Technical 1935 Ford B pillar repair help
Discussion in 'The Hokey Ass Message Board' started by Do it Over, Dec 21, 2021.
  1. Do it Over
    Do it Over
    from NYC, NY
    I thought I was going to knock out this quarter panel patch this morning but things got a bit more involved. Looks like the bottom of the B pillar is rotted. It's no surprise. I searched but didn't find much for my year. Anyone have pics of what this area should look like? Seems like some of the bottom of the quarter panel is missing. I'm using an EMS patch which seems close enough just not long enough at the bottom. I used the deep shrinker to pit some curve in the bottom and the english wheel to add some shape to the top. One might thing if you're going to the trouble to make dies to stamp out panels adding the correct curvature wouldn't be much more work. I'm still grateful they are available. Also don't see much to weld to at the rear of the inner rocker. Thinking of welding a length of 12ga bent at 90° welded to the inner rocker for strength as this is where I jack up on the body to lift it off the frame.
    Can the B pillar be repaired after I weld up the quarter panel? That seems logical to me as once it's cut there's nothing holding this area together.
    20211221_150438.jpg 20211221_150444.jpg 20211221_150447.jpg 20211221_150453.jpg 20211221_152900.jpg 20211221_153248.jpg 20211221_153258.jpg 20211221_153302.jpg 20211221_153310.jpg 20211221_153356.jpg 20211221_153404.jpg 20211221_153548.jpg 20211221_172809.jpg 20211221_172732.jpg 20211221_172719.jpg
  2. I would think it would be better to fix the inner rocker and the bottom of the B pillar first. Adequately brace and support the B pillar using the still installed door as reference, doing one side at a time. Although mine is a 53, the repair is very similar. EMS makes good panels, but usually require "tweaking" to fit a particular car.
  3. chinarus
    chinarus
    from Georgia
    EMS makes the B pillar inside brace - kinda pricey.
