Projects Bonneville XF/GMR Build
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Sep 14, 2021.
  1. cornfieldcustoms
    cornfieldcustoms
    local homless camp
    Stogy, Champscotty58 and loudbang like this.
  2. loudbang
    Man you sure work FAST and GREAT. :)
    Stogy and chryslerfan55 like this.
  3. There is a handbuilt "27 roadster" that showed up last year and was forced to run in the lakester cl*** since the body was not an exact replica. same goes with gl*** bodies, not all are clean copies of Henry Ford steel. There are actually dimensions they can check, go or nogo.
  4. cornfieldcustoms
    cornfieldcustoms
    Corre
    Correct mainly it is based on the lower cowl with and wheel well width
    Stogy, chryslerfan55 and loudbang like this.
  5. @jimmy six astutely pointed this out in a couple threads. Good advice from a veteran salt racer
  6. cornfieldcustoms
    cornfieldcustoms
    A little update on progress. F25ED493-7676-4847-926D-7609D20F20C9.jpeg 1ABFFF59-3138-4DDC-98C2-002755534537.jpeg 3FF7EA23-EE2A-40F7-8589-FC45A758A4CE.jpeg 60478BB1-86E7-473A-B734-B0033652FFF2.jpeg 5FE21602-89C5-4E99-BC9D-711EB1D83981.jpeg 5735D77C-D6EC-406B-BA38-2DBC5CD94D97.jpeg BDFA7904-575E-4E9A-8B0D-54D0671432F2.jpeg 1363ECCF-502B-4C25-A946-57F14B8C5D0E.jpeg 4DEE1F2A-C3B5-4061-9511-A1E9F6B6B311.jpeg 933D1751-49E0-4A60-B2EA-2F2AF9D42331.jpeg 31025953-0815-4296-85CE-7D4EE8DDB61A.jpeg F03E02C0-9FC9-4ADD-8491-2582F762CE82.jpeg 2439E732-4F80-4096-B65C-31BA6D03FC99.jpeg D431B9EC-7B34-4C01-9CAE-5CF1A75CD9BA.jpeg FD358BCB-7215-45C7-B611-6F948B609D32.jpeg 3FCEABE1-81C2-4218-81C5-82D88ABCB57A.jpeg F35746F3-6C5C-4C0F-A7CF-A12408674088.jpeg 87656B53-BDD7-46BE-A05B-9C03EB53F76A.jpeg D71D8796-143A-4A89-9197-A8F1ED12DAF4.jpeg
    The 39 guy, Stogy, saltflats and 9 others like this.
  7. deucetruck
    deucetruck
    from Missouri
    Just read thru the entire thread. Man, your work is amazing!! Thanks for all the pictures.
    The 39 guy, Stogy and loudbang like this.
  8. pprather
    pprather
    More nice work!
  9. cornfieldcustoms
    cornfieldcustoms
    thanks guys
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Do any builders put an outward rolled lip on the bottom edge, similar to dragsters, funny cars and NASCAR stockers to both strengthen the lower edge and restrict the inward rushing of air under the car?
    alanp561, Stogy and loudbang like this.
  11. cornfieldcustoms
    cornfieldcustoms
    I am going to build a splitter for front, just haven't done it yet. i wanted to so a separate splitter so size and shape can be changed with out changing the nose itself.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  13. Yes, some do.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Those nosepieces are fragile enough as it is, what with loading/unloading issues, folks tripping over them, hitting debris, and just plain driver negligence. I have a couple nosepieces for mine, both of which have taken a few battle scars as evidenced in my pic. The lip gives it some structure.
  15. cornfieldcustoms
    cornfieldcustoms
    Worked on more of the roll cage cowling tonight DCFAB84A-0834-4779-A972-7A13D363208D.jpeg 05F193AC-5227-4AA4-AEA0-9AE511D32536.jpeg 7EBD717A-58B4-46CF-B7CB-71859791C842.jpeg F2900AC4-FCF0-4805-9788-C1E6477DC3D8.jpeg
    bymanr, The 39 guy, alanp561 and 10 others like this.
  16. The aluminum work looks great!
  17. Rynothealbino
    Rynothealbino
    Very awesome work. Can I ask the purpose of the setback drivers compartment? I know a lot of the roadsters are setup that way. Is it more of a packaging thing or a center of pressure / aero thing?
