Projects AV8 seat recomendations
Discussion in 'Traditional Hot Rods' started by hotrodrhp, Feb 16, 2022.
  1. hotrodrhp
    hotrodrhp
    from Wisconsin
    Used a custom after market Teas seat in my 34 and prefer not to make that investment again. When I built the roadster I used a third row seat from a mini van. Works fine, tilts, and have it mounted on sliders but never liked the look at all. Short of building a seat per the Tardell book what have others used? Recover the seat, rebuild it? Cl***ic aluminum aircraft seats look great but can't see me sitting this old body in them for a couple hours. Ideas appreciated
    lothiandon1940 and Joe Blow like this.
  2. JWL115C
    JWL115C
    My A Roadster had a seat from a Chevy S-10. Fit well and was comfortable, adjustable forward and back, plus back cushion folded for access to space behind.
  3. NoSurf
    NoSurf
    In my coupe I have a 2nd row seat from an Aerostar mini-van.
    Joe Blow likes this.
  4. Early sportscars like Triumphs and MGs have seats that look the part and fit.
    Packrat, Almostdone and Joe Blow like this.
  5. rusty rocket
    rusty rocket
    My pops has a 28 A v8 and used tardels book as his bible. I built a seat bottom for him and everything else has upholstered in the car. In my humble opinion this looks the most traditional.
  6. Joe Blow
    Joe Blow
    Not a roadster but I have a van seat in my A coupe. Had it rebuilt to fit my ***......bought a distressed hide, to fit the era and had it reupholstered. Worked really well for me.
  7. jimgoetz
    jimgoetz
    I got a couple of school bus seats for around $10 from a guy who was building a party bus out of it. I cut the frame all to pieces and ended up using two bottoms. It's kind of crude but it fits the style of my early 60s build 27 pretty good. DSCN1108.JPG DSCN1109.JPG DSCN1110.JPG
    dmar836 and lothiandon1940 like this.
  8. 51 mercules
    51 mercules
    My 29 has a late 90's jeep wrangler rear seat. you can find them pretty cheap.[​IMG]
  9. continentaljohn
    continentaljohn
    If you have the original seat springs use them as they are very comfortable and will last for another 70 or 80 years. Some Cotton batting or foam over the spring will give you more comfort. Some new seat covers and will feel and look great. On my roadster I have original spring and change up the seat covers for a new look 736FEE92-E08A-471F-B88F-CC17B9934343.jpeg B85A6582-F1F2-4B03-8164-0D8818BD5F35.jpeg
    dmar836, lothiandon1940 and Just Gary like this.
  10. hotrodrhp
    hotrodrhp
    from Wisconsin
    Have the seat bottom platform but not the springs so I'm a bit behind the curve in this regard, thanks
    lothiandon1940 likes this.
  11. hotrodrhp
    hotrodrhp
    from Wisconsin
    Pricing out doing my present seat this week. Thank you
  12. If you have the riser you are half way there. Some plywood, some webbing and some med to high density foam and you have your bottom. No springs needed and you end up with a lower seating position that is also more comfortable. Pics stolen off google but from the HAMB
  13. missysdad1
    missysdad1
    Before you get to building your seat, have a friend take some pictures of you in the car sitting on boards, buckets or whatever else you can find to sit on. Adjust the height of whatever you are sitting on UNTIL YOU LOOK "RIGHT" in the car. Huh?
    Yep, if you are too low you'll look too "gangsta", too high and you'll look like a "****." You get the idea.
    The right "look" is purely subjective, get it to where YOU are happy with how YOU look in YOUR car.
    Then build the seat.
  14. hfh
    hfh
    from Western MA
    F765CA28-EAE4-4380-B589-7D451844EAD1.jpeg 9F157789-4645-428D-ADBC-728422D26BE5.jpeg I have really enjoyed having an armrest in mine. It has a lid and works as a glove box too. If you make it strong enough it helps in getting out of the car.
    Packrat, Dino 64, Junk yard and 2 others like this.
