Technical Lowering Headlights on a 1935 Ford... The Quick & Easy...
Discussion in 'Traditional Customs' started by Ryan, Mar 2, 2016.
  1. Ryan
    Ryan
    ADMINISTRATOR
    So, Keith has a '35 Ford roadster in the shop that I'll cover more on later... But this morning, he lowered the headlights and I thought I would do a quick tech piece on how he did it.
    Step 1. Use a razor blade to cut the paint around the rivets... This is done to the paint doesn't chip out when you are drilling the rivets out.
    Step 2. Cut the rivets out so that you can release the inner headlight mount.
    Step 3. Cut a relief in the bottom of the headlight just big enough to allow the bottom mount (the part that attaches to the fender) to slide into the headlight bucket.
    Step 4. Use simple hardware - just nuts, bolts, and spacers - to adjust the height of the headlights to where you want them.
    Step 5. Step back and enjoy your work. Major improvement in profile...
    reagen, Maverick1, Chavezk21 and 9 others like this.
  2. louisb
    louisb
    Now that is slick and so simple.
    --louis
  3. olscrounger
    olscrounger
    very nice job!
  4. Hitchhiker
    Hitchhiker
    I had to pull up a google image to see what a stock 35 roadster light was at.
    I think that hints at this being one of those some people won't notice mods....and those are the best kinds.
    Just Gary likes this.
  5. ROADSTER1927
    ROADSTER1927
    Very :)Very,;) Cool! Thanks, Gary:D
  6. Atwater Mike
    Atwater Mike
    Good thinking! I pondered how to do that on my '35 flatback, but left it hanging, undecided...
    Simple operation, when done this way. (brilliant)
  7. deuce1932
    deuce1932
    from Australia
    another solution is to use Ford Pilot headlight stalks... they bolt to the fenders in the same location, only with a slightly broader flange & the headlight mounts the same as original.
    Benefit is they are just over an 1 3/4" shorter than the orig 35 stalks.
    I'm sure some of the Aussie Hambers can find you a pair..
    reagen and Outback like this.
  8. BuiltFerComfort
    BuiltFerComfort
    Will a sealed beam light still fit - will it miss the raised mount?
  9. Last time I lowered the lights on a '36 3 winder was in the 70's when I sliced and diced a pair of '40 Chevy p***enger lights and nested them in the fender valley. Wish I had pictures, but I'm sure many have seen it done - an old custom trick.
  10. continentaljohn
    continentaljohn
    Wicked cool idea thanks for sharing
  11. 38Chevy454
    38Chevy454
    Simple and effective.
  12. Squablow
    Squablow
    How was he able to cut that relief out of the bottom so cleanly, without damage to the paint? Seems like a difficult task to do with a cutting wheel or a jigsaw.
    Also, is the gap around the bottom of the bucket and the fender mount a concern? Maybe not, doesn't look like moisture will get in there and shouldn't be visible, just curious.
  13. 35cab
    35cab
    I used the same trick on my 35, also added 36 rims and lenses. One of the few jobs that went as planned. sm35.jpg IMG_5874.JPG a
  14. Ryan
    Ryan
    ADMINISTRATOR
    1. Tape, patience, and a whole lot of skill with one of these:
    2. No, it's pretty tight... If anything, it gives a place for the water to drain?
    That's a gorgeous car...
    reagen likes this.
  15. 35cab
    35cab
    "That's a gorgeous car..."
    Wow, a thumbs up from the boss, made my day ! Thanks Ryan.
    I might never clean this keyboard ever again.
    The car, like myself, is still a work in progress.
    Sancho likes this.
  16. lewk
    lewk
    from Mt
    Thanks, this is on my to do list and I'd made it much more complicated in my head.
  17. Love it. Plain and simple!
  18. RICH B
    RICH B
    Just got around to doing this on my lights and figured out that longer screws/bolts that replace the rivets no longer enter the headlight shell squarely; and didn't look too good. I looked back thru this and other techs and found no mention of how to fix this.
    I was using 10-24 carriage bolts and ended up bending the heads (kinda like deuce headlight bar bolts) to match the contour of the shell. I think they look better now. Found I still have to extend the cut-out a little more to aim the light up enough.
    reagen likes this.
  19. Detonator
    Detonator
    from santa cruz
    How far did you drop yours? Is it possible to roll the buckets in a little tighter to the grille? Thanks.
  20. RICH B
    RICH B
    Instead of using pricey rod couplers, I cut some 1/2" x 1/8" wall DOM pieces 1" long for the spacers, due to the angle they sit on bucket and center piece I think it is a little more than 1" drop. Looks like there is room to go more, depending on what you are using for the lighting. Looks like you could roll them in as there is plenty of room around the hood handle. The picture shows a little more room than there is as the light was kinda balancing on the stand; but should give you the idea.
  21. Outback
    Outback
    from NE Vic
    Thanks, more Pilot parts I'm ch***ing now!
  22. kennj
    kennj
  23. kennj
    kennj
    Thanks for the thread, looks fairly easy
  24. brigrat
    brigrat
    from Wa.St.
  25. pprather
    pprather
    Following on @brigrat above, the headlight mod is about half way down page 15.
    brigrat likes this.
