History Man-A-Fre
Discussion in 'The Hokey Ass Message Board' started by catdad49, Mar 3, 2022.
  1. catdad49
    catdad49
    Every time I think about thinning my collections of magazines, I seem to find a gem that needs to be shared. Here's one concerning Man-A-Fre intakes set-ups. I know most are familiar with the 4 carb versions, but has anyone seen or used any of the other ones?! From the May '66 issue of Popular Hot Rodding, Enjoy. IMG_3289.jpg
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
  3. Mike VV
    Mike VV
    from SoCal
    Ol Harold made some changes to the two barrel carburetors too.
    He cut out the divider between the two ventures, to make the upper a single oval opening. I thought, to give it a try, just for the hell of it.
    I cut the center piece out, did some reshaping. Some JB weld to reshape the ventury opening, much like the Holley three barrel carburetor. Then to smooth the airflow through the base, you ground the base into a "V" where the air enters the throttle bores. No flat s left on the throttle bore base for the air to bounce off of.
    A friend put the one that I did on his 65, 283 El Camino. While I do not recall the specifics, his El Camino went a little quicker and faster at the original Irwindale Raceway, than with the factory two barrel carburetor. Interesting fact too, the open throttle sound was much different than a stock carburetor also.
    I then lent it to a friend that put it on his Hot Rod, Corvair. That whole thing was a constant experiment.
    I never actually ran it on anything of my own. I just did it as an exercise, experiment.
    And yeah, I ran a normal, four carb. Man-a-Fre on my 56 Chevy for 5 or 6 (more?) years. Both on a 327 and a 350 engine.
    Mike
  4. bchctybob
    bchctybob
    Isn't it funny how you can go through them again and again and see something of particular interest each time. Sometimes they are very timely, I was going through a stack a few weeks ago and found articles on how Royal Pontiac and Geraghty Automotive power tuned the GTO 3x2 set-up back then. Just as I was rebuilding one.
  5. saltflats
    saltflats
    from Missouri
    We ran one of his 2 jets on are street stock dry pond runner. Man did it wakeup that 355.
    catdad49, loudbang and mad mikey like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I went and found that issue of PHR and read the article. while they showed a few different manifolds in the pictures, all they talked about was the 4x2 setups. Maybe the others were prototypes that never made it to production? who knows. I have a man a fre on my corvette and it runs great and even gets pretty respectable mileage at 18 mpg .....
    Just Gary, vtx1800, rod1 and 8 others like this.
  7. Motorwrxs
    Motorwrxs
    Sounds sweet…any specific carbs you need to run on those intakes? Seems like someone on the HAMB has a American Graffiti coupe and had trouble getting it set-up correctly. Thinking he needed to run some specific truck two- barrel carbs?
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, 58 chev truck carbs are what I have
    mad mikey likes this.
  9. Motorwrxs
    Motorwrxs
    …so if one wanted to run that intake, would they need to run 58 chev carbs? Or is it the intake was designed for those type of carbs?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    There are a number of carbs that will work, but the throttle arm on the 58 chev carbs are the proper length to work with their linkage. most other carbs that were modified back in the day had the throttle arms cut off and a man a fre modified arm welded on so that the throttle linkage would work
  11. Motorwrxs
    Motorwrxs
    Gotcha…it is a killer looking intake for sure.
  12. hrm2k
    hrm2k
    on my V8 Corvair, I went through this Offenhauser manifold with the carbs matched completely. We could get top end and ugly at low speeds or low speeds but no top end. We screwed with this for almost 6 months before I removed and sold it.....and replaced it with a sniper...........so sweet
    I still think this is the best looking induction system
    VANDENPLAS, catdad49 and loudbang like this.
  13. Motorwrxs
    Motorwrxs
    I have to agree…
    catdad49 and hrm2k like this.
  14. Axle34
    Axle34
    from Michigan
    My Man-A-Fre runs good!
    rod1, PBRmeASAP, loudbang and 6 others like this.
  15. Paul
    Paul
    Editor
    Pretty sure my bbc man-a-fre had the mid '60s big 2GCs off a BOP car
    loudbang, joel, hrm2k and 1 other person like this.
  16. Axle34
    Axle34
    from Michigan
    Paul, Yes, I think all BBC Man-A-Fre intakes were made for big GC's (but I don't know, for sure). My
    intake was modified (adaptors made) to run the smaller carbs.
  17. Danger Diaz
    Danger Diaz
    IMG_7771.jpeg Hi, seeing the prices for anything Man-a-Fre, even if it’s incomplete; has anyone made their own? starting with a Corvette/Rochester fuel injection base manifold? I’ve been curious if anyone has.
  18. Dave G in Gansevoort
    from Upstate NY
    Found this picture here from 2009. Small block tunnel ram.
    Might be an even cheaper alternative for making a sudo-Man-a-fre intake. If you could find just a base, then cut and weld carburetor flanges on, and recreate the balance p***ages, it might be worth the effort.
    Danger Diaz likes this.
  19. DDDenny
    Considering those single intake tops never worked the best I imagine the whole thing could be bought at a fairly reasonable price.
