This is a 1958 392 Hemi bored 30 over with sone head work done. (Porting / polished) I have all New water pump, cross over, old school (new) valve cover ,tubes, plug wires, plugs, from Hot Heads. MSD ignition , coil and box. Mini torque starter. Mini high out put alternator. Low profile old school racing oil pan. I have 4 2’s set up from ****s Hot rod carbs that will go with it. It has a mild cam nothing to crazy for the street. I was putting this in a coupe I was building. I sold the coupe and don’t need the motor now. This motor is ready to go everything is here. If you need more pics or info let me know.
