Hot Rods Slant Post Fordor AV8
Discussion in 'The Hokey Ass Message Board' started by Collin Benoit, Jan 1, 2022.
  1. NashRodMan
    NashRodMan
    Colin,
    Looks great already just by swapping out the frame! Good luck with it!
    Collin Benoit likes this.
  2. Collin Benoit
    Collin Benoit
    Thanks everyone for the positivity! Hopefully will have it wrapped in time to drive it in the spring!
  3. The regular sedan windshield is vertical and the slant tilts back a few degrees?
  4. The37Kid
    The37Kid
  5. Collin Benoit
    Collin Benoit
    That’s correct. They utilized the Victoria cowl.
  6. hotrodjack33
    hotrodjack33
    If I'm not mistaken, the windshield posts were layed back 7 degrees...same as a '32 Ford.
    I can't see the rear of the body enough to tell if it's a 160A or 160B...but if those are the correct fenders, it's a 160A. The 160A (Town Sedan) had a rear mounted spare, while the 160B (Deluxe Town Sedan) had dual side-mount spares and provisions for a rear mounted luggage rack.
  7. Collin Benoit
    Collin Benoit
    This is a 160A
    Stogy and lothiandon1940 like this.
  8. hotrodjack33
    hotrodjack33
  9. sometimes you get lucky and find one within a mile of your house, as is here.
  10. hotrodjack33
    hotrodjack33
    I got my body 4-1/2 miles from my house...from a local "Modal A guy" who never sells anything.
    I had to trade him a '31 pickup cab, a rare '31 wide bed pickup box, and $500 for it. Yeah, I think he screwed me, but I really wanted that body...and it was pretty much rust free:D.
    Stogy, brEad, catdad49 and 2 others like this.
  11. The37Kid
    The37Kid
    He spent the $500. but the cab and bed are most likely in the back corner of his garage. o_O
  12. hotrodjack33
    hotrodjack33
    Yep, that's EXACTLY what happened to them:(
    catdad49 and lothiandon1940 like this.
  13. Collin Benoit
    Collin Benoit
    Box is done done. Keys in the pitman arm were removed and tie rod end retapered. Zerk added. Now to replace the gears and she’ll steer!
    By the way, if anyone has any advice (or a video!) on how to rebuild one of these, that would be much appreciated!
    9E407E95-C257-4D91-964A-922E3C3F9F5C.jpeg FA66E30D-33AA-4BC1-8205-01B9CC3E485D.jpeg 9BC8324E-02C7-4E88-978C-9239979BE1F5.jpeg AE0DC618-E44B-45BB-8A51-735ED0CF519B.jpeg 3A628C85-4562-4060-918B-B394FBE09C78.jpeg
    20F6B94F-A20A-4C3C-86D9-7ED09E504D04.jpeg 5C868763-E030-446D-91E7-75C6613F69FE.jpeg
    Hank37, lothiandon1940, brEad and 2 others like this.
  14. johnold1938
    johnold1938
    from indiana
    slant post means it is a murrey body correct?
  15. The37Kid
    The37Kid
    Briggs made them as well as Ford, I read that parts from all three Slantwindow body makers will interchange. Mine is a Briggs
  16. Collin Benoit
    Collin Benoit
    Some final touches to go on the column drop, then on to the steering shaft/wheel hub fitment. C8ECA605-E338-4F99-9745-9B7A4ADB0DD8.jpeg
  17. The37Kid
    The37Kid
    Nice column drop, are you using the stock cowl gas tank? If so keep an eye on the stock column drop attachment, you now have more leverage, and it could start weeping.
  18. Collin Benoit
    Collin Benoit
    No, tank will be relocated behind/beneath the rear seat.
    Stogy and The37Kid like this.
  19. hotrodjack33
    hotrodjack33
    Nice job on the column drop...looks great.
    If you're not using the stock gas tank, a 32-34 Ford pickup dash is almost a bolt-on. You will have to cut the old tank out and trim about 3/16 inch off each side of the dash...it also matches the curve of the windshield/dash rail perfectly.
    EDIT. This dash would also work well on 30-31 Ford Victorias and A400s, as they use the same cowl as the Slantwindow Sedans
  20. Collin Benoit
    Collin Benoit
    I think I’m going to use the gas tank as a dash and housing for any electronics and battery. Need to find a dash rail though.
    Stogy likes this.
  21. Collin Benoit
    Collin Benoit
    Anyone know what patch panels I need to get for the back panel/corners? Definitely different than standard model a. Do I need to find ones for a 32??
    B61ACE4F-DDDB-4EB9-BBC1-0045AEB47571.png FF973CA1-6945-4287-BC25-6C3BC7F9B661.png E98B0DAB-9D7C-4572-A5CE-F7A1E347EB02.png
    Stogy likes this.
  22. hotrodjack33
    hotrodjack33
    Yes, the '32 patch panels are about as close as you are going to get. The "reveal line" isn't as tall as the Model A, but they can be made to work.
  23. Collin Benoit
    Collin Benoit
    Slow, but sure. Kinda getting it how I want it now. Swapped out the aftermarket axle for the old A axle that was under my T coupe. I’m going to do a little spring work and get the front end down another inch or so. E8A8823F-769F-4173-9DE3-D614643D7B9A.jpeg A3850C06-2DC3-4245-8A6C-B056F034FA42.jpeg BCF65523-DF8C-4338-8D93-3032AEA1B0C6.jpeg
    Fordors, brEad, mvee33 and 8 others like this.
  24. Collin Benoit
    Collin Benoit
    Got the front down another 1.5” or so and lost the frame horns. C8FCE107-AE16-4125-98E9-B45487CB9E5B.jpeg 5272D6FD-7F8E-447E-BE25-47EE571450F0.jpeg
    Also got a nice surprise from Muroc Manufacturing!
  25. Collin Benoit
    Collin Benoit
    Got my grille! Need to get the radiator painted and final mounted. 266CD917-61DF-4C1F-9236-080C9E6075AC.jpeg 40983D71-3B7A-4185-A8C7-ABA271D9C841.jpeg
  26. The37Kid
    The37Kid
    Great photo to help with my top chop.
    Bob
    Collin Benoit and juan motime like this.
  27. pprather
    pprather
    I like the Von Esser banner in your garage.
    The house where I grew up was on Irving Park Road, about ten miles west of the speed shop.
  28. Collin Benoit
    Collin Benoit
    Very cool!
  29. hotrodjack33
    hotrodjack33
    Hey Bob,
    Maybe these might help
    This one appears to have a 4" or 4-1/2" chop. I thought it was a little too much, and I noticed it had sort of has a high spot above the C pillar so...
    ...so I chopped mine 3" in the front, and 3-1/2" in the rear in an attempt to "soften" that high spot. It kinda worked;)
    29EHV8, brEad and The37Kid like this.
  30. Collin Benoit
    Collin Benoit
    F5D47579-E55C-4DC8-A4F6-AC2CD33617F9.jpeg 8CDB826C-A57E-49D0-9FD8-A6A560D682A4.jpeg DA8C8D80-2FE4-44CB-9E84-96C18B15128A.jpeg 953AABD0-1ED1-4B5E-95C1-B30C13CC3ECD.jpeg Measure once, cut four times.
    brEad likes this.
