Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. Hnstray
    Hnstray
    from Quincy, IL
    @rockable
    Just Absolutely Awesome Workmanship!!
    Ray
    BJR, loudbang, vtwhead and 4 others like this.
  2. rockable
    rockable
    Thanks, Ray!
    loudbang and BJR like this.
  3. rockable
    rockable
    0225221528a_HDR.jpg 0225221528_HDR.jpg Now we're getting somewhere!
  4. BJR
    BJR
    loudbang, Thor1 and rockable like this.
  5. loudbang
    GREAT color. :)
    brady1929, Thor1 and rockable like this.
  6. 58prostreet
    58prostreet
    Stance looks great as well. Looking real good Rock.
    Traceys dad
  7. rockable
    rockable
    7495.jpeg I posted this as a separate thread, hoping to gather more input. It doesn't appear my Sombreros are going to work out. Its a shame, I like them but they are throwing the tires out of balance at cruising speeds.
    Here's a shot after installing the front bumper.
  8. jim snow
    jim snow
    Beautiful, congrats. I’m sure you’ll figure something else out. Snowman ⛄️
    loudbang and rockable like this.
  9. Peanut 1959
    Peanut 1959
    So, removing the sombreros fixes the imbalance?
  10. greybeard360
    greybeard360
    FInd someone that can spin balance them.
    loudbang and Thor1 like this.
  11. rockable
    rockable
    Yes
  12. 123pugsy
    123pugsy
    If they were mine, I would set up a tapered ended rod to check the balance. Hitting center might be difficult, maybe tape a small washer underneath. Add little beads of silicone underneath until it's balanced. Something a guy could try and it's removable.
  13. vtwhead
    vtwhead
    If those tires are tubeless you might try tire beads. Most tire stores have them available. Might help with the issue. We used them at our store for difficult balance jobs.
    LAROKE, tomkelly88, Thor1 and 2 others like this.
  14. 40FORDPU
    40FORDPU
    Beautiful car, hopefully you can sort out the balance issue with those hubcaps..they really work with that car.
  15. i.rant
    i.rant
    Maybe your car is crying out for a set of Buick sombreros.....;)
    Beautiful car.
    brady1929, rockable and firstinsteele like this.
  16. BJR
    BJR
    X 2 on the tire beads. It should balance the tire, wheel cover, and the brake drum or rotor.
    LAROKE and rockable like this.
  17. rockable
    rockable
    Little by little, bit by bit. Its coming together. Upholsterer said mid April before we arendone with the interior. I did get the balance situation resolved...i think. So, I'm putting some miles on it and m***aging out small bugs.
    JalopyJimbo, Okie Pete, brEad and 8 others like this.
  18. rockable
    rockable
    I am one lucky guy. After taking the Buick for a drive, for probably the 20th-30th time, I parked it and locked the shop. Fortunately for me, a friend texted me and told me he had come by when I was gone he had left me a part outside the shop. So, I went back out there and the shop was filled with smoke! (There is nothing else like the smell of electrical smoke.) I opened the door of the Buick and the panel was on fire! The whole right side of my American Autowire Highway 22 panel was smoked and a relay was on fire. I blew out the small flame, pulled out the 2 relays with a pair of pliers and disconnected power. I had not wired in a main cutoff, which I usually do, so I had to disconnect power manually.
    As I think through this, there are no melted wires connected to the panel, including the main feed wire. (I will inspect the fuses tomorrow.) So, something in the panel or one of the relays had to short out. I will have to replace the panel and some other small things but, all in all, I was very lucky. My shop and my cars could have burned to the ground if my friend hadn't texted me when he did. I will be installing a master cutoff. I won't sleep well for the next few nights.
  19. BJR
    BJR
    WOW rockable That could have been awful!!!! :eek: Thank your friend for texting. That would have been heart breaking. You could have lost your 49 Buick and your shop. Is the interior of the Buick smoke damaged? :(
    loudbang, Thor1 and Hang'emHigh like this.
  20. rockable
    rockable
    Really no damage other than electrical and the AC vent hoses that I saw. I immediately texted him after I got things under control. I could have lost my other cars, too! It would have been a major disaster. I'm feeling very fortunate.
  21. Hang'emHigh
    Hang'emHigh
    Someone smiled upon you!
  22. BJR
    BJR
    Good to here the damage was minimal.:D
    loudbang and Hnstray like this.
  23. Hnstray
    Hnstray
    from Quincy, IL
    WOW…..just…..WOW! :eek:
    Happy beyond words for you Rock!
    Ray
  24. loudbang
    WOW good deal you caught it before everything went up. :eek:
    brady1929 and rockable like this.
  25. vtwhead
    vtwhead
    OMG! The one thing I (we) worry about is just what happened to you. I recall the fire that Ryan experienced a few years back. Scary deal for certain.
    Did you have a fusible link on the primary? Or just a manual cutoff for protection?
    I experienced a similar issue years ago while traveling out near Yellowstone with the Motorhome. Had electrical smoke pouring out of the dash. It gets your attention quickly. Fortunately, the power to the effected circuit (rear camera) was tied to the ignition side of the key switch. The camera installer had pinched the hot side of the 12 volt feed to ground for the camera and no fuse! Took about 9 months for that to finally cut through the insulation shorting to ground.
    I will be very curious to see what you find as the cause of your short. Terrible set back.
    Thor1, loudbang and Hnstray like this.
  26. jim snow
    jim snow
    Great catch. Your guardian angel was watching over you. I’m sure you will figure it out real quick. All the best. Snowman ⛄️
    Thor1, rockable and loudbang like this.
  27. rockable
    rockable
    Well, the horn circuit shorted and caused the fire. The wiring panel had the horn relay on the panel but it was not fused....and I did not catch that. So, I guess my horn ****on triggered the horns but I did not hear them. Maybe when I was getting out of the car, I depressed the horn ring. I don't know but the DS horn got really hot, so I'm guessing it shorted. So much for using the original horns that I cleaned and adjusted.
    It won't take me too long to replace the panel since all of the wires are terminated at the panel with screws. I did not have a master cutoff but I have seen the error of my ways and will remedy that, too. Dang, that was scary!
    JalopyJimbo, EBW, brEad and 8 others like this.
  28. rockable
    rockable
    0306220901_HDR.jpg 0306220822.jpg After checking the horn ****on today, I am certain it did not stick. What likely happened is I hit it when getting out of the car and the relay contacts welded themselves together. There was no fuse. Also, I was using the OE 6v horns which would draw high current. When I asked American Autowire why there was no fuse, they said that's the way GM did it for decades. Lesson learned.
    JalopyJimbo, Okie Pete, Tman and 4 others like this.
  29. vtwhead
    vtwhead
    Wow, what a mess. Glad you caught that before it developed into a major disaster.
  30. 123pugsy
    123pugsy
    Buy your pal a beer or a hunert........good save.
    rockable likes this.
