Technical 891/365 Bellhousing Differences
Discussion in 'The Hokey Ass Message Board' started by old.hot.rodder, Feb 7, 2022.
  1. old.hot.rodder
    old.hot.rodder
    Made a mistake and bought a used truck bellhousing as a spare for my 59 Corvette (mine has a crack). It is a truck bellhousing #3815891 and my car uses 3733365. Can I use it on my Borg Warner early T-10? The Hole and trans. bolt pattern seems the same. What might other differences be? Thanks
  2. redo32
    redo32
    The truck bellhousing takes a different motor mount that only has one bolt, the p***enger car has two. I've never done it, but have been told you can drill and tap the two holes. Everything else is the same.
  3. old.hot.rodder
    old.hot.rodder
    hanks, I w
    I will look into this. Thanks
  4. squirrel
    the lower transmission to bellhousing bolt holes on the truck bell don't have threads, but you can put a nut inside, and use a longer bolt.
  5. Mr48chev
    For show and tell purposes this guy claims this is a 56/58 Corvette bellhousing.
    1956-58 Corvette Bell Housing, 373365b(s2) | eBay
    I'd say you could redrill the truck bellhousing for the mounts.
    Truck being the one above and Car/ Corvette being the one below.
  6. Mr48chev
    Yuppers, true there. you run a bolt down though the bellhousing, through the upper half of the mount, through the crossmember, through the bottom half of the mount and then put the washer (s) and nut on it.
  7. old.hot.rodder
    old.hot.rodder
    Things are looking good here. Thanks
  8. old.hot.rodder
    old.hot.rodder
    I was worried about the depth being the same. Thought the truck might have a different depth than p***enger car/truck?
  9. squirrel
    chevys were really good about all being the same depth, all the transmission input shafts were the same length, cars and trucks from 55-90s on the V8 and straight six.
  10. 427 sleeper
    427 sleeper
    Doesn't the fork come out on the right side on a truck?
  11. squirrel
    only on the ones that had the hydraulic clutch.
    427 sleeper likes this.
  12. old.hot.rodder
    old.hot.rodder
    Great! Thanks
