Projects 34 3W my way
Discussion in 'The Hokey Ass Message Board' started by Xman, Sep 24, 2013.
  1. Xman
    Xman
    Some more recent pics Slow progress but steady. I have the steel B pillars done, the rear frame horns flipped, and the rear spreader bar rolled, and tack welded in. I have a roof filler sent to Chip Quin in Pheonix for louvers. And OfCourse the chop has begun. 100_1393.JPG 100_1392.JPG
  2. j hansen
    j hansen
    Looks really good!
  3. coupe33
    coupe33
    I really like the chop! Are you eye balling the chop or are you doing it by angle? I also like the look of the wide five rims,
  4. Xman
    Xman
    I like it about an inch more in the front than the back. I just cut it till I like it.
  5. coupe33
    coupe33
    Just asking because sometime next winter I will try to change my 3 w. It has a 4 inch regular chop but I want to angle it back and keep the windshield at 6 inches.
    Xman likes this.
  6. Xman
    Xman
    100_1406.JPG 100_1409.JPG I had the 6 in chop about half done when I got the stupid idea to take another 2 inches out. So back to the drawing board. It will start to take the look when I get the door tops in. I have the roof insert panel in Pheonix with Chip Quin getting the louvers done. That will help the final look. Rear window was 4 in and now 3 inches.
  7. panhead_pete
    panhead_pete
    Holy cow Xman, no going back now. :)
  8. DaveyJonez
    DaveyJonez
    from Houston
  9. Xman
    Xman
    Got a little more done on the chop. Must say, taking this much chop is creating issues I never ran into with the 4- and 6-inch chops I've done in the past. Bought an english wheel in order to make the skins above the A pillar. Just started fitting the door tops.
    Kreepea_1, lo c dan, Tim and 9 others like this.
  10. HotRod33
    HotRod33
    That looks pretty cool.
  11. Xman
    Xman
    Not working on it to hard but have made some progress. Got the roof panel welded in, the trunk lid and hood louvered, engine is ***embled with Navarro heads and intake. I'm getting ready to put in a floor section forward of the B pilers and mount the new Schroeder cowl 100_1450.JPG 100_1452.JPG 100_1457.JPG 100_1456.JPG steering.
  12. Squablow
    Squablow
    Looks good, good to see a flathead in there. I like the looks of that intake too, looks like you could still get a center-mount generator on there without interfering with the carbs.
  13. Xman
    Xman
    Yes, a generator dose fit center mount. I took the gen and magneto off to lighten the engine up for mockup.
    Squablow likes this.
  14. Xman
    Xman
    I cut the front floor section out, didn't like it. Now have the new floor installed along with the toe boards and trans tunnel. I was a little concerned about how to mount a gas pedal. I came up with the idea of using one of my s**** throttles and cut it down and mounted it to the schroeder . It's going to work perfect. clears the brake pad and tunnel.
    Put it off long enough and have been working the door tops. To my mind this is the hardest part of chopping a 34 3W. 100_1466.JPG 100_1465.JPG 100_1481.JPG 100_1474.JPG
    rod1, Tman, Just Gary and 6 others like this.
  15. Squablow
    Squablow
    Coming together nice! I like the pedal mount, as long as that's a comfortable spot for your foot I see no reason not to do it like that. Space is always a factor, sometimes you've gotta get creative.
  16. Xman
    Xman
    Everything has to be moved back due to the Schroeder steering gear needs to be mounted right where the stock pedals were. The 34 3W I built before this one had the throttle pedal mounted on the trans tunnel. It was a little awkward to go from gas to brake. I'm fixing several issues like this that I had with the other one.
    oliver westlund, Squablow and Tim like this.
  17. jays41willys
    jays41willys
    from nj
    nice, i should had keep my 34 ford
  18. Xman
    Xman
    jays41willys, you are not welcome here. You know why!
    brady1929 likes this.
  19. Xman
    Xman
    Pushed the 34 outside for a couple pics. Gives me wood! 100_1488.JPG 100_1489.JPG 100_1491.JPG 100_1492.JPG
  20. j hansen
    j hansen
  21. Tim
    Tim
    from KCMO
  22. Rocky
    Rocky
    Classified Editor
    Shazam! Makes my 5 window look like a school bus! What a stunning profile!
    Tim likes this.
  23. Xman
    Xman
    Rocky, that's some school bus!
  24. Rocky
    Rocky
    Classified Editor
    Thanks. I used Steve's quarters, decklid and panel below the decklid. Had to shorten Steve's roadster quarters about an inch.
  25. DaveyJonez
    DaveyJonez
    from Houston
    Really mean looking!!
  26. Magfiend
    Magfiend
  27. Xman
    Xman
    getting the ch***is done so i can put the body back on and run the engine. Trying something a little different for me, I built the exhaust system using 3" oval SS tubing running under the frame. 100_1504.JPG 100_1506.JPG 100_1504.JPG 100_1520.JPG 100_1518.JPG
  28. rod1
    rod1
    Some fun now! Looks Great.
  29. Squablow
    Squablow
    That's lovely. I like the lever shocks up front too, not sure if I noticed that before. I have similar ones on my T.
  30. Xman
    Xman
    I ran the engine, runs gret, idles nicer. Very loud, too loud! Not going black this time. dan 34 side.jpg dan 34 front.jpg
    40 Olds, cooke, BlueNotes and 6 others like this.
