Projects 1924 McLaughlin Buick spl. Build Notes
Discussion in 'Traditional Hot Rods' started by Deeluxe, Feb 3, 2022.
  1. Deeluxe
    Deeluxe
    from island
    Seat! Narrowed shape, shortened and re-curved sides around the wood base.
    Here it is along with some other modified floor bits, ready for rust stripping.
    You can also see parts for the drop-floor, also made of model A s****s and being narrowed to fit.
    20200716_125021.jpg 20200718_093709.jpg 20200718_111217.jpg 20201225_135739.jpg
  2. Deeluxe
    Deeluxe
    from island
    Cowl and Firewall happening.
    More s****s re-shaped...and Yes, some fresh 18 Gauge.
  3. Deeluxe
    Deeluxe
    from island
    And the Gas Tank. This little pile of crud got:
    Boiled, hammered, welded, sealed, primed, painted and engine-turned. Then cap and strap repairs.
  4. rwrj
    rwrj
    from SW Ga
    Thank you for sharing this. It's quite a thing. I'm happy to be watching.
    Stogy likes this.
  5. dirt t
    dirt t
    Thank you for letting me follow along.
    Any up dates.
    Terry aka dirt t
    Hamtown Al likes this.
  6. Deeluxe
    Deeluxe
    from island
    Greetings and thanks for all the kind words! I have found much inspiration and knowledge here, so trying to share what I can.
    Doing my best to make these posts, I am not a regular onliner.
    One or two more for today...
    302GMC likes this.
  7. Deeluxe
    Deeluxe
    from island
    So, it was now a roller with a motor. Need Body. Thus begins the real fun!
    Please keep in mind, I did all of this bodywork in a parking stall at a friend's shop. And in a tent.
    Yep, the neighbors love me....
    Anyway...Gotta turn these 1929 s****s into Speed and Beauty.
    We start with the back of a trashed 1929 Model A 4dr and two rear doors. I will try to explain the steps in following posts.
    Here I have shown the first rough fit of the new metal shapes. Still had a long ways to go.
    But I will do my best to explain the cuts.
    282doorUK, hfh, VANDENPLAS and 2 others like this.
  8. Deeluxe
    Deeluxe
    from island
    Ok, Into the cuts.
    First, more inspiration from the HAMB...
    ... there are some good ideas in this one...
  9. Deeluxe
    Deeluxe
    from island
    And then...many careful cuts.
    Everything got screwed together until the shape started happening.
    Then it all gets torn apart, trimmed up, de-rusted, riveted, welded, and primed.
    Roof removal...
    20200527_103351crop.jpg 20200527_103217crop.jpg 20200527_122931crop.jpg 20200527_122951crop.jpg
  10. Deeluxe
    Deeluxe
    from island
    I live in a damp region near the ocean, So no bare-metal glamour shots. Things must be treated and sealed Immediately around here. We will cover that later on.
    For now...
    Wheel-well removal. Cut side panels. Flip side panels. Layout for narrowing.
    20200527_103326.jpg 20200527_103311.jpg 20200527_154639crop.jpg 20200527_154624.jpg
  11. Deeluxe
    Deeluxe
    from island
    And Narrowing.
    I used careful cuts, many measurements and the factory body lines to re-align it all.
    20200527_160346crop.jpg 20200527_161325crop.jpg 20200527_161344crop.jpg 20200527_161354crop.jpg
    Note: You may have noticed my trusty steel-handle-hatchet in these pics...i use that for all the sheet metal t******* ;)
    jim32 likes this.
  12. Deeluxe
    Deeluxe
    from island
    And the start of the rear floor and channel. Much measuring, many marks.
    Just some key points. And the first mockup, figuring out placement and the channel depth.
    20200527_123626.jpg 20200601_102445.jpg 20200601_110321.jpg 20200605_180142crop.jpg
  13. Deeluxe
    Deeluxe
    from island
    Now the doors will become the start of body sides.
    This stage took many hours. Still very rough. These show...
    Cut the window frames off. Cut most of the door frame out. Flip them. Reshape the door-skin to fit the cowl shape. Make a pile of new pieces.
    20200218_152259crop.jpg 20200605_101755crop.jpg 20200608_162644crop.jpg 20200611_180908crop.jpg
    Shadow Creek and Hamtown Al like this.
  14. Deeluxe
    Deeluxe
    from island
    Then, Many more hours and situations like these...
    And I arrived at the over-all desired shape. Of course, it still had to all get torn apart again...
    I chose to do without the typical wooden framework for the body.
    My preference was a variety of interlocking and folded seams; relying on the whole shape for strength.
    Result is Very solid and light enough for two people to lift.
    20200616_110604.jpg 20200623_122454crop.jpg 20200623_145346crop.jpg 20200623_145417crop.jpg
    Time for a break.
  15. 62pan
    62pan
    Amazing you could vision a body out of that pile of sheet metal. Well done I'm impressed.
  16. Deeluxe
    Deeluxe
    from island
    Back for more adventures.
    Now that it almost looked like a car...time to tear it all apart.
    On to stripping all the parts, treating the metal with Fertan rust converter and then re-***embling, a bit at a time.
