Projects 1932 commercial grille on model A
Discussion in 'Traditional Hot Rods' started by daylatedollarshort, Feb 7, 2022.
  1. Anyone have pictures of a 1932 pickup grille on a model a ? Not sure I am going that way, but there is one for sale. Both my projects are 30/31. In lieu of pictures, advice is also welcome, my current vision is full hood, full fendered, un chopped, thanks in advance. I did a search there are a couple of pictures. Looks a little bulky to me. Maybe I can ask for a measurement top to bottom while I am at it.
    Stogy likes this.
  2. rusty rocket
    rusty rocket
    Just my taste but I think 32 truck shells are just to clunky. They just don’t have the lines and look of a car shell.
    302GMC, jnaki, Kiwi 4d and 3 others like this.
  3. I have just the opposite thought.The 32 truck grill is not as deep as a car shell.I think they look lighter.I have a truck grill on my 32 PU,and wouldnt swap for a car shell. I have seen model A"s with the truck shell. I like the look. They repop them.....800 bucks! Now the 34 commercial shell that gets used a lot is too heavy looking for my eye. Guess its just a matter of what you like.....after all, you arent building it for us.
  4. Just measured mine. 29-1/2 inches from the bottom center to the center of the Ford emblem. 31-1/2 inches to the top by the cap. the thickness...front to rear is 4-3/4 inches including the area the welting fits in.
  5. Stogy
    Stogy
    alfin32, 31hotrodguy, Tman and 12 others like this.
  6. Stogy
    Stogy
    brady1929 and stillrunners like this.
  7. Stogy
    Stogy
    https://www.jalopyjournal.com/forum/threads/1931-ford-a-v-8-roadster.1024465/
    Quoted from Thread above...
    "Mounted to the radiator is a new Brookville grill that was grafted with an original 1932 ford commercial grill. The bullnose area of the commercial grill was removed and reshaped to blend into the aftermarket grill. The insert on the grill is an original and then I stamped and fabricated a center chrome trim bar to resemble a Pines Winterfront."
    Credit to Photographer, Owner
  8. Stogy
    Stogy
  9. Yeah, thanks Stogy , my search didn’t bring that thread up. I will go look at the grille and make my decision, owning the grille is likely better than money in the bank. Then I can mock it up to see how it looks in place. Thanks Irish Steve for the measurements, I appreciate it.
  10. Stogy
    Stogy
    No problemo...Your Thread helped solidify how different the 32 Commercial is to the 33 34 grills...
  11. hotrodjack33
    hotrodjack33
    I used a '32 commercial grill on my old Sedan Delivery which started out as a '31 Slantwindow 4 door. Stock Model A hood and added slightly modified '34 pickup grill trim.
  12. Nobey
    Nobey
    sko_ford, lothiandon1940 and Stogy like this.
  13. Stogy
    Stogy
    Looks like Marilyn...and a case of the Custom gets the Girl eh!!...:D
    The Hotrods weren't all that was hot back in the day that's for sure...
    That's why every Hotrodder should have a Custom so they don't go through life lonely...:p
  14. Stogy
    Stogy
    @daylatedollarshort show us the candidate for the Commercial Grill...you have to supply the Base, Coupe, Sedan, chopped, channeled...what's the vision you have...Robert Stacks Hotrod might have even been prewar, was it?
    Nobey, brady1929 and lothiandon1940 like this.
  15. banjorear
    banjorear
    Most important, if you go the '32 shell route, is to get the lines right. Too many '32 shells on A's sit too high and don't look right.
    Stan Back, hotrodjack33 and Just Gary like this.
  16. sloppy jalopies
    sloppy jalopies
    IMO... everyone and his brother run car grills... be different run the comm... speshly if it is a good deal...
  17. hotrodjack33
    hotrodjack33
    That's a good point. I had to trim about 1-1/8" off the bottom sides of the grill to lower it and get the lines right.
    Tman, Budget36, chevyfordman and 5 others like this.
  18. Nobey
    Nobey
    Robert Stack ran that car July 3rd 1938, according to the S.C.T.A. program, so yes it's a pre was war car.....
    51 mercules, Carter and Stogy like this.
  19. ModelARon
    ModelARon
    Here is my 32 Commerical grill. Not sure if it was cut down it came with the car with an original 32 radiator . IMG_4588.jpeg 65716525278__6731222C-C53D-4C2D-B58C-623BB1C9B28A.jpeg IMG_4653.jpeg
  20. banjorear
    banjorear
    I've always liked the '32 truck grilles. Living in the Northeast, it was next to impossible to find a decent one do to them rotting on the lower chin. If you've got a good one, I'd use it for sure.
    Stogy and hotrodjack33 like this.
  21. I saw the grille for sale locally, car is a 31 coupe, just in the gathering/thinking stage. There is nothing wrong with the 31 grille, except that the other one showed up for sale, so many options. D9B1B6C4-ABF3-4489-A7B7-6655A2A23BC1.jpeg
    Stogy likes this.
  22. shortypu
    shortypu
  23. Likely going to see the grille next week, was anyone able to get a measurement- height- of a stock grille? Thanks.
    Stogy likes this.
  24. 31-1/2 inch from front bottom center to top at radiator cap .
    Stogy likes this.
  25. Ned Ludd
    Ned Ludd
    Something I'd like to see is the other way round: a '30-'31 AA grille shell on a '32 car. It'd have to be a specific kind of build.
    Stogy likes this.
  26. 41SpecialSSE
    41SpecialSSE
    from Chicago
    This is on a '28 phaeton that I *just* missed out buying. Huge regret and I hope it shows up again.
    Stogy likes this.
  27. 33-34 shell.
    Stogy and 41SpecialSSE like this.
  28. banjorear
    banjorear
    Correct. These look out of proportion to me on a model A. Too bulbous
    41SpecialSSE likes this.
  29. Macstoy
    Macstoy
    from Alaska
    I have a commercial grill I kinda like the look I have been thinking it is bit big but laid back a bit it fits... I have to modify the hood as was acquired from a different project someone else had.
    Stogy likes this.
  30. redoxide
    redoxide
    I have a commercial fitted to my coupe , no idea what it came off as it had some funky lower contour where the hood sides would locate . It also had the remains of some chrome plate .. I used it because it was cheap, even cheaper than a reproduction. It fits good, looks the part and was old school cheap and cheerful. Basically used what was laying around ,cheap and available at the time .
