Hot Rods 57 FORD Build #2... Glutton for Punishment.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Oct 20, 2021.
  1. Stogy
    Stogy
    Ahhh makes sense, if you make a retractable roof why not make the hood open a little different to...that might have been the catalyst for that feature...
    Thor1, loudbang and Jeff Norwell like this.
  2. bobss396
    bobss396
    This is where multiple parts come in, like 3 pieces of the same trim section. The bad news is it takes a part off the market that someone else may need. I mark those cardboard tubes as "goes on the car" and the rest I'll eventually sell. Then there is the molding fastener/clip pile...
    Fitnessguy, Thor1 and loudbang like this.
  3. that explains why i was unable to pull the wiper switch out, its a dial that turns, ive never seen anything like this,
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes....... and on the underside of the knob.. is a very tiny set screw to hold the knob on the switch.. don't lose it!........ hahah!
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Still pounding away.....
    Got the master in and the brake/clutch pedal ***embly in..... Went easily.....
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Then.....
    Tested the 60 wiper motor,gave it a lick and a promisee as the east girls say...... All works,... had to make spacers to give it some space on the lip/ledge of the firewall.
    Did I mention this already?
    Anyhow, fits great and tested the wiper cable and switch... all gonna work nicely.
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    63.jpg 64.jpg 65.jpg 66.jpg 67.jpg 68.jpg Swung underside and started to mock up the steering.
    With steering, can't stress to make sure your idler arm, links and cross shaft are in good working order and not damaged or bent.
    All theses parts are new NOS I collected from my pal Shay at pre60's,.... All good rubber, NOS, rods ends, shafts,steering linkage, everything..... I really didn't trust old parts sitting in a junkyard since 1971.
    Anyhow.. all is just loose and mocked up.
    So I had an "Oh S@#t" moment,.....
    Before I put any steering gear together, I was noodling with the Pitman arm and steering shaft,.. turning and finding centre. I got roughly 2.5 turns left and right finding the centre. as I turned the pitman to the right.... it was hitting the header collector.(At 2.2 turns to the right)
    Ugh.... then I realized that I did not have the steering together and the shafts turn to the right and left would be much shorter.... with the gear attached.
    .........Relief!
    As well I dug out some bump stops I have and if in an emergency, you can also use hood stops as well.....
    so if I need them I can just my turns left or right.
    I looked and looked and could not find if Ford had factor bump steers(for 57 or 58)... there is a place for them. and I have never paid attention or noticed on other cars....Anyone know this?
    But...I think we are good.
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well..... also decided on a Carter 406-427-428 fuel Pump.. Picked up this Friday and I am gonna run back to the shop and install... 3/8's line....
    Carter has a golden reputation and it's all made in the USA.
    I am happy about that.
  9. RmK57
    RmK57
    I've had my Carter pump in my big block 57 for around 9 years now, it's been flawless and the car has also been deep 11's with it with no electric pump. My 1970 Boss Mustang also has the same pump, built for Ford by Carter and I finally rebuilt it a few years back after 50 years of service.
    Joe Travers, Thor1, Randall and 4 others like this.
  10. chriseakin
    chriseakin
    283 with two four barrels or fuel injection is what springs to mind, probably a single four-barrel version as well.
    Thor1, loudbang, Deuces and 1 other person like this.
  11. Maybe not useless trivia: In the Ford Performance catalog form the 60's an upgrade was going from 5/16" to 3/8" on fuel lines. On of my cl*** mates had a 67 fairlane with a 390 2 barrel engine. He swapped to a 4 barrel and went through the Ford steps. I remember him saying the fuel line was worth 500 more rpm. Also, the clutch and brake pads from 57 are the same they used for almost forever. I know that the late 80's f150's use the same pads so if you're going to the parts store for pads, that might help you. :)
    Joe Travers, Thor1, Sky Six and 3 others like this.
  12. Thor1, Deuces and Jeff Norwell like this.
  13. Jeff, how do you plan to deal with the 5/16" line fitting in the Tank?
    loudbang, Deuces and Jeff Norwell like this.
  14. bobss396
    bobss396
    I have a 5/16 line in my car, this is why I run out of power sooner than I'd like. The tank is plumbed for the same, I should have thought about this before I put the tank in.
  15. Ford blue blood
    Ford blue blood
    Jeff just found this thread! Watching the progress, looking good!
    Jeff Norwell and loudbang like this.
  16. RmK57
    RmK57
    If you haven't put gas in the new tank yet it makes for an easier decision.
