Hot Rods '35 3 Window, Damn Right it was a Good Day
Discussion in 'The Hokey Ass Message Board' started by lewk, Apr 10, 2016.
  1. 33Doll
    33Doll
    Are you just wire wheeling? Or are you using so sort of acid wipe in addition?
    I have to do do the same thing to my floor, and structure.
  2. Lou39
    Lou39
    from Cedar, MI
    Late to the party. Great work. I had a '36 3 window from '56 to '68 and sold it to buy an airplane. Seemed like a good idea at the time.
    lewk and TagMan like this.
  3. lewk
    lewk
    from Mt
    I wire wheeled everything for starters. I sand blasted nooks and crannies. My compressor was really limited. I’ve been dipping smaller parts in vinegar and then coating them with ospho. I’ve been wire wheeling, osphoing, and weld through priming when I open up areas I won’t be able get back in later. I’ve been using purple 3m pads for stripping paint and big crusty ****. I’m getting a better compressor together so I can final blast stubborn parts before I prime the whole car.
    33Doll likes this.
  4. 34Larry
    34Larry
    Hey man, what a find. Those stock wires look so good on it, hope they are there when you, get-'er-done.
  5. 33Doll
    33Doll
    Thanks, been moving along on my project with this Corona thing keeping me home, its great, at least for me.
    Whats “ospho” is that the milky stuff that turns green then black? Thats what I have. Its. Called “conquest”
    We use it at work for rusty submerged metal.
  6. lewk
    lewk
    from Mt
    Ospho is Ospho. It’s a phosphoric acid based rust treatment that leaves a black coating of neutralized rust that you can prime over if you follow the instructions correctly.
    I’m apparently essential and still working so I’m not getting much done on the coupe. There have been a couple of waves of layoffs but I’ve been lucky. If that changes, I’ve got a stack of patch panels and a fresh bottle on my welder to make the time p***.
    33Doll likes this.
  7. Pensive Scribe
    Pensive Scribe
    Any progress on this beauty?
