Hot Rods Hurst Mounts and the sincere Imitators
Discussion in 'The Hokey Ass Message Board' started by SilverJimmy, Mar 4, 2022.
  1. Been seeing many different Hurst mounts in different hot rods and was wondering how many Hurst actually made and how many are copies. So, let’s see what you guys have and if you know what they fit. Here’s what I’ve got, it’s a bit different from most I’ve seen for the early 303-324 Olds as it’s one piece and utilizes the lower bolts for the timing cover.
    53D6AF43-DDC6-4C33-A85A-F01E5768DB70.jpeg 1646D20F-A7CE-4BD0-A796-67213D6EBE1A.jpeg 73FC5B1E-3661-4FD0-B3F9-9CE2F98BB97E.jpeg CA99C2FA-2A4C-4759-9E47-ED950F4214EF.jpeg 0F4D643C-6996-4C6B-8AE2-AF7C6FAEEBBF.jpeg 130740A6-9945-4B78-BE4A-0A98EAAAA332.jpeg 3EC48B4E-59A8-4531-94CE-171F8409D68C.jpeg If anybody has any print ads or catalog info, please post those too. Let’s see what you have!
    tractorguy, Okie Pete, brEad and 4 others like this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. nochop
    nochop
    from norcal
    I’ve got this 90369338-0872-4C3D-805F-43863D1EB32A.png DFDA4811-D129-45A2-9CBB-9C8DA5A36FCF.png
  4. Never really understood these regarding crushing the timing cover gasket.
    I would of though they would continually come loose until the gasket was no longer useful?
    They obviously don’t though,or do they?
    kadillackid likes this.
  5. nochop
    nochop
    from norcal
    Hmmm, now you did it. You got me thinking
    tractorguy, kadillackid and loudbang like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ever see a stove bolt Chevy inline 6 set up?
    tractorguy, loudbang and VANDENPLAS like this.
  7. Bob Lowry
    Bob Lowry
    From a 2016 post.....
  8. Splitbudaba
    Splitbudaba
    5478F51A-555F-4167-B3E2-D45ACF42B5F4.jpeg 4836F36C-5582-410A-872E-96288EEA7535.jpeg Imitator, definitely, purchased a u weld it kit from eBay. Modified it for pump clearance on my sbc. It was easy to do! Purchased a wider lower strap. Bent face plate as required and tacked the lower strap in place. Made some support angle gussets and welded it up! Works great for my application. One tip, have the pump you plan on using, their diameter can vary. Plus it helped the steering box clearance!!
  9. So according to the catalog it looks like my mount started out as a PO-202 and then was modified with the lower tab to capture the timing cover bolts. I pulled it off my Olds 324 so long ago I don’t remember if all the bolt holes were used, I need to put it back on and I’ll post a picture. I like that my mount has Hurst stamped into it, back when a manufacturer was proud of their products!
    loudbang, Paul and Bob Lowry like this.
  10. Bob Lowry
    Bob Lowry
    Another from 1960 catalog..
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    1967 Moon catalog
  12. Now I’m confused, my mount fits my 324 Olds perfectly! 5CD6F999-2494-4408-BA9C-49B23A7AEC69.jpeg All the bolt holes line up and match the front of the motor.
    Okie Pete, AHotRod, jimmy six and 5 others like this.
  13. Budget36
    Budget36
    Kinda looks like the one on the upper left w/o the bolt it is off a bit? Maybe just pic angle
  14. Budget36
    Budget36
    I’ve a Hurst mount for a BBC into a 35-40 Ford, must be “newer” as the one I saw pictured has holes for small block, 409 and 427. Mine is steel(one I had before was aluminum) but only has holes for the BBC mount.
  15. Motorwrxs
    Motorwrxs
    If you were running on these types of engine mounts and wanted to run an automatic that uses a two bolt pad mounted to the crossmember towards the end of the tail shaft would that work? Just curious about flex because of the distance between the engine and transmission mount.
  16. Sorry for my comment but I tend to overthink things.
    I’m making a very similar mount for a single seater project using an A banger motor but they have actual mounts cast into the timing cover and use only a thin paper gasket.
    The Hurst ones obviously work well,look great and a lot of guys use them and have been for a long time.
    tractorguy likes this.
  17. MCjim
    MCjim
    from soCal
    Yes, used the hurst one in my 55 Chevy, and the C1 Corvette basically used this type of mounting from the factory.
    tractorguy, Moriarity and Motorwrxs like this.
  18. nochop
    nochop
    from norcal
    No
    Beanscoot and loudbang like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Did Henry's water pump gaskets fail?
    Okie Pete, Toms Dogs and loudbang like this.
  20. jimmy six
    jimmy six
    One would be ez to make using a saddle to start. The first thing is the two lower timing cover bolts would need to be removed and the front main cap taped. Those could used for support and a “wing” on each side of the engine down to the saddle for added twist or torque stabilators.
    tractorguy and loudbang like this.
  21. A bolt would go right in that last hole, it’s just the angle and light messing with you. Too bad Hurst didn’t stamp model #’s on their mounts.
    dirt t, loudbang and Budget36 like this.
  22. atomicglowman
    atomicglowman
    The ones pictured are what I have in my Olds powered Model A. Original, got them off a 48 Merc I drug home that had an Olds motor in it.
  23. pprather
    pprather
    I would say the engine would like a rear mount, possibly off the bell housing bolts, like a 55 Chevy, to relieve some of the stress on the front and tailshaft mounts.
    Just my opinion.
  24. Speedy Canuck
    Speedy Canuck
    The centre lower mount is just the stock front mount off an Olds motor. Looks like it's been welded onto your Pontiac Hurst mount.
    bchctybob likes this.
  25. Flatrod17
    Flatrod17
    Unfortunately Hurst don't make a mount that I needed, so I made my own Hurst style. Flathead with 409 water pump. Still in mock up stage. Mount.jpg
  26. nochop
    nochop
    from norcal
    Cool, drill some lightning holes to make it cooler. Nice work
  27. Flatrod17
    Flatrod17
    Thank you. Can't drill to many holes. There are water holes behind the two vertical bolts. I machined them for disc type freeze plugs, but it's thin there so the mount will help seal them. But it's not finished yet and will get some lighting holes somewhere!
  28. swade41
    swade41
    from Buffalo,NY
    I've had real Hurst mounts with the "Hurst" stamp, still think I have one somewhere, then I have this imitater
  29. choptop40
    choptop40
    Easy to fabricate..I had same issue years back , oil leak in front bolt hole.. Hurst name just screams hot Rod..
  30. choptop40
    choptop40
    just bought a tubular engine trans combo , included engine / trans mount and hardware,,,,,,,heavy duty steel ...on E#ay...105.00 shipped....i think transdapt is also made in Chickety Chick...you know where...
