Hot Rods Dodge 318 LA to New process 4 speed
Discussion in 'The Hokey Ass Message Board' started by sheddynz, Feb 22, 2022.
  1. sheddynz
    sheddynz
    Hey chaps.
    I'm in New Zealand, working on a 1942 Dodge WC body and tray. I have a 77 club cab D200 ch***is I am going to make 4x4. My LA 318 has a bellhousing for the New process box. My question is, does anyone make an alloy bellhousing to replace the cast iron dinosaur I currently have, I can't believe the weight of this thing and I'm trying to stay under the big truck limit of 3.5 tone here in NZ.
    Thanks
    AB Normal likes this.
  2. squirrel
    Which NP box is it? The 435?
    Truck stuff was built pretty heavy....
  3. sheddynz
    sheddynz
    I think it is a 435
  4. sdluck
    sdluck
    [​IMG]will this work la 318?
  5. sheddynz
    sheddynz
    Possibly but need a link or address to view specs. Thanks
  6. AccurateMike
    AccurateMike
  7. squirrel
    They don't have NP435 as one of the transmission choices. Does anything else use that bolt pattern? It's not the same as the car A833
  8. 73RR
    73RR
    I am not sure of the input shaft length and too lazy to pull one off of the rack to check but, why not use a 70's-80's alum truck/van bell and modify the trans bolt pattern if it needs?
    squirrel likes this.
  9. AccurateMike
    AccurateMike
    I have drilled/tapped/studded an NP435 to change pattern too. It was the tail end, I'm sure you could do the same on the bell side as well. The case was plenty stout. Mike
  10. sheddynz
    sheddynz
    Awesome info guys, that alloy bellhousing from a van looks interesting
  11. 35desoto
    35desoto
    If you are keen to loose weight why retain the NP435 box?
    Is it because you can get the 4 wheel drive takeoff on the side of the box?
    Ive use Dodger Dakaota 5 speed boxes in a couple of projects behind good 318's and never ever quetioned their ability. They are aheck of a lot lighter than the 'box you are using - by the way I have a NP435 in my '73 Dodge club cab so have experience with them. Darn hard to kill - but plenty of weight to lug around
  12. sheddynz
    sheddynz
    Again thanks for the options. Sounds like a reasonable idea to change to a modern gearbox. I'm going to run a separate transfer case so that could work. One issue over here is Dodge stuff isn't easy to find and shipping availability and cost is mental currently.
