Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. john mullen
    john mullen
    Not much going on with the truck this week, waiting on parts. So today I installed new rear brake lines and flex hose to the frame mount. Then I caulked the underside of the C Notch before primer coat.
  2. john mullen
    john mullen
    I finished up the bed and shocks today as well as finished the new break lines. Just need to bleed them. I got an e mail from the cam grinder today and he has the profile done and it's ready to be ground. Hope to have it back early next week.
  3. john mullen
    john mullen
    Photos of the finished c notch and shock modifications 20220302_140120.jpg 20220302_140142.jpg
  4. john mullen
    john mullen
    20220305_150201.jpg 20220305_150236.jpg This is the modified stance for the new improved Virginia H.A.M.B Special
    Hopefully with this and the revised engine program we will record this project.
    Speaking of records team 640 has set personal best speeds every year we have gone to Bonneville.
    The crew and our support team are all that keeps this dream alive.
    And when we record this truck it will be with a much smaller engine and bigger truck than the current record holder by far.
    Thanks to the crew and support team we are able to keep chasing the dream.
    Thanks to all we charge onward with great hope and pride.
    Thank you everyone...
  5. pprather
    pprather
    Everything appears to be moving in the direction of more speed!
  6. john mullen
    john mullen
    Thanks phil
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That will help.
    Stogy, chryslerfan55 and loudbang like this.
  8. john mullen
    john mullen
    Just looking at fuel cost as if we were going to Arkansas today.
    1.750 miles round trip at 8 mpg × $5.79 per gal.=
    $1.266.56 dollars just for fuel not to mention entry fee's, lodging, food, race gas, etc.
    You might just say I ain't none to happy about dis ****.
    I guess I better get my *** to work on funding.
    Holly **** bat man..
    chryslerfan55, Stogy and loudbang like this.
  9. john mullen
    john mullen
    And if we left today to Bonneville.
    4400miles at 8 mpg.
    At $5.79 per Gal. =
    $3,184.50 just for fuel there and back. And we usually burn 2 or 3 tanks at Bonneville running around.
    Not to Happy bout dis $&#%. Hard on a poor boys pocket for sure..
    And I'm sure it's going to go up even higher by then
  10. john mullen
    john mullen
    $5.79 x 35 gal = $173.00 dollars per tank of diesel
    Unbelievable... and it's still going up
  11. john mullen
    john mullen
    Got a fresh cam back today and can continue engine ***embly once I get the cam degreed in..
    Arkansas mile is coming up fast so I need to get on the ball
  12. Rand Man
    Rand Man
    Where do they hold this Arkansas mile?
  13. john mullen
    john mullen
    Blytheville Arkansas at the airport there. ECTA holds 3 events in 2022.
    Search the web for ECTA HOME PAGE for details
  14. john mullen
    john mullen
    Working on some tire clearance on the right inner fender 20220314_172627.jpg
  15. john mullen
    john mullen
  16. john mullen
    john mullen
    chryslerfan55, Stogy, D-Russ and 3 others like this.
  17. john mullen
    john mullen
    Back to waiting on engine parts again ..
    I broke the cam retaining plate and had to order another one. Everything seams to go wrong when you have a deadline to meet..
  18. john mullen
    john mullen
    And now the head goes on and torqued down.
  19. john mullen
    john mullen
    20220319_112542.jpg 20220319_120753.jpg 20220319_120804.jpg Finished the top end today valve to piston clearance checked, valves adjusted, oiler installed and valve cover on.
  20. john mullen
    john mullen
    I have been laid up this week with a back injurie
    But back at it now. Slow but steady I will get back into the routine full time.
    Got the flywheel, clutch ***y and bell housing back together today. 20220324_152911.jpg
  21. john mullen
    john mullen
    Another short day today but I got the crank trigger on and timed. Also got the dry sump pump and starter on 20220325_135922.jpg 20220325_135940.jpg 20220325_140319.jpg 20220325_140328.jpg
  22. wheeltramp brian
    wheeltramp brian
    That thing is a beauty! Good luck getting some records
    Stogy, milwscruffy and D-Russ like this.
  23. john mullen
    john mullen
    Some photos after the engine went in 20220327_091908.jpg 20220327_123118.jpg 20220327_091850.jpg 20220327_091842.jpg
  24. The Magic Ratchet
    The Magic Ratchet
    Interesting. I was not aware you could use an early valve cover on a late head. John, is that "halo" around the rockers for oiling?
    Lou Mangl***
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    NASCAR racers use them to cool the valve springs to prevent fatigue.
    Jet96, Stogy and The Magic Ratchet like this.
  26. john mullen
    john mullen
    I have to use double gaskets to use this valve cover and yes the tube above the rockers is for oiling the top end.
  27. john mullen
    john mullen
    Freshening up the carbs and installing the Arkansas tune up.
  28. john mullen
    john mullen
  29. john mullen
    john mullen
    I picked up the header that Dave Russell modified to clear the tye rod. Took it to Jimmy's and gl*** beaded it then on to my shop for VHT ceramic coating.
    20220330_141651.jpg 20220330_141424.jpg 20220330_141045.jpg 20220330_140408.jpg
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It looks like you've switched out to a more efficient looking collector. That will be a good step toward a more efficient system which may ultimately lead you to merge collectors.
    D-Russ, saltflats and Just Gary like this.
