Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. saltflats
    saltflats
    from Missouri
    This one the whole back has been removed, guess it's what they call a back hafted car.
  2. You've also got a blower that you could donate to the cause :D
  3. I traded that towards a paint job:D
  4. OK, made things easier by cutting out the floor. Out with the old. But not in with the new lol, turns out, my half *** measurements were no where near being close. The 32" ladder bars are about a foot too long to go anywhere near the factory brackets for the lower links. I have a piece of 3X3 box tube that is about 3/16" wall. I'm gonna make a ladder bar crossmember out of it. I got this **** ;) but now it's time to quit for the day and go play some music!! Peace my friends :cool: 20220212_122947.jpg 20220212_134843.jpg 20220212_150257.jpg
  5. My solution, and before you start giving me ****, I still have to put gussets in, and I have braces to go from the top of the frame down to my crossmember. It works. I'm happy. Still have to make a crossmember for the coilovers and put the shock mounts on the axle. But it's rolling, and the stance is exactly what I was after. Can't put those pictures up though, my wheels cause a disturbance lol... 20220215_132828.jpg 20220215_144253.jpg 20220215_151128.jpg 20220215_155516.jpg 20220215_172450.jpg 20220215_174622.jpg
  6. Dick Stevens
    Dick Stevens
    You could cover the wheels with a little masking paper! :rolleyes: hint, hint :D
  7. I thought i would add to this G***ER build thread:p
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    is your 2 piece driveshaft going to have enough travel without rubbing inside its "tunnel" in the frame with this new stance? Just put some wheel covers over your modern wheels if you want to post pics..... hopefully you can get some cragars or something else on topic at the swap in Louisville in a few weeks....
  9. Andy
    Andy
    I remember a car at a run a few years ago. It had the ladder bars mounted just like you are doing. I have seen them fail on street cars so I was interested in how these were holding up.
    The mount to the rear axle had failed the axle housing. The mount had tore a patch out of the housing except for a section at the top where it was flexing.I was able to stick my finger in and touch the shaft.
    I was coming back from a run with a bunch a friends in their cars. The car I front of me swerved violently into the ditch and then went across the road and ended up in the other ditch. It had the same set up you are proposing. It had sheared a bolt.
    The couple and the kids were OK.
    I can explained how just adding the extra upper link will do the same thing as you are proposing but with out the danger and trouble.
    The extra link actually makes the mechanics the same as the solid ladder bars.
    You won’t have enlarge the tunnel etc!
    I have owned my original 60 since nov 59.
    I have owned three others and put at least 300,000 on them
    Tickety Boo, Budget36 and loudbang like this.
  10. bchctybob
    bchctybob
    Lloyd, you are probably going to need a stout cross member at the inside rear of the cab for a roll bar so I would make it go full width and support it well. Make some torque boxes to weld onto the new inner rockers to spread the load and bolt the outer ends of the crossmember to them. Then see if the ladder bars can mount to the crossmember nicely.
    I ran an 8 3/4 Chrysler rear end in my yellow Stude pickup with drag race ladder bars, coilovers and a wishbone. It was supposed to be primarily a drag race truck but I ended up driving it regularly on the street. I sold it to a friend and he drove it everyday with a milder motor. So traditional straight ladder bars are ok on the street just not perfect. Keep at it, looks great!
    mad mikey, loudbang and 427 sleeper like this.
  11. I still have a long way to go on this setup, but I'm not worried about it. By the time I'm done with it, all will be good. As it sits, the ladder bar crossmember is wonky as ****, but it won't be that way when it's done. Lot of work still left to do. Made a crossmember today for the coilovers, and got most of that done, somewhere in this shop is a box of 5/8" bolts! Now I have to address the panhard bar. 20220226_161755.jpg 20220226_201326.jpg 20220226_201339.jpg
  12. What's up *****y Bob :D for the most part, every model A I've built used ladder bars that I made. I drove the **** out of those cars. The only failure I've ever had was a broken panhard bar bracket, which was a ton of fun. Used a couple of borrowed ratchet straps to hold the rear centered-ish so I could make it home lol.
  13. It appears so. I wanted to run a one piece shaft, but I'm not sure that's gonna work. We'll see when I get that far along ;) and when my ship comes in, I'm gonna order a new set of the US Mags slots
    enloe, mad mikey, loudbang and 4 others like this.
  14. lippy
    lippy
    from Ks
    Don't let em **** with ya Lloyd. :D
    enloe, mad mikey, loudbang and 3 others like this.
  15. B.A.KING
    B.A.KING
    What ratio is the rear you pulled out? I may need it.
  16. I gave it to wheeldog Bruce, it was a 3:36
    mad mikey, loudbang and guthriesmith like this.
  17. enloe
    enloe
    from east , tn.
    Looking good
    Big Dog
  18. Ah Lippy, I looked around the shop today, and with the exception of my buddy Butch stopping by to have a few beers, I didn't see anybody working but me, so I do things my way. And if something doesn't work, I keep going until I get it right :D I knew I wanted ladder bars on this car from the beginning. It'll be alright
    61Cruiser, mad mikey and loudbang like this.
  19. B.A.KING
    B.A.KING
    cool.
  20. if it was my car I would Not put them on.
    I had a guy that I did a lot of work on his car & some friend
    told him to put them on............................guess what happen
    the Car was towed into my shop with the rear end hanging out of the car
    it seems he had them a little to low & cought a sewer cover on the
    street at 50 mph & it ripped the Rear end out of the Car.
    just my 3.5 cents
    live learn & die a fool
    he Rear
  21. I forgot to say that you will be in Deep do do
    when the Trunk Monkey is woke up!
    He will be ranting raving about all the Noise!
    just my 3.5 cents
  22. Lmao... thanks.
  23. mad mikey
    mad mikey
    I do not really see a problem at all with your plan Lloyd. As you said, I do things my way. My coupe runs straight ladder bar set up that has been there since the early 60,s. As you know she is raced hard and street driven , sometimes like I stole it. No problems. Now I have to get back to work on her, so you do not feel left out, get back to work.:D
  24. Lmao w***up mad Mike! Guess I should've put it on air ride so that it would have been traditional? Stock ****s ****s
  25. That was in the late 60's & early 70's
    Just my 3.5 cents
  26. Well where do I start... had the 283 sold, was gonna use that money to go buy a 327. Put the car in the shop to fire it up and have it ready to pull after the guy got here and heard it run. Surprise, about a 6" long crack behind the starter, and the freeze plugs shoved out behind the motor mounts. Probably the dumbest damn thing I've ever done. I did drop the lower radiator hose after I put the car outside, but I guess it froze before I did that. So I've been doing bodywork. Got the quarter panels done, tailgate about done, inner rockers done, rear suspension done. Now I'm waiting on another 283 block. Oh the joy. 20220306_172049.jpg
    61Cruiser, Peanut 1959, enloe and 3 others like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
  28. 427 sleeper
    427 sleeper
    :mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
    What a Gigantic kick in the Nutz!!!
    Everything else looks good though! :cool:
    Lloyd's paint & glass likes this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    man, ya gotta drain the block...both sides... taking the lower hose off ain't enough... guess you learned that the hard way.. ****s
    Baumi likes this.
