Technical mysterious thing in my engine bay
Discussion in 'The Hokey Ass Message Board' started by miky2001, Feb 10, 2022.
  1. miky2001
    miky2001
    from houston
    i see this mysterious thing in my engine bay, can someone tell me what it is?
    thanks in advance.
    chryslerfan55 and dana barlow like this.
  2. Baumi
    Baumi
    That´s a ballast res***or for your ign coil. Usually drops the voltage to around 9V´s whenthe engine is running and has a byp*** to provide the full 12V during cranking and startup...
  3. Budget36
    Budget36
    ^^^^Don’t listen to him, that’s your flux capacitor.
  4. 57 HEAP
    57 HEAP
    If it's bad, the engine won't start/run.
    loudbang, Baumi and VANDENPLAS like this.
  5. down-the-road
    down-the-road
    Yes, ballast resistor for the ignition circuit. It might also be part of the flux capacitor circuit for those times when you are traveling precisely 88 mph and trying to catch the energy of a lightning bolt to go back to the future!
    When my ballast resistor went bad the engine would start, but die as soon as I released the key from the start position. The ballast resistor is not in the circuit when cranking to start the engine. It is in the ignition circuit when the key is in the run position.
  6. NashRodMan
    NashRodMan
    Keep a spare in the glove box cuz they do go bad at the most inopportune time?
    mr57, 550Coupe, Ford52PU and 3 others like this.
  7. down-the-road
    down-the-road
    A neighbor had a spare mounted to the firewall so he could just move the wires over and get back on the road!
    WalkerMD, 49ratfink, WB69 and 4 others like this.
  8. brading
    brading
    These work with a ballast resistor coil which normally runs at around 9V and 12v at engine start. The idea is that you have a fatter spark at start up. If you run a ballast resistor coil at 12v all the time you will burn it out
    chryslerfan55 and down-the-road like this.
  9. Budget36
    Budget36
    Why are you repeating things I told you next year?
    theHIGHLANDER, clem, 1pickup and 13 others like this.
  10. hotrodjack33
    hotrodjack33
    Hooked up a Flux Capacitor to my microwave...and my burrito disappeared into the future...ate a ham sandwich instead.
  11. Budget36
    Budget36
    Jack, that’s NOT ham, see a doctor immediately!
  12. 325w
    325w
    Don’t touch one after the engine has been running for a while. They get really!, Hot.
    Yes I did.
    clem, chryslerfan55 and 427 sleeper like this.
  13. hotrodjack33
    hotrodjack33
    LOL, ya know Mike, coulda been ham...coulda been cheese...once them slices get all fury and greenish, they all look (and taste) alike:eek:
  14. rusty valley
    rusty valley
    That one looks like OEM from an early import car. They rarely fail.
    Tman likes this.
  15. miky2001
    miky2001
    from houston
    ballast resistor for my ign. coil.
    can i eliminate it? i am running hei distributor, there is no "coil"
    thanks, and forgive my stupidity!!
    chryslerfan55 and Deuces like this.
  16. fordflambe
    fordflambe
    Be very, very, careful..........You are giving away your age...............
    Budget36 likes this.
  17. Deuces
    Deuces
    Don't sweat it Miky!!!!.... These HAMS on here like to joke around.....;):)
  18. Boneyard51
    Boneyard51
    Yes you can and should eliminate it if you are running an HEI. The HEI needs a full 12 volts to operate right and likes a 12 gauge wire!
    Bones
  19. The best thing that ever came from a Dodge !!!
    VANDENPLAS likes this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you dont have a coil , how do you fire the plugs ?
  21. PhilA
    PhilA
    You call them into your office and give them the news.
    theHIGHLANDER, X-cpe, clem and 13 others like this.
  22. Mr48chev
    Snagged from a Brit car site but the diagram explains things well.
    Note that the resistor is in the wire from the switch and the red wire is the resistor byp*** wire from the solenoid. Ballast resistor circuit.jpg
  23. Budget36
    Budget36
    I’m guessing coil in cap, vs external coil.
    OP is just finding his oats, so to speak.
    PhilA likes this.
  24. PhilA
    PhilA
    Personally I would be more worried why there is a random piece of bell push wire attached to it.
    My guess is starter byp***.
  25. gimpyshotrods
    gimpyshotrods
    That's for the pro-theft switch.
    VANDENPLAS and chryslerfan55 like this.
  26. Fabulous50's
    Fabulous50's
    from Maine
    Accept that is Lucas....nothing they make ever works! Ask and British car owner, Bosch all the way!
    Jibs and Baumi like this.
  27. gimpyshotrods
    gimpyshotrods
    Hey now, come on! The smoke that they made worked just as good as any other smoke!
  28. 64 DODGE 440
    64 DODGE 440
    from so cal
    Fabulous50's, joel and alanp561 like this.
  29. NoRust
    NoRust
    So, like yesterday it (mysterious thing) was not in your engine bay, and NOW it has just appeared today. That is totally freaky. Close the hood, maybe it will will just go away on it's own. If it is still there tomorrow ......
    ottoman likes this.
  30. Harv
    Harv
    from Sydney
    Do I have to be an Alliance Member to get a HAMB sammich? :D
    Cheers,
    Harv