  15. JWL115C
    JWL115C
    You may want to visit the Glide website and check-out what they offer. I have a Glide framed seat in my 32 3-window. Seat moves forward and back, seat cushion folds for access to area under seat, and rear cushion folds forward for access to storage in back of seat. I also mounted it on a Tanks, Inc. bracket. Bracket is adjustable for height and rake.
  16. Jeff34
    Jeff34
    Tman, it's kinda hard to tell if the plywood on the bottom is inside the rim around the seat riser, or sitting on top of the seat riser. Can you tell?
  17. Typically it sets down inside the lip. I helped my old boss redo his years ago, the webbing, which we added, made a HUGE difference in comfort. I am doing the same on my 51 GMC. It also allows easy access to the storage under the seat.
  18. seabeecmc
    seabeecmc
    hfh and lothiandon1940 like this.
  19. Dino 64
    Dino 64
    from Virginia
    I used a Caravan middle seat but I found it wasn’t very comfortable. Found a pair of Mini Cooper seats on Craigslist. Much more comfortable 02B3FB14-9A44-4D91-87EC-69A79E2DB352.jpeg F731B8EE-C834-4207-BF11-8341FE71AAD9.jpeg
    Packrat, lothiandon1940 and Just Gary like this.
  20. 40Standard
    40Standard
    from Indy
    I like the Glide seats
    05snopro440 and Dino 64 like this.
  21. hotrodrhp
    hotrodrhp
    from Wisconsin
    Talked to my go to upholstery guy yesterday and he is booked out till November. More ground work ahead I guess! Oh well, guess when you are exceptional at what you do that's expected. Mmmm who do I know that has an industrial sewing machine?
  22. HOTRODPRIMER
    HOTRODPRIMER
    I used high density foam and plywood to make the seat in my '32 pickup, I got the seat setting where I was comfortable and the back I adjusted util it felt right then attached the two pieces of plywood together, I used 4" foam for the seat and 3" foam for the back, I covered it with a old heavy cotton material my mom purchased years ago, "Fruit Salad", it was only going to be a temporary deal but never got changed.
    I drove the truck over six hundred miles in one day, not recommended for a 6' 4" tall guy but the seat was comfortable, the lack of leg room was not. HRP
    dmar836, sidevalve8ba and Just Gary like this.
  23. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    "Fruit Salad, I like it. :)
    Just Gary likes this.
  24. Kiwi 4d
    Kiwi 4d
    Some of these seats look very comfortable, but only for a short guy. Maybe i am seeing it wrong but the comfy ones with the big fat back rest gobble up interior room for your legs.
  25. H380
    H380
    from Louisiana
    The back seat of a 4 door Dodge Dakota. They are split bottom and fold up.
  26. A 2 B
    A 2 B
    from SW Ontario
    I had a Dodge Caravan 3rd row seat taking up space, so removed the covers, foam and then narrowed the frame 5 1/2". This gave me a perfect fit for my channeled 30 A coupe. The back tilts forward for access behind the seat and the seat raises up for storage underneath. The back has an adjustable tilt and the seat front can be raised or lowered. I just started this project and am going to reupholster it once I figure out a simple slide set-up for fore and aft. The original was too bulky and heavy. I am going to trim the original foam thickness and build some lower density foam into the new uoholstery to try to improve on comfort. DSC07089.JPG DSC07095.JPG DSC07096.JPG DSC07098.JPG
    Packrat likes this.
  27. k32t
    k32t
    from Hog town
    [AT TACH=full]5327487[/ATTACH] upload_2022-2-24_4-0-46.jpeg glide
  28. k32t
    k32t
    from Hog town
    these are glide
  29. hotrodrhp
    hotrodrhp
    from Wisconsin
    That's probably where I will end up with my seat. Nicely done by the way
    A 2 B likes this.
  30. A 2 B
    A 2 B
    from SW Ontario
    Thanks, I still have the stock bench seat, which is not too bad in the comfort department but I couldn't get it to set down low enough and it didn't provide storage under the seat or access behind and was heavy. If I opt for a modest chop, this seat gained me about 2 inches of additional headroom. The price was right too, free.
