Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Johnny99
    Johnny99
    Rooting for you Marty. We'll need to have a go, last year was probably the most fun I've had at the track.
    Toms Dogs, bchctybob, brEad and 4 others like this.
  2. Marty Strode
    Marty Strode
    Your on Johnny, can't wait !
    bymanr, Bandit Billy and Stogy like this.
  3. Marty Strode
    Marty Strode
    Russ Meeks (Finish Line Coatings) did these 7 years ago, I need to talk to him. Russ Meeks Coating.jpg
    Tman, bchctybob, brEad and 7 others like this.
  4. Johnny99
    Johnny99
    I'm sure you'll kick my **** with that injected small block---this year, next year we'll see. Staying focused on another project right now but next winter the Willys is in for some serious upgrades. Funny how a shot of rattle can Chevy orange can make these heads "traditional".
    bchctybob, Stogy and loudbang like this.
  5. Marty Strode
    Marty Strode
    Got some new tires for the '40 mounted up today, should be a roller in a day or so. Pretty happy with the 55 hubcaps, the wheels are 5.5's and 8's. . IMG_8572.JPG
  6. Marty Strode
    Marty Strode
    Now that should make some power !
    Stogy likes this.
  7. Marty Strode
    Marty Strode
    I got to thinking about what flywheel I was going to use in the RP, and remembered buying one 20 years ago. Since it is a Chevy engine with a Ford Toploader trans, and a friend traded me his old Doug Nash pro shifted internals with the 1-3/8 ten spline input shaft, I needed the Long Style bolt pattern. Along with the deal I got his, Ram "Cleaning Lady" disc, and pressure plate ready to go. The flywheel I had is a 32 lb, billet steel, with the correct pattern, and is brand new ! IMG_5047.JPG IMG_5048.JPG IMG_8573.JPG IMG_8574.JPG
    Toms Dogs, Runnin shine, Tman and 9 others like this.
  8. Marty Strode
    Marty Strode
    On the '40 Pickup, I got it on wheels tonight. Everything is just loosely bolted in place, and the final ***embly work will come later, when I get it moved out of these cramped quarters. IMG_8576.JPG IMG_8578.JPG The next thing I need is a bushing kit for the '40 pedal ***embly.
  9. Marty Strode
    Marty Strode
    I did get it moved today, and am making arrangements to ***emble the engine, and break it in before installing in the ch***is. But for now I am making a full court press on the RP. IMG_8580.JPG IMG_8581.JPG IMG_8582.JPG IMG_8583.JPG
    Toms Dogs, bchctybob, brEad and 16 others like this.
  10. Marty, Your ability to jump from project to project is admirable. It's all I can do to keep one project on track in my mind...and I still forget stuff!
    ratrodrodder, Stogy and loudbang like this.
  11. Marty Strode
    Marty Strode
    I guess it comes from 46 years of having multiple customer's cars in the shop at the same time. Thanks.
  12. AmishMike
    AmishMike
    Looking forward to u hitting the track with 32 lb flywheel, stick trans & some rear gear. Forget if you building/adding wheely bars. Should be a fun trip. Is that trans a 5 or 4 speed? Will the quick change handle the hit?
    loudbang and Stogy like this.
  13. Marty Strode
    Marty Strode
    I am going to add wheelie bars, the trans is a 2.78 first gear Ford Toploader 4 speed. We will se if the Champ QC can handle the load.
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    No Worries:D
    brEad and loudbang like this.
  15. AmishMike
    AmishMike
    Looking forward to video of that first hit & those after some engine tuning & adjusting suspension. Should be one hell of a trip - many trips; all safely
  16. Marty Strode
    Marty Strode
    Thanks Bruce and Mike !
    Stogy likes this.
  17. Dean Lowe
    Dean Lowe
    No worries with the Champ QC Marty. Ran mine for 5 years with narry a problem. Clutches were a different story. The last year the car ran we were lucky to get 2 weekends out of one. Had one in the car, a spare with us at the track, and one at Weber getting fixed.
