Hot Rods 57 FORD Build #2... Glutton for Punishment.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Oct 20, 2021.
  1. Texas57
    Texas57
    Let me look. My high beam switch is on my late steering column now, so never used it. I think it had a rust issue though.
  2. thank you, i should be able to patch it as long as its not completely gone.
  3. Texas57
    Texas57
    was gone all day....will look tomorrow.
  4. Texas57
    Texas57
    Sorry, I coudn't find it. I did find other stuff I forgot I had while looking, so that was good, but no switch cover plate. Sorry!
    NoSurf, loudbang and Thor1 like this.
  5. No problem.
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well,.... no big updates.. but small all around the project type things....
    I received the parts I needed, Headlight switch,Bezel and Knob with an OG ignition.Fantastic shape.
    My headlight buckets came as well and I was floored how good of shape they were in.The man in B.C. primed and packed flawlessly.All the small spring hardware was included.
    Very Happy on that.
    I started to ***emble the heater/Defroster for the car,.... cleaned and painted, then fit the the heater core, vacuum controls and outer heater box.While doing so I ***embled the Vents(Pia) then put in the dash.
    All went well but I learned from the last car to have this stuff in place before wiring.Just easier(for me anyhow)
    With a bare firewall,.. one would say"man... loads of room"
    not really.... last car had the fuse panel on the left cowl side.. this one will have it on the p***enger side(right side).The left has just too many obstacles for me.. parking Brake, hood release, pedal ***embly and steering..... so, yea.... fuse panel- p***enger side.
    Tackled a little painting on the trunk area, rear floor.. with again a myriad of rust paint, and Por-15.
    Just started and a rough first coat is on.... but I will allow it to dry for a few days before a second application.
    I need undo a weld on the cross-roof bow and bend it back into shape,.... a 10 minute job... but next on the list.... and I can also apply paint under there as well.
    Gonna run a Wildwood small master for the clutch.... just need to order.... but a small 7/8's should fit nicely beside the factory master.... "It should"......
    Famous last words.
    Later guys.
    brEad, pwschuh, Joe Travers and 18 others like this.
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Just an overall shot from a week ago. and I was happy the front end settled down ... it dropped 1 full inch all ***embled.
    I ***ume it may drop another inch when all the sheet metal gets put together.
  8. Ha Ha Ha ,not to forget where you put them ,Ha Ha Ha Safe place HaHaHa
    loudbang, Thor1 and Jeff Norwell like this.
  9. Been looking for 2 yrs for the safe place I put the ashtray and thumb latch for my 35 chev glovebox door HA HA HA
  10. 57 Fargo
    57 Fargo
    Jeff, it’s going to look mean once it’s all together.
    Hell it already looks mean.
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    "I already forgot my safe place"
    Joe Travers, loudbang, Thor1 and 5 others like this.
  12. Fabulous50's
    Fabulous50's
    from Maine
    20200702_231454.jpg I think you may already be done by the sound of it. But, I found a good place for 12 fuses under the dash was just to the right of the colum. I riveted a piece of 3/16" aluminum to the firewall and mounted my universal ebay fues panel to that. It was split 6 and 6. So I make half of it hot all the time and the other half hot with the key through 40amp Bosch relay you see on thr column. This is fed by 2 #10 wires which are fused at 30amps by the battery. This is all covered with loom or 3M super 33 tape now. But you get the idea. 20200404_203458.jpg 20200404_203657.jpg
    pwschuh, Joe Travers, Deuces and 9 others like this.
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @Fabulous50's
    I have not made any clear decisions as of yet.... kinda doing that As I go..... not sure if that's good, bad or indifferent....I just know if I make plans beforehand.. it never seems to work in my favour. hahaha
    Joe Travers, loudbang, Thor1 and 4 others like this.
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    The safe space thing.... yea,.....
    Last night I had about 10 small things to get off my list,.... interior, exterior,... I have had the thermostat and the neck out which was one of the things that needed "to get done".. ya know... try every evening to attempt something, so your always moving forward.... well... I had everything laid out... permatexed the gasket, placed the studs into the manifold, had the wrench and socket handy...... "where did the lock nuts go?"
    I spent 35 dang minutes looking where them d#%m nuts went.... then.... God told me to look down....
    there they were... on the intake manifold.....
    Geeeeeeezzzzzz.
    That's how it always goes for me.
    I don't know if it age or just I think about 5,894 things over a 2 minute period.......
    ..........after completing this very simple task...I sat back and questioned myself.....
    "Did I put that thermostat in backwards?!?"
    I did not.
    brEad, Baumi, Silva and 17 others like this.
  15. enloe
    enloe
    from east , tn.
    TOO FUNNY
    loudbang, Thor1, Stogy and 2 others like this.
  16. hotrodA
    hotrodA
    ^^^^That’s a look into the future! Just wait, it doesn’t get better with age. HA !
  17. keeping it a column shift?
    lothiandon1940 and Jeff Norwell like this.
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
  19. RmK57
    RmK57
    Cruise-o-matic?
    Jeff Norwell likes this.
  20. 3 pedals, likely a 3 speed.
  21. Fabulous50's
    Fabulous50's
    from Maine
    3 pedals is a real car!
    I think there is a breed of person who was born with a clutch pedal under their left foot......
