Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. Tribalmonkey
    Tribalmonkey
    This came in the mail today. Gave me a bump of motivation. 79935B83-5587-4179-AFF4-D8089BFCFE46.jpeg
  2. Tribalmonkey
    Tribalmonkey
    Still cleaning trans parts. Trying see what I have and what I need to order. 70801639-634D-4664-BB0F-7C28F9F70C1B.jpeg
  3. Tribalmonkey
    Tribalmonkey
    I’m considering swapping out the cam. Any recommendations or advice?
    lothiandon1940 likes this.
  4. lothiandon1940
    lothiandon1940
  5. Tribalmonkey
    Tribalmonkey
    Thanks Don. I’ve never swapped out a cam. I’m not sure what all I need to consider. Do I need to adjust the valves afterwards? No adjustable lifters. Not sure I’m comfortable with grinding the valve stems if that’s what’s required. I’d like to talk with someone with experience before I tackle this one. TM
    Joe Blow and lothiandon1940 like this.
  6. lothiandon1940
    lothiandon1940
    I'm no help there. Anything that I might suggest would be purely speculation. Maybe some of those guys up at Bratton's could offer up some advice. Good luck. Hopefully some Model A gurus will chime in.
    loudbang, Tribalmonkey and Joe Blow like this.
  7. vtwhead
    vtwhead
  8. Dustyp489
    Dustyp489
    Check with Jim Brierley
    Jimb4e4@gmail.com
    He did mine , tell him the set up you are going with and he can grind you cam
    Skip
    Tribalmonkey and lothiandon1940 like this.
  9. Tribalmonkey
    Tribalmonkey
    Thanks Skip! I had a good conversation with Jim Brierley today. I’m going to send him my cam. He recommended his C grind for my purpose. I picked up some adjustable lifters from Bratton’s today. I’m not sure about valves, guides, springs. Can I just used what I have in there? Should I? TM
    Dannerr and lothiandon1940 like this.
  10. Tribalmonkey
    Tribalmonkey
    I also sent Mac Vanpelt pics of my ****** gears today. He said he would take a look and give me a recommendation of what I should keep and what I should replace. These pics are the ones I consider the most concerning. I’m bracing for impact on this one. $$$
    DE60558E-65DF-49BE-BCA2-2A65267B74AA.jpeg BF97F47D-9AC2-4469-97C1-EB470209B318.jpeg 7E8668B2-65C3-42CA-942D-2073D05B3E99.jpeg
  11. Tribalmonkey
    Tribalmonkey
    The engine looks better than I expected. The pistons, rods, and caps look pretty new to me. I can see hone cross hatch on the cylinder walls. No lip at the top of the cylinders either. Also the pistons are marked with 80. Does that mean 80 over? Is that good? TM
    623D26F6-4AE7-48E2-A347-1779564904DB.jpeg 1E0CFA85-1AFE-4D16-AAE5-B984FD64F6AA.jpeg
  12. lothiandon1940
    lothiandon1940
    I believe that is what the 80 means. That's quite a bit, could possibly affect cooling. I think 10 would be a typical "clean up bore". If I were to guess, that little engine may have been rebuilt more than once in its' life. It may be fine. It couldn't hurt to inquire with some of the A experts to get their thoughts.
    Dustyp489, Joe Blow and Tribalmonkey like this.
  13. Tribalmonkey
    Tribalmonkey
    Yeah. I’d like to hear what the experts on here have to say. Good or bad it is what it is. I’m sticking a higher compression head on it, probably a C grind cam, Mallory dual point ignition, and a 39 trans behind it. Also considering a lightened flywheel. All that and I want to keep it looking like the rusty old barn find it is.
    Tony Martino and lothiandon1940 like this.
  14. Dustyp489
    Dustyp489
    Ask over on the banger monthly meeting forum. My engine is 60 over with balance crank runs very smooth.
    lothiandon1940 and Tribalmonkey like this.
  15. I'm no expert, never played one on TV, and didn't stay at a Holiday Inn last night, but...
    I had a Model A that was bored .125 over, and had no problems with it. That was a pretty common overbore, but might also have been the maximum, but no one in the Model A community thought anything of it. Ninety years ago they weren't worried about 3.1 pounds of cast iron to meet fuel economy standards, so castings were thicker walled than what you find even in the '50s. I would be tickled pink (how the hell did THAT become a 'saying'?) to have a good one at .080 over.
  16. alchemy
    alchemy
    I would think a more important question would be "what shape is the Babbitt"?
  17. Tribalmonkey
    Tribalmonkey
    My clearances are good. I think it was a recent rebuild. Not sure about the actual babbitt condition.
    Dustyp489 and lothiandon1940 like this.
  18. Tribalmonkey
    Tribalmonkey
    Can I use the stock valves and guides with adjustable lifters?
  19. lothiandon1940
    lothiandon1940
  20. Tribalmonkey
    Tribalmonkey
    I may be close to needing an intervention.
  21. alchemy
    alchemy
    You don’t need an intervention, you just need some pallet racking.
  22. rusty valley
    rusty valley
  23. greaser
    greaser
    Maybe not an intervention, but perhaps a model A pickup will do.
  24. Tribalmonkey
    Tribalmonkey
    Without going into details and sharing other people’s personal business…
    I have sent my cam off to be reground. It looks like it may be some time before I will get it back now. Any recommendations on where I can get a good mild performance cam for my banger (without a core)? TM
  25. lothiandon1940
    lothiandon1940
  26. Tribalmonkey
    Tribalmonkey
    Joe Blow, loudbang and lothiandon1940 like this.
  27. Tribalmonkey
    Tribalmonkey
    ****** bolted in and filled with gear oil. 796617DC-DD74-46C3-9BC6-B1E595F2ED02.jpeg 2EA5BFFB-BC2C-44CD-99DE-260B1281ABA6.jpeg 0BEF43AD-5833-4371-8F49-86DA2A37AFA1.jpeg
  28. Tribalmonkey
    Tribalmonkey
    @lothiandon1940 . Don, I think you are my last remaining follower. :) I still plan to continue using this thread to do***ent my hot rod hobby. Thanks for hanging in there!
  29. Dick Stevens
    Dick Stevens
    There are more of us following, just not commenting regularly
  30. ^^^^^^^^^^^
    What he said!!!!
