Projects 1950's Tube Frame Sports Car
Discussion in 'The Hokey Ass Message Board' started by jebbesen, Oct 5, 2015.
  1. jebbesen
    jebbesen
    from Winona, MN
    Just about finished up the column this afternoon. Also decided to add an oring to the lower bearing holder. 20220304_142446.jpg 20220304_144550.jpg
    Whether I run oil or grease it'll help the threads not seep. If anyone is curious it's a -033 oring. 2.129OD and 0.070 cross section. I cut the groove about 90 wide and 2.00" diameter.
    Then I started on the column tubes. The lower one had to be turned down just slightly to slip into the upper one.
    20220304_165222.jpg 20220304_170903.jpg 20220304_170848.jpg 20220304_172434.jpg
    I cut the upper one to length and then bored out a 5" long chunk of original 49 Chevy column tubing to slip over the top end and hold the sealed ball bearing.
    20220304_174632.jpg 20220304_180040.jpg 20220304_181908.jpg 20220304_191943.jpg
    Then I milled a slot in the bottom end where the clamp holds it to the box
    That's all for today. I'm tired. Next will be fitting the blinker switch and setting up the horn wiring. I still need to do some testing to see how I'll secure the two tubes together.
    Jet96, brEad, UNSHINED 2 and 3 others like this.
  2. Ned Ludd
    Ned Ludd
    The technical term is thixotropic. I've heard it applied to non-drip paint and bentonite engineering mud.
    x15builder likes this.
  3. SS327
    SS327
    You want that d shaft to fit snugly into the tubing. Otherwise you will develop a rattle or looseness over time. When I did theft repair on columns weather Ford, GM or Chrysler you needed to collapse the shaft to rebuild in car. Some were really tough as in heat and beat. Sometime remind me to tell you about the stuck shotgun in a stolen police cruiser. How the cop managed to blow a hole through the roof of the cruiser and the shop. :confused::oops:
  4. jebbesen
    jebbesen
    from Winona, MN
    The shaft is a pretty firm push fit. Hopefully it will take quite a while to develop any looseness. I also have a full 6" of engagement so that should help. Most oems I've seen only have about half that and a lot put plastic in between too.
    Stogy, x15builder and loudbang like this.
  5. jebbesen
    jebbesen
    from Winona, MN
    This afternoon I adjusted the bearings and sealed everything up. I used rtv on the side cover and its bolts rather than the original paper gasket. Will fill it tomorrow after the silicone has had a chance to fully cure. Blinker switch should be here this week and then I can wrap up the column tube setup. 20220306_205846.jpg 20220306_205854.jpg
  6. Dave G in Gansevoort
    from Upstate NY
    Okay Jeremy, it's been 17 days since your last update. We're all having withdrawal symptoms. And in case you ask, just go look at my update...
    Stogy likes this.
  7. jebbesen
    jebbesen
    from Winona, MN
    Hah! Yeah I'm sorry. I ended up having to replace the clutch I'm my wife's VW. That's a major job. I'm ready to put it back together once the last few parts arrive. VW used torque to yield bolts on EVERYTHING so just getting all the new bolts rounded up is quite a deal. The whole front suspension cradle has to come off to get the transmission out. Between that, inlaws visiting, and sick kids there has been zero time. The only progress I've made is dis***embling/cleaning the blinker switch and making the slip ring deal that will let the horn circuit transfer power thru the column tube. I'll try to post a couple pictures after the 3 yr old goes to sleep here and I do the dishes.
    Stogy, Dave G in Gansevoort and Jet96 like this.
  8. AmishMike
    AmishMike
    I would replace that rusty bolt in steering clamp, but that just me. Love the rebuild
    Dave G in Gansevoort likes this.
  9. jebbesen
    jebbesen
    from Winona, MN
    Don't worry. I'll make sure it's either replaced or blasted. I just grabbed the one off the cars original steering column. Good job keeping me honest though! :)
  10. jebbesen
    jebbesen
    from Winona, MN
    Roughly how the switch will mount. I thought the pontiac column was 1.75" like a Chevy one but it was 2". I'll have to revamp my upper bearing sleeve on the column but that's OK. 20220309_220514.jpg
    The slip ring to get the horn power thru the column tube is made of two br*** sleeves with one grounded to the shaft and one isolated by a 3rd sleeve made of phenolic. 20220309_190542.jpg 20220309_190539.jpg 20220326_130026.jpg 20220326_130048.jpg
    The horn wire will be soldered to the isolated sleeve and the wire will wrap around the inner shaft until it goes thru the solid upper portion and gets fed thru this phenolic washer and soldered to the copper contact. 20220326_130118.jpg 20220326_130115.jpg
    These carbon brushes will run against the br*** rings. I haven't made the brush holders yet but they will be brazed to the very lower end of the column tube. The brushes started out as 3/16 square but I turned then round so I can make the brush holder tubes round. 20220309_185944.jpg 20220326_130058.jpg
    I will press the blinker canceling cam onto the steering wheel hub I make. It used to have a closed center with 3 bolt holes but I parted it off in the lathe.
    That's all I have for updates at the moment. Stay tuned. Hopefully soon I can do a little more.
    Jet96, brEad and Stogy like this.
  11. ROADSTER1927
    ROADSTER1927
    WOW your details are Awesome! Gary:):)
    Stogy likes this.
