Projects BENNETTS ‘Midnight Special’ speedster
Discussion in 'Traditional Hot Rods' started by jordabennett, Mar 3, 2022.
  1. After a bit of hiatus with personal projects, I’ve had my eye on a very special event happening in September this year. A race at Lake Perkolilli called the ‘Red Dust Revival’ paying homage to those who raced the dry clay lake bed back in the 1930s/40s
    I missed this race that happens every four years due to restoring and hopping up a gentleman’s ‘34 Hudson Terraplane who raced it at the event back in 2018.
    The pile of parts has grown and there’s plenty to do. There’s 199 days until the race- 7 weeks of that will be spent back home in Canada
    The inspiration most definitely came from Ray Prue’s (onekoolkat1950) little speedster he build and raced at Trog in 2017, along with other major car inspos I have the idea in my head and will continue to post about the build.
    I’ve spent only just 3 days so far but feel I’ve made some progress.
    I picked up a rolling model a ch***is. Sold the frame to a good mate. And will use the front and rear axles and wheels etc.
    The frame rails are box tubing that will have oval sections taken out at a later time. Wheelbase is 94” and frame width for outside is 24”
    I will finish off the frame over the next few days tweaking the springs and getting the ride height where I want it, it will be flathead powered with a 39 box (maybe an early overdrive)
    I’ve sectioned, trimmed and cut a cowl (can anyone identify it) to suit the 24” wide frame and will fabricate the rear section as I go and make a nose and grill setup as well.
    Here’s how I’m going so far:
    6C72B4D0-1593-4992-A197-6A5E90C2F7FA.jpeg C101DB1A-F0A6-4505-8B87-61A0FD2520AC.jpeg 515FCA64-AF28-40C3-AE99-C7C018C476EB.jpeg 7E5865B1-83DB-4958-9201-AEF3E803BD4C.jpeg DCD71AE3-060F-4799-AA64-8575EE758F3C.jpeg 528F0D8B-2813-4B68-86B7-9D413A9CCE74.jpeg DE85FE44-852C-455D-A05C-BB387D74D67E.jpeg 2D6EE14C-1A92-4FFF-B58F-3BD129D99325.jpeg 778049AA-CEC5-4CE5-B315-F26D1A7D5566.jpeg BE7C5E5B-EA25-4CDA-88F4-D4ECE056407B.jpeg 85833DFF-BB77-4C73-ACA1-203FE116B605.jpeg 6C97348C-2101-48D9-AA39-8FBB47AFC151.jpeg 1C67D16B-A57A-4498-90B2-8433366E7964.jpeg 44659C71-B55D-4E21-85E1-49BACFAD10C7.jpeg 5AE73C71-3694-4B35-AF95-448680C817D2.jpeg 96FF2352-3E4E-4F48-AE02-F2BC08A883D7.jpeg B0B0B999-BACF-4D54-AF27-96F0B0650761.jpeg 47E4ED8B-419F-4C49-8591-231333D3E44C.jpeg 635914DD-5CF5-489A-9697-B22321DB9003.jpeg F22126C6-E657-4D96-9E92-CD50C37C44E0.jpeg 332FBEA9-1021-49F8-A121-AE6AA7756886.jpeg 332FBEA9-1021-49F8-A121-AE6AA7756886.jpeg 2EACCBB9-9030-40C6-B3F1-E140DCD23638.jpeg 1DB9059C-1E1D-4A2F-8287-974CF1FFF6D6.jpeg 4224588F-DB54-4575-A8DF-B74812FDE124.jpeg CFC18E1C-CF2A-4AB5-9100-226E616B427C.jpeg
  2. badgascoupe
    badgascoupe
    Nice project... I'm following it!
    Hnstray and Stogy like this.
  3. DDDenny
    Cool!
    Some very creative ideas.
  4. Today I managed to get a bit more done, I cut the rear model a crossmember flush and added a plate that’s welded in with silicone bronze to finish off the out side frame rail, I welded in the lower portion of the the kick ups and blended them in. I also added some gussets that play a role in the look of the frame I’m going for. Here’s some shots 8BF12DFE-6457-4DD4-98BB-61697B772078.jpeg 45DF4B9E-D197-4C4D-B87A-9A94725CADE1.jpeg F7BF54FD-3478-4EB4-84FD-BEA427C05BEF.jpeg C9F549C2-486B-4009-95F2-CD1069523079.jpeg B4526BF1-F93B-4118-A20B-8C00B1AA53D0.jpeg C5863513-F418-42AC-AEDB-89485E1DD66D.jpeg 564307C1-3C66-4F85-B2FA-1F66FB361938.jpeg 607C8DBA-FD88-4F2E-B417-DFDA12D350C9.jpeg 07AC8312-32D0-4557-A9BA-43357EA74C6D.jpeg
    oldiron 440, Spooky, brEad and 32 others like this.
  5. Blues4U
    Blues4U
    from So Cal
    Wow, what a great build! I'm in for the ride, for sure. Thanks for sharing, and looking forward to future installments.
