Projects S.E.G.A. Olds build
Discussion in 'Traditional Hot Rods' started by Saturn V, Oct 11, 2021.
  1. Saturn V
    Saturn V
    from Killen AL
    Seats temporarily mounted in place. Between swap meets, work, and odd jobs we finally got back on the car!
    Also got it stripped down for a trip to have the cage installed. IMG_20220226_133742191.jpg
    Due to my A.S. I've decided to pay for the roll cage. 10yrs ago I would have put it in myself. IMG_20220226_133705337.jpg
  2. Saturn V
    Saturn V
    from Killen AL
    Seeing how the g***er is going to another shop for a while. I'll give you a pic of a small block Olds I've got sitting in the shop waiting on it's final home! IMG_20220301_173345167.jpg IMG_20220301_173407681.jpg
    winr, chryslerfan55, catdad49 and 5 others like this.
  3. AmishMike
    AmishMike
    Besides water pump & alternator what are all those other things?
    panhead_pete, oj and SilverJimmy like this.
  4. Saturn V
    Saturn V
    from Killen AL
    AC compressor, steering pump, Idlers and tensioner.
  5. AmishMike
    AmishMike
    Yes, it is nice street setup but not needed on a g***er
    Saturn V likes this.
  6. Saturn V
    Saturn V
    from Killen AL
    I started building that engine before I found out the 56 was in the shape it was. Once we started finding all the hidden rust, plans for the car changed
    loudbang, AmishMike and mad mikey like this.
  7. Saturn V
    Saturn V
    from Killen AL
    This is the block for the g***er. Cleaned, magged. Ready to start machine work on. IMG_20220302_160835023.jpg
  8. Saturn V
    Saturn V
    from Killen AL
    These blocks are getting hard to find. I will post pics of all the machine processes that take place to turn this old boat anchor diesel into a 700hp gas burner!!
  9. Saturn V
    Saturn V
    from Killen AL
    Bored the block for 1 sleeve at work. Got it installed. Will be bringing back to my shop later this week. I have a few hrs. on my mill before I can take it back. IMG_20220307_134019646.jpg
  10. oj
    oj
    Those main saddles look weak, do you have plans for a girdle of some sort?
    Just Gary likes this.
  11. Saturn V
    Saturn V
    from Killen AL
    All we need is a set of splayed caps. These blocks are extremely strong. I know of one that is containing nearly 2000 HP. Twin turbo set up. I'll see if I can find a pic of it.
    Tman, OahuEli, chryslerfan55 and 2 others like this.
  12. Saturn V
    Saturn V
    from Killen AL
  13. SS327
    SS327
    Those blocks, cranks and rods are very strong.
    They were designed by Detroit Diesel built by Oldsmobile. They had to withstand high compression and hard explosions. No they were not Oldsmobile’s pro stock block though.
    OahuEli, chryslerfan55 and Saturn V like this.
  14. Saturn V
    Saturn V
    from Killen AL
    I would love to have enough Olds DRCE stuff to do a complete engine. That stuff is easier to find than the Batten parts!!
    Tman, loudbang and SS327 like this.
  15. Saturn V
    Saturn V
    from Killen AL
    Loaded and ready for the cage! Ready for the drive tomorrow! IMG_20220312_160254916_HDR.jpg
  16. Saturn V
    Saturn V
    from Killen AL
    Hard to believe all that green in the back ground was covered in 4" of snow this morning!!
  17. Saturn V
    Saturn V
    from Killen AL
    After a 7 plus hr drive. The Olds will be getting a cage!! IMG_20220318_174114062_HDR.jpg
  18. panhead_pete
    panhead_pete
    Looking at the motor, I thought you were building a G***er not a streetrod. Cant you lose all that billet, its so not in keeping with the rest of this build. Old Tunnel Ram and 2 x 4 carbs would look much better.
  19. Saturn V
    Saturn V
    from Killen AL
  20. Saturn V
    Saturn V
    from Killen AL
    If you'll read a few of the posts after, I stated that is going in another project. Especially after we found the extensive rust in the car.
  21. OahuEli
    OahuEli
    from Hawaii
    Just came across this thread and Holy **** how cool it is! My first car was a '56 Olds 88 mordor with the same color and a Rocket 330, not sure of the engine year. Paid $5 for it in 1971.
    Its real cool you're using an Olds motor and those main webs look pretty beefy. Designed by Detroit Diesel engineers? You're golden.
    Not sure if you'll be needing it but if you have any ideas you'd like Photoshopped, let me know. Subscribed.
    Eli
  22. panhead_pete
    panhead_pete
    Oh apologies I must have missed that somehow.
  23. FinnishFireball
    FinnishFireball
    Cool build, world needs more g***ers! Keep us posted.
  24. Saturn V
    Saturn V
    from Killen AL
    1st step in turning a diesel into a hotrod gas burner!! IMG_20220326_144949424_HDR.jpg IMG_20220326_145916415_HDR.jpg
    OahuEli, brEad, chryslerfan55 and 5 others like this.
  25. Saturn V
    Saturn V
    from Killen AL
    I've got 5 more of these block to do,,,
    OahuEli and 427 sleeper like this.
  26. bobss396
    bobss396
    Ballsy... I'd like a little more meat under the toe clamp. Is that a 90 degree attachment for a Bridgeport?
  27. Saturn V
    Saturn V
    from Killen AL
    Yes, it is. I have 2 machined bolts in the mains that fit snug in the t-slot groove. Only needed a light clamping to hold it tight to the table
    ottoman, chryslerfan55 and bobss396 like this.
  28. WalkerMD likes this.
  29. Saturn V
    Saturn V
    from Killen AL
    What I'm doing is machining the injector pump boss out. Having to make room for a good timing chain.
    It's a 78-85 5.7 GM diesel. If your going to make 650+ HP with a Olds. This is the block to use. The main webbing in the gas blocks are too weak to consistently contain those power levels.
  30. 6sally6
    6sally6
    Thanx fer the explaination!
    6sally6
