Projects 1950's Tube Frame Sports Car
Discussion in 'The Hokey Ass Message Board' started by jebbesen, Oct 5, 2015.
  1. Fabber McGee
    Fabber McGee
    I was thinking about the telescoping tubes you might use a couple days ago and it dawned on me that you would probably need something to keep one from turning inside the other. My thought would be to drill holes and run a nylon zip tie through them someplace out of sight. Tough enough to hold them and soft enough to shear easily.
    Stogy likes this.
  2. jebbesen
    jebbesen
    from Winona, MN
  3. Fabber McGee
    Fabber McGee
    Yeah, that would be cleaner looking.
    loudbang, Stogy and jebbesen like this.
  4. Dave G in Gansevoort
    from Upstate NY
    One of the oval track companies, don't remember which one, makes double d tubing and shafting that fits inside for exactly this purpose. If I find it again I'll post the linl (well, I'll type in the web address, as I still don't know how to manage links...)
    BradinNC and loudbang like this.
  5. Dave G in Gansevoort
    from Upstate NY
    Boy am I dumb! Ididit has it and so does Speedway. Made for the job. Hope this helps....
  6. jebbesen
    jebbesen
    from Winona, MN
    I'm going to do a couple tests with two pieces of tubing and one of these 1/4" plastic pins. I think if I can pin two together I'll set it down and stand on it. If I can stand on it but break it by stomping I'm thinking that's about right. If it works I'll turn the head down smaller on one and pin the column. 20220218_105816.jpg
    Stogy, loudbang and Fabber McGee like this.
  7. Fabber McGee
    Fabber McGee
    Sounds like a good plan. You can add more if needed until you get what you want.
    Stogy and loudbang like this.
  8. loudbang
    If you run out of them Honda uses a bunch of them in various sizes. :)
  9. jebbesen
    jebbesen
    from Winona, MN
    Today was one of those days when it doesn't look like I got much done. My tubing for the steering column and the nos worm shaft aren't here yet. I decided to make the bushing for the lower end of the front shocks. They push in from both ends of the shock eye and tighten up between my spring shackle plates. 20220219_160317.jpg 20220219_160322.jpg 20220219_160342.jpg 20220219_160344.jpg 20220219_160332.jpg 20220219_161011.jpg
    If you've read thru the whole thread you'll remember that the front shocks originally hooked on to the front frame hoop I removed. My plan is to rebuild that hoop a little differently and have the shocks mount to the front of it instead of on the side like before. Since my front spring perch will be height adjustable, I intend to put 3 or 4 holes for each upper shock mount as well. Just for an idea how the shock angle will work out I set the cut off frame hoop back on. That way I can see roughly where they'll sit. 20220219_161112.jpg 20220219_161226.jpg
    On the rear I'm thinking I might weld the ends of some bent Model A radius rods onto the crossmember for an upper mount. The shocks will sit something like this. 20220219_161407.jpg 20220219_161315.jpg
    Or I may decide to make them height adjustable as well.
    brEad, 1934coupe, RICH B and 5 others like this.
  10. Dave G in Gansevoort
    from Upstate NY
    Nice Jeremy! Looking really good.
  11. jebbesen
    jebbesen
    from Winona, MN
    My new steering worm shaft showed up. After cleaning the cosmoline off I soaked it in some citrus rust remover to clean a little surface rust off. 20220225_151604.jpg 20220225_151600.jpg
  12. alchemy
    alchemy
    Was the citrus remover a commercial product, or something you mixed up from scratch?
    Stogy likes this.
  13. jebbesen
    jebbesen
    from Winona, MN
    I used evapo-rust. It's real gentle but works well. I think its citrus based. Ill have to look. Ive had a couple different ones but this works the best without being too aggressive. I've used it on transmission gears before too. It works super. It's slower than something like muratic acid but that has more risk of removing metal and causing embrittlement.
    evapo-rust.com
    Stogy, Jet96, UNSHINED 2 and 2 others like this.
  14. UNSHINED 2
    UNSHINED 2
    @alchemy i use a citric acid (bought in powder form) and water for light rust removal and it works well. You can usually get it at a local food Co-op for real cheap. I put about 1/2 cup in about 3 gallons of water. You can mix weaker/stronger as you need. Warmth or sunlight makes it work a bit faster.
