Hot Rods emergency brake
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 19, 2022.
  1. sdluck
    sdluck
    What are you guys using to apply the e brake on your stick shift hot rods?
  2. Mr48chev
    Why would stick or automatic make any difference on that?
    On my T bucket I used a pull handle park brake like you find in a lot of boxes with wheels. I can't remember what mine came out of at the time because I put it in in 1974.
    On my 48 I used the kick panel mounted park brake pedal out of a mid 70's donor car that I had s****ped out. Basically the car was there at the shop, I owned it and needed a park brake and a half hour later I was figuring out how to put the park brake pedal and cable in my truck. Outside of being mounted a tad high it worked great for a lot of years. Releasing the ****** was a challenge for a long time as I didn't have a proper release lever for years.
  3. sdluck
    sdluck
    sorry,not much room in a model A
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
    egads and RMR&C like this.
  5. Just Gary
    Just Gary
    My '28 Tudor has a Lokar E-brake centered under the driver's knees.
  6. egads
    egads
    Corvette handle[​IMG]
    mcsfabrication likes this.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    Fred used his heels...
    wraymen likes this.
  8. hemihotrod66
    hemihotrod66
    I adapted the original that came with my 34 Ford....Hooks to the cables from the Mopar rear axle... Build picture 2.jpg
    stillrunners likes this.
  9. Check out forklifts and heavy equipment lots of compact under dash units
    4F03C1A5-3A55-4210-935F-3CDD42E9F269.jpeg 4C142009-1584-4E55-82C9-6F0543F39C9A.jpeg
    PORCHE 944 and Jaguar xjs from the 80’s had handles that went in the left side of the drivers seat , once you pulled them up they would drop down to let you get in and out of the car
  10. Paulz
    Paulz
    Floor mounted handle from a popular foreign car. Starts with H ends with A.
    ekimneirbo likes this.
  11. Bandit Billy
    Bandit Billy
  12. mrspeedyt
    mrspeedyt
    a short piece 2X4 works ok.
    williebill and da34guy like this.
  13. Just adapt a standard one. Mount it slightly in front of your gear stick.
  14. lostone
    lostone
    from kansas
    I picked up a cheap import one that goes between the front buckets off of eBay for 10.00 to put into my 31 tudor.
    I'll mount it behind the floor shifter and between the bucket seats so it just sticks out enough I can get hold of it.
  15. DDDenny
    I'm using the same Corvette lever in my roadster.
    Also using one in my Nova.
  16. mgtstumpy
    mgtstumpy
    An old Gennie shifter mechanism
    mad mikey and Bandit Billy like this.
  17. evintho
    evintho
    E-brake from an '87-'93 Mustang in my T roadster.
    Randall and mgtstumpy like this.
  18. gimpyshotrods
    gimpyshotrods
    Just Gary likes this.
  19. gimpyshotrods
    gimpyshotrods
    In case you cannot find a 944 in an yard, it's forerunner little brother the 924 had the same handle.
    VANDENPLAS and Just Gary like this.
  20. da34guy
    da34guy
    The Brick @ Bako.jpg Cheap and simple
    Dino 64, mad mikey, mrspeedyt and 3 others like this.
  21. cfmvw
    cfmvw
    Friend of mine used what he called a parking brick for his beater.
  22. V8 Bob
    V8 Bob
    I'm using a Model A in the '32 and the stock '40 handle in the coupe.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    The junkyards are full of cars with all sorts of floor mounted ebrake handles ,pick one you can work with ..
  24. I use a '39 ford under dash handle, at least that is what I think it is. I mounted it under the dash as close to the door as I could get it, cable stays inside the firewall and goes down through the floor. It works good but as you know you run out of room fast in a model A and it does compete with space with the clutch when it is in the full release position, handle all the way down and forward.
  25. BJR
    BJR
    Pontiac Fiero had a very compact floor mounted one.
  26. fleetside66
    fleetside66
    I used various components, but the actual lever affair came from a junk yard Suzuki Samurai, I think...it's been some time. This interior shot was early on, but the brake works really well. I use it all the time.
    egads likes this.
  27. Phil P
    Phil P
    I used the stock lever in more or less the stock location. I bolted it to the t5 with an adapter plate.
    I wanted to say bolted it up with a "A"dapter kit:D.
    Phil
  28. atch
    atch
    When someone above mentioned Corvette I immediately thought of my '66 (that I stupidly sold 45 years ago). It had the other kind of under dash unit; a t-handled pull knob. '67 was the first floor mounted lever like what was shown. '66 still had the "old fashioned" kind. Has anyone used the under dash pull cable? Seems like it would use the least amount of real estate of any.
    As for my Model A sedan I plan to use a junk yard floor mounted lever that I've had laying on a shelf for about 30 years. I don't know what it was from but I pulled out of a junk yard car 'cause I liked. At that time I had no use for it.
    egads likes this.
  29. modagger
    modagger
    :p
    VANDENPLAS likes this.
  30. sdluck
    sdluck
    Where did you find the boots for the shifter and em brake?