  22. Sky Six
    Sky Six
    from Arizona
    I'm a big fan of any Norwell thread. Always has pictures, thoughts on what to do, how to do it, and yada, yada, yada. But what I am waiting for is the video of the day he takes it out for the first time. Lots of volume, lots of revs, dump the clutch, and head North sorta straight.:D
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @Sky Six
    Dan... your most kind.. and just to let people know of your generosity,...Dan has sent me 57 parts he had left over from his previous build..... generous indeed.. thank you so much.
    and yes.... soon,. in a few months.... a burn out on Channel 12.
    hahaha
    brEad, Joe Travers, enloe and 5 others like this.
  24. Those of us that grew up with a column shift were pretty good with them until they got worn. Then the rods got out of adjustment and a few broke the lever off. :) There's a reason why Foxcraft and Ansen shifters came to market. :) Poor people couldn't afford a Hurst.
    Joe Travers, loudbang, Thor1 and 3 others like this.
  25. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes.. 3 pedals for sure..... but no 3 speed.
    This is a long winded response .... so buckle up and try not to fall asleep. hahahah.
    In the beginning..I wanted 3 pedals... and for a time I toyed with a 3-speed OD unit... I had a perfect R-11 lined up... at a great price.... but... the distance for transport and cost... was ridiculous.
    And these good 3-speed OD units are very pricey.
    So, I settle with the Top loader 4 speed I acquired 2 summers back.. a good and fair price for a rebuilt unit..... a 69-70 unit that was from a 351 Stang.
    Next was to find the shifter,... the perfect Hurst shifter and all is a 64 Galaxie unit.
    Since I have been down this road before.. believe or not.... the cost of a Hurst for my application is super costly..... $750 USD.... and then add shipping, duty, tax and exchange(20-25%).... I am into the $1200-$1500 range.Combine this with a shifter handle that needs to be altered because of the bench.....
    I went down this road with my other Black 57. I did not want to buy a used unit from Craigs List or elsewhere.... Not much cheaper and some old unit that was beaten and tortured to death.
    I was prepared to swallow all this...... and buy a new unit.
    COST
    So, I speak with my pal Jay from M***.... and he asks what were my plans with the shifter and trans?
    I tell him that I plan on buying a Hurst unit....
    He asked me.."Why not a 4-speed on the column?"
    I was intrigued ..... So he begins to tell me about his 406 with a 4 speed on the column... and how easy it was...
    Basically... the shifter rods, shifter tabs swap directly over to a 4 speed Toploader .
    At first I didn't believe him.... this was impossible.
    So... Enters Lane from out west.... @57 Fargo
    Lane and I start to converse and he has this 58 Meteor with all the parts I could use and need.... anyhow.. we strike a deal(which is still ongoing)
    Lane wants a Hemi.. he is a mad Mopar nut..... so he will be getting a 54 331 for his P/U and I will get a boatload of 58 Meteor parts I need for now and the future.
    Problem is Lane lives in North Alberta.... about 1500-2000 miles from where I am.... but... I have a trucker friend that has agreed to transport because he does North America moving..... so a deal was struck and hopefully Lane will have his Hemi by June.
    This board moves in mysterious ways...
    Lane sends me the shift rods and shifter tabs.... I stare at them..
    "this aint ever gonna work"
    I have several columns.. and pull a cherry 57 manual column in very good shape.. give it a clean and grease.... start bolting and lo and behold.. the darn thing worked!...
    The rods line up... the shifter shifts into every gear..... I never even had to adjust the rods.... so....
    1-2-3-4 ..H pattern.
    I then called Mr. Mac Vanpelt.. at VanPelt and I spoke with him and got a OD cable and reverse parts for using reverse(small kit) using the cable.
    Great guy.. and really knows his 3 speed and early transmission stuff..... so....
    I was going to use a old vintage Morse throttle to pull reverse..but... ehh.... it just was too big and out of place.The OD cable out of a shoebox is a perfect fit.
    The only fly in the ointment is I have a small amount of relief to be made on the 1-2 shifter tab.. as it knocks into reverse.... no big issue... doing that now.
    so... Ford Never made a 4-speed until 63.... so in my mind.... it works on this build.I had a 55 Ford with a 3 speed OD and column shift.I loved it.
    Yes.... you can't beat a Hurst 4 speed. and I have one in my other 57..... but the costs are getting very prohibitive... I would rather spend that cash in in other areas.
    I am not an automatic guy.... and I don't fault others who use and like them...
    My car.. my way.....
    *edit*... @Mac VP
    Mac help me with the parts I needed.. great guy!
    I gotta go.... My build is calling me.....
    Thanks guys ....
  26. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Either can I!!!!!!!!
  27. lothiandon1940
    lothiandon1940
    Wow. It's like the stars aligned for that 4-speed on the column and the help from fellow Ford pals. Excellent.
    Joe Travers, enloe, loudbang and 3 others like this.
  28. guthriesmith
    guthriesmith
    I have also been intrigued by the 4-speed on the column deal ever since my buddy Bret did that in his 40 Ford coupe. We may head down that road in my kids C10 build. Pretty cool setup.
  29. RmK57
    RmK57
    If I were power shifting on the column I'd be afraid of snapping off the shift lever.
    It's a cool setup for sure as long as you don't get to aggressive.:cool:
  30. The '50s/early 60s Ford column linkage was pretty good as long as it's in decent or better condition. When Ford started using die-cast parts it went to hell...
    Knew a guy back in the day who dropped a 289 K-code/4speed into a early Econoline van. Considering that the shift rods were about 5' long it worked better than you'd think.
