Technical Stewart Warner gauge repair
Discussion in 'Traditional Hot Rods' started by 1954fordkustom, Feb 22, 2022.
  1. 1954fordkustom
    1954fordkustom
    Hey guys,I was wondering if anyone has had luck changing the cable and probe on a water temp gauge? I have a large sw gauge and it is missing the end and I would like to try and repair it. Rather that throw it away. Any tips would be great
  2. alchemy
    alchemy
    It's not a do-it--yourself thing. Now somebody will come and link to an ancient site that shows how they did it with some dry ice and a soldering iron. But I think if the gauge is valuable (some old SW's are really valuable), it should be left to the pros.
    e1956v and Nailhead Jason like this.
  3. Joe Blow
    Joe Blow
  4. e1956v
    e1956v
    Alliance Vendor
    Speed~On likes this.
  5. Nailhead Jason
    Nailhead Jason
    @alchemy is right, I have done it on 2 different gauges, by using a donor gauge to steal the bulb off and the capilary tube. . And yes it did work sort of, but it was no where near accurate. I still have them both to send out and have done properly, instead of my rig.
  6. Speed~On
    Speed~On
    @1954fordkustom Can you post a photo of your SW water temp gauge? It sounds like you have a 2 5/8". I can shed some light on your gauge if I know which one you have.
    The guys are correct, the proper thing to do is to send it in. I have sent several to shops over the years.
    kadillackid likes this.
  7. 1954fordkustom
    1954fordkustom
    Thanks for the help guys. I have contact mo-ma .
  8. 1954fordkustom
    1954fordkustom
    Speed on. It is a 2 5/8 gauge
  9. fleetside66
    fleetside66
    If it's a smooth bezel gauge with a crescent needle & curved gl***, it would definitely be worth it to get it fixed. If it's a later flat gl*** step bezel gauge, you'd be better off finding one that works, as the repair cost would exceed they value of the gauge.
    kadillackid and e1956v like this.
  10. alchemy
    alchemy
    Good call. Many of the common newer SW gauges (2-5/8" too) are not worth the extra labor to repair. They can still be found in perfect working order at swap meets for half the price of a brand new one.
  11. 1954fordkustom
    1954fordkustom
    This is what I have.
  12. 1954fordkustom
    1954fordkustom
    Maybe you guys can school me a little bit. What year where this style gauge made?
  13. alchemy
    alchemy
    That style was made from the late 50's through at least the 80's. Then in the 80's they started painting the tail of the pointer black, but all else was the same.
    Yours has a plastic covered tube, so I'd guess a later gauge. The earlier ones had a wire wound tube.
    As I said above, gauges like that can be found at almost all swap meets. Usually for about $40.
    hotcoupe and ClarkH like this.
  14. 1954fordkustom
    1954fordkustom
    Thanks for the info. I bought several different 2 5/8 gauges from a fiend. A box full of them and unfortunately all the water temp gauges have been cut
