Hot Rods I Need Some Help To ID This Dash Panel...
Discussion in 'The Hokey Ass Message Board' started by Papa Bee, Feb 27, 2022.
  1. Papa Bee
    Papa Bee
    from Lemoyne PA
    Anybody out there recognize this Dash Panel? I can't seem to crack the code on this one. The S-W Gauges are tiny - aprx 1 7/16" in diameter. There's a 100 mph Speedo / Fuel Gauge Combo in the center - perhaps the unique 100 to 212 range on the Temp Gauge will provide a clue. Overall it's 15 1/2" wide x 6 1/2" tall. I'm guessing 1930s(?)
    Thanks in advance !
    Gremlinguy, harpo1313, Spooky and 4 others like this.
  2. rusty valley
    rusty valley
    Very cool what ever it is !
    Stogy, VANDENPLAS and Wanderlust like this.
  3. Stogy
    Stogy
    Stewart Warner made in USA is a start...and yes Art Deco styling is evident...
    VANDENPLAS likes this.
  4. Max Gearhead
    Max Gearhead
    from Wisconsin
  5. Stogy
    Stogy
    wraymen and VANDENPLAS like this.
  6. Papa Bee
    Papa Bee
    from Lemoyne PA
    Stogy and VANDENPLAS like this.
  7. this right here !!! That instrument panel is kick *** !!
    Stogy likes this.
  8. Stogy
    Stogy
    Always good to double check...did Stewart Warner supply dash clusters to the Auto manufacturers of from 1905 to 1930s?
    Or...were they specifically aftermarket...
    There was a WW from 1914 to 18 so 1905 to 14 and 1919 to the early 30s are target years...
  9. squirrel
    SW supplied clusters and gauges to carmakers, usually the smaller ones...but some of the big guys, too. Hudson used them.
    I'd guess 30s from the look of it. Sure can't find anything like it, though.
    Stogy likes this.
  10. Papa Bee
    Papa Bee
    from Lemoyne PA
    Thanks for your input...
    I don't think a lot of 100 mph speedos were in use during the teens & twenties - but I've been wrong many times before !
    This is definitely a complete panel w/ the S-W gauges built to fit the very small & specific openings.
    I'm not sure what would've gone into that empty opening but I'd guess an ignition or light switch.
    I have never seen S-W gauges so small before - and the odd temp gauge range coupled w/ a 100 mph speedo really has me scratchin' my head.
    I haven't checked the truck dash panels of the 1930s too closely - perhaps it's from a commercial vehicle of that era.
    Stogy likes this.
  11. Stogy
    Stogy
    This is quoted from an article...
    "It was only in 1912, nearly a decade into the feud, that A. P. Warner decided to adopt an “if you can’t beat ‘em, join ‘em” strategy, agreeing to merge with his nemesis and form a new en***y, the Stewart-Warner Speedometer Corporation."
    http://www.madeinchicagomuseum.com/single-post/stewart-warner/
    :rolleyes:...What is important to note about the above is Stewart and Warner were separate en***ies prior to so compe***ors so I think we can rule out prior to 1912 due to this fact alone...
    kevinrevin likes this.
  12. 5window
    5window
    I doubt many trucks needed a 100mph speedo
    rusty valley likes this.
  13. Stogy
    Stogy
  14. wraymen
    wraymen
  15. squirrel
    yup, 33 Nash Big Six.
  16. Stogy
    Stogy
    continentaljohn, catdad49 and wraymen like this.
  17. wraymen
    wraymen
    I found another one where it was part of an automotive quiz. All three had the empty hole on the left. This is claimed to be where the ignition switch goes. It would be kind of funny if it’s the same panel that has been p***ed around.
    5window and Stogy like this.
  18. Stogy
    Stogy
    @F&J said he had one but wasn't particularly fond of it...
    I guess if we search out some originals for sale that empty hole may show an installed detail...regardless thank you for bringing some closure to this tough...so many models back in the day...
    I also note the dash must have a large hole that the main body of that cluster p***es through with the part with holes behind the dash with those attachments through the holes anchoring it...
    wraymen likes this.
  19. Stogy
    Stogy
    Ignition Switch....check
    Tman, rusty valley, wraymen and 4 others like this.
  20. Papa Bee
    Papa Bee
    from Lemoyne PA
    Mystery Solved !
    I had done online searches on Nash, Hudson, Studebaker (and many other makes...) but didn't find any images of this one.
    Thanks to you all...
    Stogy and wraymen like this.
  21. One of the most attractive dashes of the '30s. Glad somebody identified it, but the cool thing about traditional hot rods is that you can go ahead and use a cool part even if you never know what it came from.
    Stogy likes this.
  22. What a ***y piece
    a jewel for any hot rod dash
    Tman and Stogy like this.
  23. Stogy
    Stogy
    Okay Papa get it on the Hotrod now...100mph is good enough to lose your license so I think your good...;)
    anthony myrick likes this.
