Technical Help with large base 2 bbl gm carbs
Discussion in 'The Hokey Ass Message Board' started by Oldfart59, Mar 1, 2022.
  1. Oldfart59
    Oldfart59
    I have a tri power intake trying to find base for the end carbs
    All I see is small base for sale
    Thanks
  2. Jmountainjr
    Jmountainjr
    I am guessing that you want to convert the end carbs to dumpers without idle circuits? And you are looking for carb bases that are so configured? That's one way. You could also modify the bases that you have to block off the idle and transfer functions. In either case the important issue is sealing the throttle blades. That's best done with the thicker blades and some fitting. Lots of info out there about doing it.
  3. Oldfart59
    Oldfart59
    Yea you need different shaft to do it
    Must be someone doing it
  4. Joe H
    Joe H
  5. Oldfart59
    Oldfart59
