1952-59 Ford Motor pics anyone???
Discussion in 'Off Topic Hot Rods & Customs' started by Keith Sweesy, Feb 22, 2022.
  1. Rustvelle SS
    Rustvelle SS
    Yes, Mustang radiator and shroud and a 7 blade clutch fan. Radiator is mounted in front of the core support instead of behind it. And I had to cut out part of the splash pan to clear the radiator and A/C condenser.
    50sboy and nosford like this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    It is ironic how many of use used the oval type air cleaner, I had planed on using the original air cleaner but it just didn't look right, the oval air cleaner is pretty reasonable, I think or was about 55 bucks when I bought it but that was 10 years ago. HRP
    Dos Cincos likes this.
  3. 57Custom300
    57Custom300
    from Arizona
  4. larryb
    larryb
    The carb engine is on my driver 53 Merc. The fuel injected one is in the 53 I'm building a a every day driver. Have it rough wired and running and yard driving marron 53 merc motor.jpeg 53 merc FI motor.jpeg
  5. frnkeore
    frnkeore
    Shortshift, can you tell us more about your steering conversion? Maybe open a thread about it?
    nosford likes this.
  6. Keith Sweesy
    Keith Sweesy
    from Hope, Ar.
    Please do. I’ve got a 99 Cherokee I was fixing to sell to wrecking yard.
  7. shortshift
    shortshift
    OK i will start a new thread about my jeep steering conversion with pics. I know others have done this conversion so there may be other/better ways of doing this
    nosford likes this.
  8. jimmy six
    jimmy six
    Okiedokie… is your Bendix vacuum ***ist on on the front brakes? It appears that way. Are they front discs? I’ve seen this on thunderbirds done by Prestige T-Bird in Calif. I do not see a prop valve.. Very clean installation.
  9. okiedokie
    okiedokie
    from Ok
    Yes only the front brakes are boosted. Prop valve is mounted on the frame. Thanks for the compliment.
  10. jimmy six
    jimmy six
    How do they feel? Meaning nose dive if heavy braking. Did you need to add a lot to the rear thru the prop valve? Just wondering. We had this system on a 55 when new but it had a single MC and worked great then.
  11. okiedokie
    okiedokie
    from Ok
    They work good, no nose dive, did not add a lot to the rear.
    jimmy six likes this.
  12. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Given that it's a '65 or '66 289 that's been in there since 1980 or so, I've always been partial to the Cobra-style valve covers with the black wrinkle-paint finish and the '65-style Moostang open element air cleaner. My next project should be to get the Fairlane radiator swapped out with a '55-'56-style one that I picked up at a swap meet last fall and get an external transmission cooler.
    fordsbyjay, 56longroof and okiedokie like this.
  13. ezrodder1
    ezrodder1
    How about a nice greasy motor pic
  14. shortshift
    shortshift
  15. customline joe
    customline joe
    Has anyone posted a thread on installing a 351 cu in Cleveland engine in a 1955 ford customline ? I have a rebuilt 351 cu in Cleveland engine and a T5 transmission to replace the 272 cu in and 3 on the tree in my 1955 customline 2 dr. sedan.
  16. Paul2748
    Paul2748
    312, performance cam, 4 speed
  17. customline joe
    customline joe
    Do you have any notes or photos of the installation process that would help me to avoid any issues in advance. I am planning on installing a 351 Cleveland with a T5 transmission in my 1955 this summer. Thanks,
  18. 50sboy
    50sboy
    Driver side header is the only problem I ran in to. I have stock steering box, etc. I made a custom set on the side - almost any p***enger side blears. I used prothane mounts. elongate the holes in the engine mount bracket on the frame. Set the motor back as far as you can to allow room for mechanical or elec. fan and radiator. All else is same as a small black.
    Texas57 and 56longroof like this.
  19. customline joe
    customline joe
    Thanks 50sboy , this information helps me , I plan to install a 2 barrel head Cleveland that will be a daily driver . I have a 4 barrel head Cleveland that is scheduled to go in my 40 coupe and I have sanderson headers for that install.
    Thanks Again
    Joe
  20. Fairlane 62
    Fairlane 62
    A 55 may be different, but I used 1969/1970 Fairlane long tube headers when putting the Cleveland in my 58.
  21. qicvick
    qicvick
  22. cka7
    cka7
  23. okiedokie
    okiedokie
    from Ok
    Always nice to see you stuff cka7, what a beauty.
    cka7 and Texas57 like this.
  24. customline joe
    customline joe
    Thanks for the information on the headers, I will check with the friend who built my engines to see if has a idea where I may find a set .
    Joe
  25. Fairlane 62
    Fairlane 62
    I think the same year Mustang used the same headers as well.
  26. beachcruzer
    beachcruzer
    Here are a couple of pics of my 330 stroker Yblock. first painted in Daytona yellow, but changing body color and the burnt copper would go better with the deep metallic green I now plan on. Almost ready to plant in newly blasted/painted frame.
    IMG_0739.JPG IMG_0839.JPG IMG_1225.JPG IMG_1226.JPG IMG_0739.JPG IMG_0839.JPG IMG_1225.JPG IMG_1226.JPG
    nosford, jimmy six, Texas57 and 2 others like this.
  27. customline joe
    customline joe
    Hi Paul,
    which 4 speed transmission and length did you install ? I have a 4 speed out of a falcon that is shorter than the toploader 4 speed I have with is 27" +or - to put in my 55 customline with y block 272 . The driveshaft is my concern , I have a 86 crown vic driveshaft that I can use if it is the right length.
    Joe
  28. redzula
    redzula
  29. jimmy six
    jimmy six
    Since one has shown a dual quad Y-Block I’ll post mine. All evidence removed from the manifold manufacturer, 2 matched Carter WCFB small base carbs and the Purolator NASCAR mandated air cleaner for 1956. Dual quads were available in 1956 as a performance kit at Ford approved parts counters for law enforcement and racing; 103 kits were known to be made for all use. The p***enger car/Thunderbird air cleaner was different. Mercury’s were known to use their CARTER WCFB carbs. They’ve been on 7 trouble free years and checked every 18 months or so with my Unisyn. Mated to a 1962 medium case Cruise-O-Matic and 8.8 Explorer rear ended. 1CBE9D2F-C71D-459E-A339-411D8F401888.jpeg BBA17F09-7F48-416E-8534-BA2CB6F74766.jpeg
    50sboy, okiedokie, 56longroof and 3 others like this.
