Projects T&A Flathead Builds a '48 RagTop
Discussion in 'Traditional Customs' started by T&A Flathead, Aug 24, 2015.
  1. Squablow
    Squablow
    I really like the Cadillac grille and I think '49 Ford parking lights would work perfectly to finish the ends of that center bar, plus they'd be functional there.
    T&A Flathead likes this.
  2. T&A Flathead
    T&A Flathead
    I hammered out the original turn signal area. Would have been easier to start with nice 46 fenders but I could find any that didn’t have the same rust issues mine did. Also started figuring out where I’m going to cut to remove the rust.
    Okie Pete, Tim, Squablow and 4 others like this.
  3. louisb
    louisb
    You are going to be a master welder after this project.
  4. T&A Flathead
    T&A Flathead
    haha. Looking back, I have laid down quite a few feet of weld on this rust bucket. All that’s left is the rust on the front fenders. I’ll have those fixed by next weekend.
    Tim likes this.
  5. T&A Flathead
    T&A Flathead
    Front fender progress. I used pieces from the fenders off my parts car and made repair panels.
    8B4AEDB2-943A-4FBF-A658-24C7D4C74140.jpeg BEDB21AC-A745-45C8-94EA-D7B49CAE9298.jpeg 8F62D358-7803-4328-A3C9-FCA6F2ABEDCE.jpeg 919920D6-68F8-4856-AFB8-07FB422C3E38.jpeg FC953473-96DF-436E-9A5C-AD02785CCC3A.jpeg 7F2B1C68-BD86-4AB8-95D6-40490D7932C3.jpeg F41290F5-B2D8-40FB-A333-EB07DF9B51DA.jpeg
  6. T&A Flathead
    T&A Flathead
    Finished up the drivers fender and started on the p*** side.
    35916B99-4D3D-4205-ADA1-6B905A88215D.jpeg CECF55C1-0C44-499F-A3FD-31886ABF47AD.jpeg 6062F009-2D2F-4FDB-B91B-654D3E005CAD.jpeg 57844DDC-318E-4924-8B53-834A0A293876.jpeg
  7. hotrod1948
    hotrod1948
    from Milton, WI
  8. T&A Flathead
    T&A Flathead
    P***enger side fender fixed.
    6CCF1A42-1F6C-4F7E-B45B-72DBB2429DD1.jpeg 34B370E8-42E7-4C0D-AC5C-1312F8089860.jpeg 591CA027-D8EE-4A1B-AD83-28E9CE5FA842.jpeg 1BEC86F3-81E4-4EBD-A234-E4B9C8264D2A.jpeg
    Back to work on final fitment and modifications to the grille.
  9. T&A Flathead
    T&A Flathead
    A little more work on the grille. Added some mounting tabs and other final fitment work. Also shaped the center bar ends into radiused spears. Also welded round stock to the radius on the fenders to fill the gap between the grille. I have way too many hours in this grille.
    A4166974-6BC1-4223-9598-B19E4152EF53.jpeg 803F8227-BCF3-4198-8987-3357B9707046.jpeg 7646B13E-6789-4F7E-A421-A5E0AE9C984F.jpeg
  10. nitrobrother
    nitrobrother
    That's looking good, Tim! Too many hours? Yer just makin' it right and tight.
  11. Fortunateson
    Fortunateson
    Sporting a PortaWall! Old school at its finest....
  12. topher5150
    topher5150
    A porta what???
  13. hotrod1948
    hotrod1948
    from Milton, WI
    The grille looks fantastic! Nice work!
    36 ROKIT likes this.
  14. louisb
    louisb
  15. Fortunateson
    Fortunateson
    If you do t know what Porta Walls are they are a whitewall ring that tucks between the tire bead and the rim to give a low cost white wall “look”.
    Okie Pete and tractorguy like this.
  16. Dangerousdan
    Dangerousdan
    from Arizona
    I really like that you used the existing frame and extra parts to complete the engine mounts and the rear frame to lower the stance when sitting with the body weight. Also keeping the closed drive shaft. What was used in adapting the five speed to the Y- block? Thanks for a great build.
  17. T&A Flathead
    T&A Flathead
    @Dangerous Dan Thanks for the comments. The trans is a T170 from a mid 80s Ford F-150. It’s a 3sod with OD. I’m using an offy y-block to early ford trans adapter and an MEC adapter.
  18. nitrobrother
    nitrobrother
    That's basically the same transmission I had in my '31 coupe behind a pretty strong flatty. It cruised the highways like crazy with the overdrive. Great option.
  19. Fortunateson
    Fortunateson
    CBDF30A0-283E-4C27-AEB3-502BD0A201AB.jpeg Going for a little of this?
  20. T&A Flathead
    T&A Flathead
  21. T&A Flathead
    T&A Flathead
    I haven’t touched this car since March. Kids, work , house projects , and etc keep getting in the way. Cleaned up the shop today. Hope to be spending more time in the garage soon.
  22. Rand Man
    Rand Man
    I like these long term threads. Gonna read the whole thing.
    Outback likes this.
  23. Outback
    Outback
    from NE Vic, Oz
    Glad to see this thread pop up again. Life happens & you just can't stop it!
  24. hotrod1948
    hotrod1948
    from Milton, WI
    Great to see you are back at it. Slow but steady eventually gets it done!
  25. Fortunateson
    Fortunateson
    Well how’s it going? The world is waiting with bated breath for an update....
  26. nitrobrother
    nitrobrother
    Hey, Tim, checking in to see if you have an update for us ravenous hanger-on-ers!
  27. T&A Flathead
    T&A Flathead
    Haven't made much progress lately. But I did get something done today. I’m working on getting the hood gap up front where I reshaped it to be correct and uniform.
    D9210FD7-B9FF-456D-A35F-A22A01D4A42F.jpeg 68E0C10C-DE02-4211-A6D2-2D01DF85DDA9.jpeg 892465DC-4EB8-4D22-ADF1-898C9BAF77D9.jpeg E9686784-F6DE-4AB4-8138-FAA07D396E1B.jpeg
  28. T&A Flathead
    T&A Flathead
    Not much of an update, but I have a helper now.
    58F65218-B4AD-4A59-918D-5C972A8AFE9B.jpeg A1AB854E-4FFF-44BE-BAA7-EEBFB2F8AFD7.jpeg
  29. nitrobrother
    nitrobrother
    Holy smoke she's getting big! Glad it's happening again.
  30. Squablow
    Squablow
    Good to see progress, also good to see you're teaching your helper about proper eye protection. Those are good lessons to learn.
    Outback likes this.