    Thus began my weeks in the 'Tent of Seclusion'.
    20200608_151547crop.jpg 20200608_151530.jpg 20200729_142724.jpg 20200724_163543.jpg
    Note: Tree stump for chopping.
  17. Deeluxe
    Deeluxe
    from island
    Additional metal work also happened now.
    Here I am figuring out the body line extensions.
    Bad photos, questionable welding, Good Times!
    20200731_135343.jpg 20200731_135332.jpg 20200801_143154.jpg Inked20200801_141649_LI.jpg
    Note: In these photos you can see the hacksaw blade I use to write down all the measurements...
    And the finishing hammer I use to keep it sharp ;)
    Shadow Creek, lurker mick and 302GMC like this.
  18. Deeluxe
    Deeluxe
    from island
    Now, I had a real problem.
    This thing was showing signs of possible Radness! It seemed I would have to finish it and see.
    More time in the tent. Grinding, body work, primer, filler, repeat.
    Paint was done using quality modern products...BUT was all applied with a brush.
    Actually, many brushes.
    20200804_140156.jpg 20200818_125545.jpg 20200819_161848.jpg 20200820_181548.jpg
  19. eaglebeak
    eaglebeak
    Greetings from Cobble Hill, BC
    You are doing a most excellent job.
    Keep us informed.
  20. Deeluxe
    Deeluxe
    from island
    Hey, Back to play! Thanks for digging on these project posts!
    More inspiration. More effort. More progress.
    So, I convinced a shop neighbor and his son to help me lift and place the body. Car Folks unite!
    All mounts line up with the factory locations on the ch***is.
    Everything sits on 1/4" rubber setting blocks. Only good vibes.
    2o'sSpecial.jpg b20200820_185826crop.jpg b20200821_163954.jpg b20201224_114701cropped.jpg
  21. Deeluxe
    Deeluxe
    from island
    Well, after a taking a moment to step back and catch my breath...
    I decided to begin all the devilish details.
    Track down bits, repair, make or modify, then stick them on with bubble gum.
    Here are some teasers.
    1924 McLaughlin Ad in 'The Goblin' magazine.
    Dash progress, gauges, drivers-floor, controls, switches etc.
    Motor accessories and wiring. Yadda.
    More details to follow.
    1924-04-skuce-chevrolet-ad-1.jpg 20210205_154630.jpg 20210208_172852.jpg 20220202_125427.jpg
  22. Alger
    Alger
    from Sacto
    As a McLaughlin I’m enjoying this build and the history lessons about the McLaughlin Buicks
    Matt McLaughlin
  23. Deeluxe
    Deeluxe
    from island
    Ok, time to continue. Glad ya'll are enjoying the journey.
    First pic, some 'Truth is stranger than Fiction' for our distinguished McLaughlin guest Alger. Glad to know you.
    And Then... Proof that my previously mentioned 'Hatchet & Stump' method is just traditional Buick action ;)
  24. Deeluxe
    Deeluxe
    from island
    And now some quick bits and pieces.
    Thanks here to Gary B. and John A. @Chevbucket for the extra parts. You guys rock!
    Horn repair and bracket.
    Model T boot-s****ers + Buick running-board stanchions+ s**** bronze = step plates.
    Tail light bracket and Exterior kill-switch.
    bu20210120_105937.jpg bu20210121_113556.jpg 20220202_131428.jpg bu20210512_144847crop.jpg
    282doorUK likes this.
  25. Deeluxe
    Deeluxe
    from island
    Take a Model T running-board, do a little origami...
    And it becomes a Battery Box.
    And the start of the ch***is wiring.
    Shadow Creek likes this.
  26. Deeluxe
    Deeluxe
    from island
    And the Driver's Floor.
    More cedar cut-offs and some br***-strap from the br***-strap store....
    Shadow Creek and lurker mick like this.
  27. Deeluxe
    Deeluxe
    from island
  28. Deeluxe
    Deeluxe
    from island
    Wirey...
    All the lights have vintage GM quick disconnects.
    I sourced the cloth wiring, ign. ballast and other bits from Brillman Co. from Mt Jackson, VA, USA
    The starter/generator took much reading and research, but was relatively simple to service in the end.
    So, Make dash light and plan. Mystery panel. Black n Red. Ignition bits and starter/generator.
    bu20211015_134543crop.jpg bu20211018_133616.jpg bu20211012_121910crop.jpg bu20220202_124317.jpg
  29. Deeluxe
    Deeluxe
    from island
    License plate bracket and light.
    Thanks to Dan L. for the old dash-light.
    First, draw dirty pictures. Then the idea is starting to fly. Add some light. And finally a 1920's AC reflector.
    bu20210208_113706.jpg bu20210208_172723crop.jpg bu20210512_144821.jpg bu20211205_134920.jpg
    Note: The toolbox on the right...is filled with old Metallica tapes.
  30. Deeluxe
    Deeluxe
    from island
    Just another bit of history. Then a break.
    A 1910 Buick with a goat on it. And a 1910 goat with 'Buick' on it.
    Louis Chevrolet was involved... Hooligans All.
    Hamtown Al and Surfcityrocker like this.
