Projects 1939 Merc cluster in a '32 and not a '38 dash
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Feb 20, 2022.
  1. sloppy jalopies
    sloppy jalopies
    was given the cluster minus the speedometer, had the gl*** dash hanging on a nail...
    wondered how it would look as a hotrod dash...
    STOGY came to the rescue, he photoshopped the 2 together....
    i like it, what do you think... should i break out the sabre saw ?
  2. HOTRODPRIMER
    HOTRODPRIMER
    Looks great to me and it's a gl*** dash so if you don't like the finished result The dash is easy to replace and I bet you would get a lot of guys wanting to buy it if you decide not to use it. HRP
    Stogy and clem like this.
  3. Stogy
    Stogy
    @sloppy jalopies you have to get innovative mounting that behind the dash but I know being crafty is one of your specialties...;)
    Outback and brady1929 like this.
  4. X38
    X38
    Do it!
    Outback and Stogy like this.
  5. dirt t
    dirt t
    Don't let common sense or fear stop ya.
    It looks OUTSTANDING.
    Okie Pete and Stogy like this.
  6. sloppy jalopies
    sloppy jalopies
    i am thinking about using the stock steel facade that covered the cluster...
    then through bolt the key, light, heater etc. switches as mounting bolts... letting them anchor it to the dash...
    may trim off the column cover section or mount a tach in it... top in pic.
    it had a stainless trim ? may use part of it...
  7. 5window
    5window
    Well, someone has to be a contrarian and I guess that's me. I prefer round gauges in this dash. But, it's your car, do as you like.
    Barn Hunter, Stogy and rob-redm like this.
  8. lostone
    lostone
    from kansas
    I like it without the face plate with only the gauges showing....
    More work to do it that way but well worth it I think.
  9. rdscotty
    rdscotty
    from red deer
    I agree with lostone
    Stogy likes this.
  10. 19Fordy
    19Fordy
    Just get used to the parallax.
  11. Stogy
    Stogy
    I have to look that word up...:D
  12. Stogy
    Stogy
    Ahhh...out of this world eh!...as claiming to be an Artist I should know that...a way one sees things...:)
    brady1929 likes this.
  13. rob-redm
    rob-redm
    I'm more the SW curved gl*** round gauges (my 36 3w) .. it is different .. in the end it's your car.. do what you like..
    Stogy and 5window like this.
  14. X38
    X38
    No, do not do this.
    If you do, the cool factor will be reduced by 95%. The attractiveness by at least 120%
  15. mrspeedyt
    mrspeedyt
    it’s different. I like it. either way.
    Stogy likes this.
  16. Stogy
    Stogy
    I think you're saying to use this faceplate behind the 32 dash and use strategically placed switches or other dash details to anchor it all...depending on thickness it might look sunk in the dash...clever...
    Or you could maybe mount the cluster without a the spacer plate with two or more large diameter brackets that anchor the cluster and switchs achieving same with more trim protruding...
  17. sloppy jalopies
    sloppy jalopies
    my mistake, i have asked his photoshopiness STOGY to picture it in a modified '38 car dash in a pm, but didn't post that here...
    i can weld the whole face plate to the '38...
    or i bid on the stainless trim, means bolting ...
    i was thinking of using the face plate as in insert like a '33 car, trimmed and mounted on the outside... i can't cut the merc gauge holes as perfect as henry did...
    mounting on the outside keeps their gauge to face plate fit intact...
    bottom pic shows a face plate/ cluster and just a cluster... SS trim runs along the outside edge of the face plate...
  18. Stogy
    Stogy
    :rolleyes:...I didn't add the trim around the Cluster Plate feeling it looked awkward and I also feel the Speaker grille Tombstone Trim might be better left off...
    I treated these dash images as if you have welded the faceplate into the dash. I also filled the Narrow Tombstone ports beside the center trim...Maybe those are heater controls...:eek:
    Thoughts?
  19. sloppy jalopies
    sloppy jalopies
    STOGY, thanks again...
    mikie likes it... no heater controls on a '38..
    but i have both the ashtray and choke tombstone inserts...
    stogy must be a chebby guy as he only printed the 8 from the 289 badge...
    the 8 does look right though...
    Stogy likes this.
  20. nor6304
    nor6304
    from Indiana
    I think it looks great
    Stogy likes this.
  21. Corn Fed
    Corn Fed
    I think it looks good in the 38 dash, but not so much in the 32. The squared off lines along the lower part of the 38 work well with it, whereas the curved lower 32 doesn't. And when you get a steering wheel directly in front of it in the 38, that will tie in the curved top of the speedo. In the 32 it just kinda hangs there.
    clem and Stogy like this.
  22. 5window
    5window
    It's busy with the seven gauges on the left side-lots of blank space on the glove box door. It looks too asymetrical to me. JMTC
    Stogy likes this.
  23. cfmvw
    cfmvw
    Just an idea, but what if you moved the cluster to the center of the dash? That way you could put another glove box to the left of it to hide a fuse panel.
    32fenderless and Stogy like this.
  24. Stogy
    Stogy
    Sloppy I was thinking V8 not Chevy...Ford has been flying V8 since the early 30s...There is a distinct V in that 289 Badge...
    I will reinsert the side Tombstones as they serve distinct functions I was not aware of...
    I always think about center based gauges as less safe than Forward looking ones which are the norm due to the fact you have to look to center taking the watchful forward eye off its mark even though that happens when you glance down to see the forward setup...
    I think keeping your eyes looking forward might help the response in emergencies which are unpredictable...
  25. Stogy
    Stogy
    Yes there's lots of real estate for whatever one might want to populate it with but my plugging up of the narrow Tombstone holes adds to that...
  26. sloppy jalopies
    sloppy jalopies
    can't ask for more than that... thanks stogy.
    5window and Stogy like this.
  27. sloppy jalopies
    sloppy jalopies
    bought a dash, an A'[32 style], bolts under the stock dash rail.
    may weld the '39 merc facade into the new dash...
  28. sloppy jalopies
    sloppy jalopies
    time has moved me over to the '32...
    but with a '39 merc cluster in a '32 style steel dash with a stock '30 dashrail...
    the '38 is back on the nail...
    Outback, tr_rodder and akoutlaw like this.
  29. Stogy
    Stogy
    ...The year was 1965....
    :rolleyes:...Hope this fits the bill...;)
    ...even if it's on a nail...:D
    Outback, Okie Pete and 6sally6 like this.
  30. Stogy
    Stogy
    Is the center face Height the same as your Fibergl*** 32 dash?