  18. Marty Strode
    Marty Strode
    Dean, The Ram disc I will be using for the track is pretty rugged, should hold up for what I will be doing.
    bchctybob and Stogy like this.
  19. Marty Strode
    Marty Strode
    I made some progress this weekend on the new front mount. I liked the looks of the one @GuyW posted, but it had too much drop for my engine to frame height. So, I laid one out on some .063 aluminum, and fit it to the application. What I came up with has a "mustache" look to it, with large radius curves. Once I was happy with the layout, I transferred it to 1/4" cold rolled steel, and used the bandsaw to cut it out. Next will be making and welding the pad mountings on. Also, I got the other rear wheel finished welded, now all I need to do is to drill the holes for the tube stems, and the screws, and off to powdercoat for them. IMG_8584.JPG IMG_8587.JPG IMG_8588.JPG IMG_8593.JPG IMG_8595.JPG IMG_8596.JPG IMG_8597.JPG IMG_8599.JPG
    alanp561, Tman, bchctybob and 20 others like this.
  20. Marty Strode
    Marty Strode
    I did a little more on the front mount this afternoon. The press, with a simple setup bends perfect curves every time. It's welded, now to layout the holes for the hockey pucks, trim the ends, and make the frame pieces. IMG_8604.JPG IMG_8605.JPG IMG_8606.JPG IMG_8608.JPG IMG_8611.JPG IMG_8612.JPG IMG_8614.JPG IMG_8621.JPG IMG_8623.JPG
    Toms Dogs, Tman, bchctybob and 24 others like this.
  21. swade41
    swade41
    from Buffalo,NY
    Nice welds
    Stogy, loudbang and j hansen like this.
  22. Marty Strode
    Marty Strode
    I use an old Airco with a "peddle pulse", meaning I rock my foot up and down on the peddle ! Thanks...
  23. Bandit Billy
    Bandit Billy
  24. Flatrod17
    Flatrod17
    Marty I got a chuckle seeing your press set up. I did the same thing when I made my Flathead mount, but I didn't have a piece of pipe that big, so I used a late model 350 chevy damper to press round.
    Wish I could weld like that!!
    bchctybob, Stogy, GuyW and 2 others like this.
  25. Marty Strode
    Marty Strode
    Billy, I will be there, rain or shine. I ordered some bolts from CJ, and it will be fun to catch up with friends, old and new !
    embyman68 and Stogy like this.
  26. Marty Strode
    Marty Strode
    It helps to make the parts out of cold rolled, makes the welding the easy part. Looks like you found a use for at least one Chevy part !
  27. Bandit Billy
    Bandit Billy
    See you there Marty
  28. Marty Strode
    Marty Strode
    I had a pretty constructive weekend, got the frame brackets, for the engine mounts, cutout and formed yesterday. IMG_8629.JPG IMG_8630.JPG IMG_8632.JPG IMG_8635.JPG IMG_8636.JPG IMG_8637.JPG
  29. Marty Strode
    Marty Strode
    Today, I was able to tack in the new mounts, and remove the old mount on the driver side. That made it possible to mount the 525 steering gear. I was also able to tack the front shock mounts in place. One of the next things to do, is to heat and bend the steering arms at the spindles, and make corrections at the pitman arm. It wont be long can set in a seat and install the steering column, making way to mount the pedals. IMG_8639.JPG IMG_8642.JPG IMG_8646.JPG IMG_8648.JPG IMG_8649.JPG
    brEad, bymanr, Gotgas and 8 others like this.
  30. Bandit Billy
    Bandit Billy
    Looks real nice Marty! Good seeing you down at the bolt Saturday morning. Love PNW rain. I got a few trinkets and saw a lot of buddies. You included! Build on!
    Toms Dogs likes this.