  6. I really like the uniqueness of what your building. Craftsmanship shows it's not your first go round. My first thought seeing it with just another Flathead was "and then another Flathead". Not knocking a Flathead, God knows I have some of my own. What your package needs is more true Vintage Race H.P. to stand out a****st the rest. How about a Race Ready O.H.V. (Drake) B Banger. Ready to bolt in add fuel and a Kill Switch. This is a B-Ville record setting motor that would be right at home between your Rails.
  7. MMM1693
    MMM1693
    Very, Very nice work! You sir are a craftsman!
  8. Joe Blow
    Joe Blow
    Perfectamundo.
    Stogy and jordabennett like this.
  9. That certainly would look the best between those frame rails. Unfortunately it has to be pre ‘39 for everything on the car, they have a grey area with flat heads and can run any year, but no later model parts. After the race I’ll blend in some good hop up parts for it
  10. Bandit Billy
    Bandit Billy
    Canadians sure weld well. Must be the air. Watching!
  11. I should get out my B-Ville rule book. I believe other than braded steel lines, high torque starter and the throttle cable the motor fits the pre 39 mark. It will take a stock A trans, (that's what was behind it) stock A starter and the Pump isn't high pressure. Pretty sure Rubber hose would do the job as well. The cl*** it ran in is Stock Body Vintage Model A. We couldn't even remove or drill holes in the Visor or change the Cloth top insert. The only upgrades were Safty Related.
  12. What do they say about an Arden upgrade on the V-8?
    Stogy likes this.
  13. I know when people see his motor they think "That's a lot of $$$". And they are right if you're building through a Machine Shop. I also know what it takes to build a Flathead 8 through a Machine Shop. We also never brake even when they go to a new home. If you still have to buy over the counter everything for the inside and pay for any kind of machine work I can soften the Hit and save you a ton of time. That little Motor red lines at 5960 rpm's and at 5500 rpm makes 218 ft lbs torque max of 232 and 231 Hp. You'd be showing a lot of the V-8's the *** end of your little skinny ****.
    Spooky, Outback, sko_ford and 3 others like this.
  14. Stogy
    Stogy
    I like what your up to @jordabennett...I remember your Roadster...this is just as unique, showing your admirable vision and attention to detail...
    brady1929, The 39 guy and catdad49 like this.
  15. How much?? Haha
  16. Thanks for the kind words! I sure do miss that roadster but once this is finished another one will be built! 28 body 32 rails 36 rear end 32 heavy axle and many more bits!
  17. 054C9C9D-8D67-4059-B484-725809E630A9.jpeg 96628518-D62B-42B2-B782-B600B6EE82D1.jpeg 3FB57525-E22C-481C-85D5-0783DDA007E6.jpeg 7AA7F277-8CE4-4E80-AA01-F6F6984B8149.jpeg Finished off a few plates and blending. The frame should look nice once painted black
  18. Cgrgrspt10
    Cgrgrspt10
    Can you show us your riveting tech please? When your plates are welded, it doesn't seem thar the rivets do much of anything but it sure looks good.
    Hnstray, Blues4U and Stogy like this.
  19. rusty rocket
    rusty rocket
    Holy ****! Very nice work! Makes my home built single seater look like **** 7E023AA7-DFE7-4EC2-817A-A272C86F67F2.jpeg
  20. Marty Strode
    Marty Strode
    I admire you guys that can make brackets from scratch, dress them up with silicone bronze, weld, rivet in place, to look factory. You would fit right in, at our Alvord Desert Meet in 2023. We are taking this year off.
    brEad, roddering, Toms Dogs and 12 others like this.
  21.
    Spooky and Stogy like this.
  22. Roothawg
    Roothawg
    It’s in Australia. I had to look it up.
    Stogy and Pist-n-Broke like this.
  23. Marty Strode
    Marty Strode
    South Eastern Oregon !
  24. Yikes, that's probably a little further than I can go on a 3 day weekend.
  25. Okay, okay now we're starting to talk my language plus it's in driving range. Are we talking about Florance aria? When?
    Spooky, catdad49 and Stogy like this.
  26. Marty Strode
    Marty Strode
    Mike, we went last September to check it out, only took around a dozen cars. Our main guy, Jim Lindsay will be out of town this coming Sept. and the Tank will be on display in So Cal as well, so we are planning on 2023. Don't want to hijack this great thread, but here is a couple pictures from last Fall. IMG_7679.JPG IMG_7699.JPG
    Charlville, Spooky, Okie Pete and 6 others like this.
  27. Marty Strode
    Marty Strode
    Mike, I edited my post South Eastern, Oregon. Below Burns.
    catdad49, Stogy and Pist-n-Broke like this.
  28. Stogy
    Stogy
    Not at all...;)
  29. Look again, just looks like Fun to me.
    Spooky, brEad, catdad49 and 1 other person like this.
  30. Stogy
    Stogy
    Of course they add something...its now an absolute brick ****house and then some...and yes it adds some vintage ambience...
    It also seems these are the real deal and added prior to the welding commencing...
    The late Hamber Langy used to add rivet like caps or reworked fasteners in his framework for the factory look...
    Like you I'd like to see the method Jorda uses...I wonder if Henry waffled the frame rivets?
    Another big rivet user is Hamber Edward Lloyd...
