This has an original Henry steel body. 1973 350 cid Chevrolet small block engine that has been totally rebuilt. Also it has a T5 Borg Warner transmission and totally rebuilt Ford 9" rear end with 3:89:1 gear ratio. Car has very nostalgic Hallock windshield which they use in race cars way back then. Rear axle has been installed with 1936 Ford joints and a rear leaf is from 1940 Ford. Front has an dropped front axle and 1946 Ford hydraulic brakes. Steering is from1934 Ford and steering column from 1951 Ford. It has 1932 Ford front grille which has been cut 3,5 inches to fit the car better. Fuel tank is in trunk and also a battery. It still have a plenty of space in trunk. Tires are bias ply tires with Kelsey Hayes wheels. It has a dual exhaust pipes, not very loud sound. A real fun car to drive!! Works very nice! Engine mounts and trans adapter has been built the way that if someone wants flathead into it, it is an easy swap to do. Car locates in Finland, Europe. Will assist with shipping worldwide, at buyer´s expense. More info via pm or by e-mail: pistons49@gmail.com
