Technical 16” Steel wheels 5x4.75
Discussion in 'Traditional Hot Rods' started by Okie46chevy, Feb 6, 2022.
  1. Okie46chevy
    Okie46chevy
    from Edmond
    Started looking for some cheap steel 16x7 wheels to go on a project car to help move and also help with mock up. Rather get a cheap set and measure correctly before I get the wheels I want.
    I thought GM had several cars with 16” steel wheels but researching shows all of those cars I thought actually only at 15” wheels. Did GM actually use 16x7 wheels? Anyone use import steel wheels and actually fit 5x4.75?
  2. MrMike
    MrMike
    Did you try the police Impalas and wagons?
    Okie46chevy likes this.
  3. squirrel
  4. Okie46chevy
    Okie46chevy
    from Edmond
  5. Okie46chevy
    Okie46chevy
    from Edmond
    Impala show 5x115mm so it’s to small pattern.
  6. Mr48chev
    As far as I know Chevrolet never offered a 5 on 4-3/4 16 inch wheel on anything before the Moriarity says "ah hell no" wide 16s came out for the wide low profile tires in the ??s Not even sedan deliveries as far as I know.
    I looked at several years on the GM Heritage archives starting with 49 the first 5 on 4-3/4 bolt pattern (48 are 6 lug) and they only had 15 inch wheels.
    Best I can say before you get ready to pony up the coin for aftermarket wheels is to get a set of 15 inch rollers and find some roller tires that are the same od as the 16 inch tires you want to run and use those to build around.
    Okie46chevy and Moriarity like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    what kind of car are you working on and why would you want 16" wheels???
    sko_ford and Mr48chev like this.
  8. Okie46chevy
    Okie46chevy
    from Edmond
    46chevy truck. I have some take off tires that are 16” so I was trying to find some cheap 16” wheels. Might have to just throw the tires away and get some cheap 15” wheels/tires as some donor setup.
    I do plan on running 16” wheels when I get it running, figured 16” would help me figure out correct offset and such.
  9. Mr48chev
    I'm going to ***ume that he wants to run skinny wheels and 16 inch Bias tires to get "the look".
    Moriarity likes this.
  10. Anderson
    Anderson
    Wouldn’t call 7” wide skinny
  11. squirrel
    if you use wheels like they used on cars and trucks in the past 30 years, the offset will be quite different from old wheels.
    Stick with old 15" wheels, unless you have your eyes on a specific 16" wheel that you want to run, and will look right on the build.
    sko_ford and Johnny Gee like this.
  12. jimmy six
    jimmy six
    WheelSmith made me two 16x5 - 5-3/4 for my LSR roadster….but you said ….
    sko_ford likes this.
  13. Mr48chev
    I missed that part, and true there. I was thinking 5 or 5-1/2 at the widest.
    I don't think that Chevy ever made a decent looking 16 inch wheel for the later rigs that had them. Normally they have a lot of holes in them but might p*** if he is planning on running vintage 16 inch full hubcaps.
  14. jimmy six
    jimmy six
    Space saver spares were 4 to 4-1/2” wide. …..
  15. Clydesdale
    Clydesdale
    Agreed, if its just for rolling around I'd get some space-savers, then you could get them 'banded' to suit size and offset down the line?
