  1. HEMIDAV
    HEMIDAV
    from FL.
  2. HEMIDAV
    HEMIDAV
    from FL.
  3. HEMIDAV
    HEMIDAV
    from FL.
  4. HEMIDAV
    HEMIDAV
    from FL.
  5. HEMIDAV
    HEMIDAV
    from FL.
  6. HEMIDAV
    HEMIDAV
    from FL.
  7. HEMIDAV
    HEMIDAV
    from FL.
    Thank you Echo Ed, I'm glad you enjoy them!
    36 ROKIT, Keith C, loudbang and 3 others like this.
  8. jimmy six
    jimmy six
    Standard issue bride wedding gift.:rolleyes:.it could fulfil 2 jobs.
    loudbang and 40two like this.
  9. NHRANUT
    NHRANUT
    from Western PA
  10. Brizo
    Brizo
    from Indy
    There are so many errors and misquotes in this statement, I don't know where to start....
  11. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    well, did you read DeLorean's book? because that is what he said.
    impala4speed and loudbang like this.
  12. He also said he was framed in that drug money deal...
    302GMC, Fordors, egads and 1 other person like this.
  13. BornBuick
    BornBuick
    Most likely was and yet Porsche did pretty well with the swing arms. GM couldn't have 140,000 mile air cooled engines in all their divisions ... Why what would the sales managers say ?
    firengine103 likes this.
  14. swi66
    swi66
  15. I know this from first hand experience. The left motor mount would fail and rock the motor to the right but this would only happen under hard acceleration then drop back into place once the ignition was shut off or the clutch pushed in. The early fix was to chain the motor down (350 ci ) and the proper recall fix was to change mounts to 396 ci mounts.
    NHRANUT likes this.
  16. COCONUTS
    COCONUTS
    But are you the president of the Corvair fan club, I think not.
  17. outagas1961
    outagas1961
    my first car, a 65 impala had the recall "fix" which amounted to a short steel cable with a loop on both ends that would keep the engine from lifting if the rubber mount broke.
  18. 63 Safari
    63 Safari
    from Central VA
    loudbang and jeepsterhemi like this.
  19. Fordors
    Fordors
    This thread is well off the rails already so I’ll proceed with my question. What caused the problem with the Chevy side mounts, a system in use since 1958? Was there a design change, or maybe the rubber composition was modified, I don’t recall a reason being given.
  20. jimmy six
    jimmy six
    Do t know, but here on the HAMB they always seem to be Dodges...
    Lil32 and '28phonebooth like this.
  21. jimmy six
    jimmy six
    Chrysler
  22. Vincent Palangio
    Vincent Palangio
    Tag Carsten, This is a 1931 Willys-Knight sedan.
  23. Deuces
    Deuces
  24. HJmaniac
    HJmaniac
    Okay, what about the one on the right?
    impala4speed, Deuces, Lil32 and 7 others like this.
  25. Witchhammer
    Witchhammer
  26. Witchhammer
    Witchhammer
    1923 - SW 5th Ave. & Yamhill St.
    tr_rodder, Deuces, RMR&C and 6 others like this.
  27. Witchhammer
    Witchhammer
    Popular Mechanics September 1952
    Deuces, 63 Safari, RMR&C and 8 others like this.
  28. 65pacecar
    65pacecar
    from KY, AZ