  15. jebbesen
    jebbesen
    from Winona, MN
    Progress is being made on the steering column. I have the pieces of the interior shaft cut to length. Next I have to cut the flats to make the shafts fit into the DD tube. 20220301_220031.jpg 20220301_220012.jpg 20220301_220041.jpg 20220301_220036.jpg
    brEad, Stogy, Jet96 and 1 other person like this.
  16. alchemy
    alchemy
    Does the original shaft have a hole down the middle? Most old Fords do. If so, are you worried there won't be enough strength after cutting the DD into it?
    jebbesen likes this.
  17. jebbesen
    jebbesen
    from Winona, MN
    None of it is original Ford. Good point on that though. I considered using a piece of Ford for the top but decided the hole was too big. Upper piece is 1045 shafting, middle is Borgeson DD tube and bottom part is 39 Chevy which had a solid shaft. I think I will drill the upper with a very small hole just big enough to take a wire but nothing nearly as big as the Ford hole. They had almost a 3/8 hole. Here are some pics of the upper chunk. It'll be a light press into the tube. 20220302_074757.jpg 20220302_074811.jpg 20220302_074829.jpg
    brEad, Stogy, ottoman and 3 others like this.
  18. Dave G in Gansevoort
    from Upstate NY
    Nice Jeremy! Looks neatly done.
  19. jebbesen
    jebbesen
    from Winona, MN
    Lower shaft is done. I have to do a little hand fitting to the tube but it should work well. I have 6 inches of DD that will fit the tube nicely and the. I relieved the rest a few thousands on each side so I if it ever needs to collapse it will move freely. 20220302_191337.jpg 20220302_191523.jpg 20220302_191258.jpg 20220302_191250.jpg
    UNSHINED 2, brEad, Stogy and 3 others like this.
  20. jebbesen
    jebbesen
    from Winona, MN
    Upper column bearing. It's a sealed SKF. 20220303_064035.jpg 20220303_064051.jpg
  21. Overkill on that upper bearing but very NICE! Love this thread.
  22. Dave G in Gansevoort
    from Upstate NY
    Yes the bearing is overkill, the column I'm using has felt for the bearings, filled with grease. But it's British so what do you expect...
    loudbang, jebbesen and Tman like this.
  23. Sometimes overkill is just right!
  24. jebbesen
    jebbesen
    from Winona, MN
    Worked on the bottom shaft so it's a snug but smooth sliding fit.
    Then I drilled the upper stub shaft for a horn wire and drove it into the tube. Drilled a hole thru them so I can tap it and put 10-32 ****on head screws in, one from each side. 20220303_175919.jpg
  25. Dave G in Gansevoort
    from Upstate NY
    More nice work. You're putting me to shame Jeremy. I only got 1 crossmember made today.
  26. jebbesen
    jebbesen
    from Winona, MN
    Decided to add a magnetic drain plug to my steering box casting before final ***embly. I'm going to try running 140W GL3 gear oil in it. If that ends up leaking I'll switch to 00 grease. I have a modern lip seal on the sector shaft but the big threaded piece that holds the lower worm bearing may drip. There's no seal on those threads. I might try putting a light coat of rtv on those threads when I finish ***emble/set the lower bearing clearance. 20220304_104424.jpg 20220304_104503.jpg
  27. ROADSTER1927
    ROADSTER1927
    All of it is a great plan Buddy!:)
  28. Fabber McGee
    Fabber McGee
    The stock Model A guys over on the Vintage Ford Forum are really proud of John Deere corn head grease. I read about it a bit some time ago. As I recall it's thick and semi-solid at rest, but soon as you move something through it it becomes fluid and flows around coating everything. The advantage is that it doesn't leak out the bottom of the gear box and fill up their headlight switch, plus I think it's EP rated.
    If you're not familiar with the product it might be worth investigating.
    BradinNC, Stogy, SS327 and 2 others like this.
  29. jebbesen
    jebbesen
    from Winona, MN
    I've used it before and it's the best grease option I think. It is a pourable grease. I'm going to try oil on this one first and if it leaks out I'll drain and convert it. I think with the modern seal I have a good shot.
  30. alchemy
    alchemy
    I can testify that John Deere cornhead grease is good for your steering box.
    BradinNC, tractorguy, Stogy and 4 others like this.
