The Official Bead Roller Thread
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Jul 22, 2011.
  1. Dammit
    Dammit
    from Canada
    This is my H.F. bead roller that I powered with an electric power steering motor and gearbox, and SBC flexplate. The direction is controlled by a double foot switch and four relays, running off a car battery. The stand is made from warehouse racks and a '78 Chev van gas tank bracket. Am currently adding a speed control from a 12V trolling motor that allows me to slow the machine to where you can barely see the wheels turn, still having enough power to shape the metal without stalling. Have posted this machine before.
  2. D.G.F
    D.G.F
    from Las Vegas
    i have been looking at the HF roller... just to do some small jobs someday i will get me a nice one
  3. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  4. mr.chevrolet
    mr.chevrolet
    here's mine. picked it up for a couple bucks at a sale. no real throat depth but ok for the price
  5. timothale
    timothale
    Mr chevrolet 2 beads at once and they are even you scored ! !
  6. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Is that an old Pexto?
  7. nice, but keep your arms and hands clear of the sprockets:D.
  8. lrapso
    lrapso
    from Costa Rica
    Hey great machine what is the diameter of these bars ???
    <input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
  9. hugh m
    hugh m
    from ct.
    The rolls are about 3" in diameter....make a 1/2" bead.
  10. lrapso
    lrapso
    from Costa Rica
    Some pics of the advance in my Bead Roller build<input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
  11. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  12. hugh m
    hugh m
    from ct.
    A lot of thinking went into that one. Wonder how it would work for louvers, ever tried it?
  13. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Sure, we can make louver dies no problem.
  14. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Vultures Row Aviation sent this to me today and said:
    "Putting a .032 joggle on an 11' SBD Dauntless upper wing skin. Sweet! Perfection!!"
  15. scottb356
    scottb356
    My old 622, great machine but limited throat. If I ever get above water agin one of your rollers will be my next purchase. I NEED a deeper throat. Wow that didn't come out sounding right:confused: Is your units shaft the same as the Pextos ?....That didn't sound right either:rolleyes:
  16. markjenks
    markjenks
    Where's a good place to get mandrels for it? I got one a year ago and only have one set for it and would like others.
  17. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  18. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  19. Mark
    Mark
    from CT
    My Dad and I recently powered up a Central Machinery bead roller. Used a garage door opener that was kicking around. Cheap $7 foot pedal off ebay. Mounted a light switch bead roller3.jpg bead roller4.jpg to change directions. Model A axle tube as a stand. (have since added a flywheel to the bottom to make it more stable). bought a 40 teeth bicycle sprocket to gear it down even more. added a gusset to strengthen it. We are amateurs, still learning, but it seems to work pretty good.
  20. dabirdguy
    dabirdguy
    I tried the garage door opener rout. Great torque, but much too fast for me even geared down.
  21. Neil Hall
    Neil Hall
    Hello I’m trying to reach someone from Bali to get my alliance discount who do I contact I’ve emailed Shane no response?
  22. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Here are some pictures of my homemade bead roller. While it works well, it ended up being a LOT of work that isn't readily apparent. I was able to get a deeper throat on it than most bead rollers though. My suggestion is to buy one of the inexpensive bead rollers and upgrade (brace/motorize). Work just as well and a whole lot less work. If you can find a reasonably priced DC motor AND the controller that comes with it (Ebay), you can get one geared down where it can be slowed to about 5/10 rpms for good work and speeded slightly for longer straight sections. Speed control is important.
    Here is one someone else made years ago. Very heavy duty. I like it for doing thicker stuff and wide flat beads.
    fiftyv8 likes this.
  23. saltflats
    saltflats
    from Missouri
    My rendition with a Pro Tools you weld kit.
    dirt t likes this.
  24. Yamanine
    Yamanine
    Neil Hall, did you ever get ahold of anyone?
  25. Yamanine
    Yamanine
    Were you able to reach anyone at Baileigh about the discount?
  26. Never2old
    Never2old
    from so cal
  27. fiftyv8
    fiftyv8
    from CO & WA
    Made mine out of s**** and added a VFD controller.
    Kept it traditional by using a Ford diff flange as part of my base.
    Has not done a lot of work, but was great when I did my hood.
    This is the hood inner that I made with it.
    orbitup likes this.
