E9E.jpeg
  28. pennafxu
    pennafxu
    from Kentucky
    Back to the brake. I bent this to zero to match my angle E84DFBE3-9027-42F8-9DAB-11A949EBC4EF.jpeg D35E717D-2462-4477-9C76-D50AAF7B8AF2.jpeg
  29. pennafxu
    pennafxu
    from Kentucky
    Finished piece… I really like the crisp lines 138D92F8-1003-43B7-934A-E00016ED3DFC.jpeg 59D2A6C2-64EA-47F4-9D2C-150CFCA125A5.jpeg
  30. pennafxu
    pennafxu
    from Kentucky
    0357605E-846B-49E1-9DFF-87F399B2203C.jpeg F0D9BCF5-4B2C-4D18-AA00-625843FD7345.jpeg 1899B9AA-543A-4F79-BF6B-90704095BC2F.jpeg FB376BF6-1112-40AF-919F-78DBFCB94ED2.jpeg mock up and finishing tomorrow. Need to drill out the triangles and weld them up.