    Speaking of packaging is the drivetrain centered ahead of the rear end, or is it also offset? Looks pretty centered & straight in your overhead shot.
  18. jimmy six
    jimmy six
    SCTA Rules allow it in modifieds and gas/fuel roadsters. Driver must be in front of the centerline of the rear axle. Reason to do it are obvious.
    Stogy, Tman and loudbang like this.
  19. cornfieldcustoms
    cornfieldcustoms
    engine and trans are centered due to no room to offset, right now each head has about an inch of clearance between them and the hood sides. sitting that far back allows the driver to be in more of laid back position and get down and out of the air
    Tman, loudbang and Stogy like this.
  20. cornfieldcustoms
    cornfieldcustoms
    A little more aluminum work from this weekend 6F1E03CF-EF04-4462-9D43-1EB53DE77D36.jpeg 47377011-D1A5-4AD4-8D80-8EAC4173576E.jpeg 5DC6C625-5608-41CD-BD78-D16CF3706E47.jpeg FD0D6286-7D76-4725-92CF-1055DC8A2CEE.jpeg E4811E03-E5B6-420D-8781-8FEF536C2A68.jpeg F85A43F4-889D-40DA-839A-695AE50B0436.jpeg 15C3957D-D409-460B-AAFE-B7742F4EDD2A.jpeg 8ED5FD14-AA13-409F-9A39-33234C32A722.jpeg 538E6771-EC37-4709-9ED6-5418B657CEF8.jpeg 93E8B9F9-10D1-45F0-80FD-4EF90735D0FB.jpeg 99AA726E-ED6E-475D-9696-296490469BCB.jpeg E39A680A-C9E0-4E1D-8A34-E887968EFD1B.jpeg 717225AA-9F47-4327-9D56-00B1C46704D5.jpeg
  21. Stogy
    Stogy
    The similarities of this to WW11 aircraft construction are hugely evident in your crafting of this masterpiece of speed @cornfieldcustoms...a joy to witness...A little Corn makes a day much brighter...;)
    alanp561, loudbang and Just Gary like this.
  22. y'sguy
    y'sguy
    from Tulsa, OK
    Great to see all the fine workmanship. I like the structural braces under the skins. Are they designed with the scallops and openings to be more flexible to form and shape? If not, they look cool as hell, even tho when I saw a peek at them I thought, "now…he's just showin' off!?"
    Keep up the craft.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The man who works with his hands is a laborer.
    The man who works with his hands and brain is a craftsman.
    The man who works with his hands and brain and heart is an artist.
  24. cornfieldcustoms
    cornfieldcustoms
    Thanks man
    thanks. There is no real benefit to the holes and scallops when it comes to the shaping process. All the shaping was done first then holes punched and edges scalloped
    y'sguy, Stogy and loudbang like this.
  25. larry k
    larry k
    Super work on those saddle curves around the bars , that is the hardest parts for me make and make fit flat like you did ! That damn metal just don’t want to bend both ways at the same time ,you sir are a true master !!!
  26. y'sguy
    y'sguy
    from Tulsa, OK
    Okay good, so you were showing off. Love it. My hat's off to ya.
    Stogy likes this.
  27. cornfieldcustoms
    cornfieldcustoms
    Tonight i got the windscreen transition trimmed down and cleaned up. Also cut out some lexan for the windscreen. Left a little tall so i can trim down on the car for the proper at***ude C48209C7-6556-4D2B-9909-171BE1F9854C.jpeg B08BBEDB-E385-477E-ACCB-34A2B80751B9.jpeg CFC4C26C-3BA1-47D7-AC64-A84BBBC79DC1.jpeg BB75B515-0E2B-47D2-AA7B-89CAE6BE6DBC.jpeg 00060334-06B2-495C-AB61-1592C79ACB1F.jpeg
  28. Stogy and loudbang like this.
  29. cornfieldcustoms
    cornfieldcustoms
    Thanks man
  30. alanp561
    alanp561
    A friend just down the road from me is in the process of building two experimental airplanes. Ribs in the wings and fuselage stiffeners are done the same way as you're doing with the structural skin braces in order to reduce weight. In your case, it may not be much but every little bit helps, right?
