Features The official 1935-1936 Ford (3w- 5w) Coupes thread !
Discussion in 'The Hokey Ass Message Board' started by rob-redm, Dec 17, 2011.
  1. 50DropTop
    50DropTop
    Thank you! It’s still a work in progress.
  2. Detonator
    Detonator
    from santa cruz
    Yep... Standard wide fives in front, Ford accessory "Farm Implement" wide fives in back. They're an inch wider. Hard to find now, the circle track boys used them all up. They were called "Manure Spreaders"
  3. 1lucky1
    1lucky1
    from Morgan NJ
    Let’s see some more!
  4. flamedabone
    flamedabone
    This little wayward project came back to me after a number of years. She is currently in a million pieces and will be finished summer or so.
    -Abone.
    shortypu, MO_JUNK, Just.dale and 6 others like this.
  5. ironandsteele
    ironandsteele
    I posted mine once in this thread a while back but I guess I should update it since it’s been chopped since then. Work done by Brandon at East Bay Speed And Custom.
    ironandsteele.com​
    shortypu, MO_JUNK, Just.dale and 13 others like this.
  6. rob-redm
    rob-redm
    chop looks great.... I keep getting a nudge from my buddy to chop mine... if the interior wasn't done and the garnish molding chromed ... it would happen... Fulton Feathers ! lucky guy
    ironandsteele likes this.
  7. johndee138
    johndee138
    from Atlanta GA
    36 on road to Maine house.jpg Here's mine . Skirts are at 36 dash.jpg the painters and will get trimmed like the hood louvers 36 front view.jpg 36 at Eggemoggin.jpg skirts.jpg deco lady.jpg
    shortypu, Just.dale, alfin32 and 4 others like this.
  8. hotrodjack33
    hotrodjack33
    Well, it's sorta like a coupe, when the top is up;)...and it certainly shares those same "blind spots" as a 3 Window:(
    shortypu, Just.dale, benke and 3 others like this.
  9. rob-redm
    rob-redm
    keep it to 3w & 5w 35-36 Coupes. sorry..
  10. ssffnomad
    ssffnomad
    35’ 5W , soon up for sale 61EB9B41-041D-4B16-8361-1A078C36FA84.jpeg 8ECF1DCC-CDDB-41D9-9343-8EAD8E2A8566.jpeg F74B144C-7C73-4016-8CB3-A4C7FA79A93B.jpeg BBB77292-21B3-4874-990B-F2B47AE51FCA.jpeg
    shortypu, Just.dale, 36 ROKIT and 3 others like this.
  11. Detonator
    Detonator
    from santa cruz
    Finished and now on the road... IMG_8916.jpg IMG_8917.jpg FE235181-9322-4AD5-9764-A5B20C8A2FF3.JPG Interior.jpg Engine in.jpg Trans & Hay.jpg
    rusty1, Fogger, shortypu and 21 others like this.
  12. ssffnomad
    ssffnomad
    Just starting on a 36’ 3W.
    283, T5, 9”
    Came to me with parallel rear leaf kit, CE split wishbone kit & CE motor mounts.
    Could someone please give me a measurement from front of frame back to leading edge of motor mounts ?
    Stretch 0B063E71-6098-4A68-BDE8-6D9674CEE113.jpeg E9C30D86-D8B2-43B7-8E85-DD12DB468D05.jpeg
  13. Phillips
    Phillips
    Glad this popped back up! Too bad many of the older pics are gone.
    Be careful out there...
    rob-redm, Jim Bouchard and reagen like this.
  14. flamedabone
    flamedabone
    This is the one that took kind of a detour along the way.
    But, she is all done now.
    -Abone.
  15. ssffnomad
    ssffnomad
    She left you , then came back ?
    Awesome look .
    Stretch
  16. flamedabone
    flamedabone
    Yea, kinda. I sold the car half done to a buddy of mine, but after a while, he realized he didn't have the time for a full on project, so she came back to me.
    -Abone.
  17. aw1950
    aw1950
    Can somebody tell me if the doors on a 5 window are the same dimensions as a fordor ?
    I have heard that to be true but would like some other opinions . thanks
    rob-redm likes this.
  18. Flathead47
    Flathead47
    from ontario
    You have to trim the top of the 4dr edge as shown on the attached photo
    Atwater Mike and Hamtown Al like this.
  19. rob-redm
    rob-redm
    glad to see more 35-36 Coupes... keep on posting your rides or friends ...
  20. mvee33
    mvee33
  21. aw1950
    aw1950
    OK I see , I have two door sedan doors . It looks like I have to shorten them 6-7 inches , correct ?
  22. ChuckleHead_Al
    ChuckleHead_Al
  23. rob-redm
    rob-redm
  24. ssffnomad
    ssffnomad
    B216F272-BA85-431C-96A6-1221AB2B3542.png And more than a little confused. As looking at pictures here on HAMB. Some guys have SB Chev Ch***is Engineering Mounts on top of frame, and some have them under top lip of frame.
    283 / T5 set in with CE motor mounts on top of frame for now.
    Hopefully tomorrow or Saturday morning some help stops by , so can set Body on Frame to check Engine / Firewall clearance.
    Jim Bouchard and rob-redm like this.
  25. RoddyB34
    RoddyB34
    A 36 coupe I bought when I was 16 ,,,$60 ,,complete but no motor or trans ,,,50 years ago ,,,traded out for 32 parts ,,,thought I knew good ,,,
  26. ssffnomad
    ssffnomad
    Looking for a little help.
    Starting with a 35’ Coupe , putting on 36’ sheet metal & grill.
    I have original radiator support rods maxed out . Original Radiator.
    Hood matches to Cowl and Grill pretty close .
    Car did not come with a original 36’ hood ornament. It came with a Drake repro .
    I have Drake repro hood ornament snug on top of radiator.
    Got the bottom ornament holes centered good and grill up close to bottom of it .
    BUT, the ornament holes are out ahead of grill holes by 1/4” to 3/8” .
    Have any of you have trouble with 36’ Drake repro hood ornament ?
    Any suggestions ?
    Thanks, Stretch
  27. rob-redm
    rob-redm
    Good luck on the project @ssffnomad ... I have heard of issues with the Drake Bull Nose repro's for 36's not fitting.
    It was a ***** but my guy got it to line up and fit nice finally... I'm sure the V8 Drake Hood Ornament is the same issue.. maybe someone has a tip for you here... be patient someone will chime in
  28. ssffnomad
    ssffnomad
    rob - thanks.
    BTW, your black 36’ 3W is awesome
    Stretch
  29. ssffnomad
    ssffnomad
  30. rob-redm
    rob-redm
    BTT, wow that is mile off... anyone else run into this issue..