  12. tractorguy
    tractorguy
    And a gazillion other things !.......right angle gearbox on Woods 6ft. bush hog mower when #90 grease leaks past seals.......Willys Jeep steering gear......Sears snowblower auger gearbox after rebuild.......vintage bandsaw gearbox.......Case tractor front steering pedestal bearings....might have to stop buying it in the tubes and just get a 5gal bucket. Have fun
  13. noboD
    noboD
    I was liking this project when you bought it, Jebbesen. But you are doing a bangup job on it. Have fun!!
  14. Dave G in Gansevoort
    from Upstate NY
    Things are looking great Jeremy. Gonna use your slip ring idea on a totally off topic gizmo. Never thought to use brushes like that. Like I said before I'm into plaigerizing any good ideas!
  15. Ned Ludd
    Ned Ludd
    Tell me about it!
  16. Dave G in Gansevoort
    from Upstate NY
    Hey Jeremy, what's happening in Minnesota? We're hanging in here waiting for an update. I know, I haven't been too productive lately either, but hey I'm old enough to be your father...
  17. Dave G in Gansevoort
    from Upstate NY
    Hey Jeremy, it's May 1st. Any updates for us? Everyone is getting anxious...
  18. jebbesen
    jebbesen
    from Winona, MN
    Sorry for the lack of activity here. Finally was able to go work on the car a little this afternoon. Doesn't seem like much but I made a little progress on my steering column. I needed a piece to adapt the wheel to the blinker switch housing. A week or two ago I grabbed an old pneumatic actuator cover from the s**** tub at work. I think it used to operate a louver for an exhaust fan on the roof.
    Seemed like I might be able to make something out of it...
    20220530_151931.jpg 20220530_152454.jpg 20220530_152452.jpg 20220530_154559.jpg
    Then after adding some holes it fits between the wheel and the adapter.
    20220530_161239.jpg 20220530_161302.jpg 20220530_161258.jpg 20220530_161356.jpg 20220530_161403.jpg 20220530_174025.jpg 20220530_174030.jpg
    It's cast iron so I'll prime it until I figure out what color the column will end up. Pretty happy with it. Next is getting the blinker canceling cam adapted.
    BradinNC, brEad, Tman and 15 others like this.
  19. Squablow
    Squablow
    I don't think I ever saw a car build with so much lathe work in it before. Steering wheel cover looks good, nice to see this still moving along.
  20. ROADSTER1927
    ROADSTER1927
    Looks Great Buddy! Gary:cool:
  21. jebbesen
    jebbesen
    from Winona, MN
    Finished up the aluminum upper bearing holder. I still need to put a small woodruff keyseat in the shaft to time the blinker canceling cam. Getting closer though! 20220605_154503.jpg 20220605_154516.jpg 20220605_154554.jpg 20220605_154601.jpg 20220605_155555.jpg 20220605_155639.jpg 20220605_160117.jpg
    Tman, Bandit Billy, alchemy and 5 others like this.
  22. ROADSTER1927
    ROADSTER1927
    Looks Great Buddy!:)
  23. jebbesen
    jebbesen
    from Winona, MN
    Horn ****on ***embly is finished. I drew up what I wanted in CAD just for dimensions but manually machined all the pieces. Bought a generic horn ****on for the plastic piece but made everything else. Sanded the texture off the plastic ****on. The contacts are made out of copper. Used a slightly modified spring from a unistrut nut. In the pictures it's bolted to the fixture block I finished the outside on in the lathe. Bolting it to the fixture with the spring and contacts let me check how the ****on moved and how stiff the spring was. Very pleased with it. I'll try and get some pictures of it installed on the steering wheel tonight.
    20220616_103452.jpg 20220616_104346.jpg 20220616_103736.jpg 20220616_103615.jpg 20220616_104546.jpg 20220616_120900.jpg 20220616_120905.jpg 20220616_120912.jpg
    Tman, brEad, Kroombit and 3 others like this.
  24. Fabber McGee
    Fabber McGee
    Damn that's nice. Only problem I can see is that all the fine pieces you've built are going to make the remaining original parts of the car look mighty crude.
  25. jebbesen
    jebbesen
    from Winona, MN
    Bolted it in place on the wheel. I like it! Would have rather been able to use head head bolts but didn't have room. As the pic from the 1949 Bell catalog shows, they did sell the hubs with socket heads. Period at least.
    Also I agree about it being hard to match some of the crude original construction. I do plan to blow it all apart eventually and rework some of the original welds. Once the frame is painted it'll all blend in more. 20220616_183944.jpg 20220616_183947.jpg received_435297505053731.jpeg
    Tman, brEad, Shadow Creek and 3 others like this.
  26. ROADSTER1927
    ROADSTER1927
  27. Dave G in Gansevoort
    from Upstate NY
    Really nice! Love the steering wheel and your custom hub. I gotta get me a new lathe...
    jebbesen likes this.
  28. jebbesen
    jebbesen
    from Winona, MN
    Got my pieces cut for the rear upper shock mounts. Have to smooth the edges and weld them on. 20220627_175708.jpg 20220627_175736.jpg 20220627_175728.jpg 20220627_175743.jpg
    Tman, Jet96, ottoman and 3 others like this.
  29. it seems you are "de-sketchifying" the car so you can drive it without the fear of it coming apart. which makes a lot of sense to me. still looks bad***.
  30. jebbesen
    jebbesen
    from Winona, MN
    Yeah that's a good way to describe it. I wish progress was better. I haven't had any time to work on it lately but it goes in spurts. I still hope to have it back to rolling and steering yet this fall.