  17. This 5/16" to 3/8" is something I need to address on my Hardtop as well. I also bought a new tank. I asked before ordering it if 3/8" was an option. It was not. If I remember right the pickup tube is tack welded to the bottom inside the tank. I had planned to cut open the old tank to determine the best way to put in a 3/8" pickup tube. I haven't done much past think about it. I'm leaning towards dropping a new tube strait down in the Tank just in front of the sending unit in the channel for the sending unit wire and going forward and to the Fuel line on the Ch***is. My concern is letting it just hang in the tank. With fuel moving front to back with Hitting Gears it might break off at the entrance on top thus leaving us needing a Stretcher to get back home. I don't want to end up there. Who has a better idea? Does it need to be anchored to the bottom of the tank?
  18. RmK57
    RmK57
    If it were me I'd cut the fuel line stub off flush. Drill it out, then weld a 3/8 female pipe bung in place. Then you can use inverted flare, AN, barb or whatever else style fuel fitting you decide on. If the tank has fuel in it that may not be worth the bother or put it on the "to do" list.
    impala4speed, Thor1 and loudbang like this.
  19. If you're looking at the photo with the ****** on the side of the tank, that's a 1/4" vent ****** not the fuel line connection. Fuel Line connection is actually an inverted flair seat for a flared line nut to screw into. It's flush into the tank face, nothing protrudes for the ch***is line.
  20. RmK57
    RmK57
    It's been awhile since I looked at what's back there. My 57 tank now has a sump and two 1/2" female pipe ports. But regardless of what's on there now I would modify the stock fuel outlet for a 3/8" female port. I know about the vent port and the steel line that runs up the quarter panel to the rear of the tail light panel. I'll have a look and see how big a plug I have in the original outlet.
  21. I agree with at least a full 3/8" feed out of the tank. Sounds like you did a cut and weld to a stock tank and made a gravity feed to the lines. That's not the direction I want to go if I don't have to. What's your thoughts on a siphon tube free hanging in the tank?
    Joe Travers, loudbang and Thor1 like this.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Good Progress this weekend.....
    .......tied up all suspension, put the car on its own weight, tightened the suspension to factory specs,Waiting on my front sway bar to arrive,Looking for my grease gun, to grease all points needed, and such.
    Lots of little things to do, but the next big step will be to wire the car.
    Of course running brake lines and fuel lines as well.
    As for the rear tank and the 3/8's line..... for my car.... I have adapted the fuel barb out of the tank to accommodate a 3/8's line.
    That's about the extent of it..... this is a street car and a 3/8's line from the barb to the carb will be more than sufficient.On other applications I can see the use to mess with the tank and such.... but not this 57.
    yes.. when the tank was ordered from Spectra.... there were no options on a 3/8's bung....
    Fabulous50's, Baumi, enloe and 15 others like this.
  23. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  24. bobss396
    bobss396
    Which sway bar are you using? I went with a fat 1.125" on mine.
    Deuces, Thor1, Jeff Norwell and 2 others like this.
  25. v8flat44
    v8flat44
    Man is that gonna be sweet. Another thread where my finger would fall off if I hit the "like"****ton all the time!! I LIKE IT !!!
  26. at least with these cars you have very few circuits you need to wire, even less now that you've removed the radio and clock!
    Jeff Norwell likes this.
  27. This was my first thought, then I talked myself out of it. Probably overthinking it but then I never do things the easy way. Most likely why my 57 is still in pieces. I think there was a reason on all High Pro factory Ford cars the line is 3/8" all the way from the Wet Spot.
    Thor1 and Jeff Norwell like this.
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @bobss396 ... where did you get your sway bar from?... looks exactly like the one I ordered ....
    lothiandon1940 likes this.
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Howdy Bill!
    Deuces and lothiandon1940 like this.
  30. Texas57
    Texas57
    Bob........the sway bar you posted pics of is different than the SWTbirds/Concorse sway bars made for the '57's unless they've changed) What brand is yours? maybe that's the difference. The SWT '57 bars are not bent upwards like yours. They are much straighter and the front of it actually goes below the double bracket the core support bolt mounts to. However, with that said, I don't understand how YOUR setup works with the bumper brackets. The way you have it mounted would have moved the brackets outboard by the thickness of the sway bar bracket because you sandwiched that bracket between the frame and bumper brackets. The '57 sway bar mounting brackets are located to the outside of the bumper brackets, so it does not affect the bumper bracket's position in relation to the bumper's holes.
    Deuces, Sky Six, loudbang and 2 others like this.
